HOW TO: ipod into hotrod without a radio
Discussion in 'The Hokey Ass Message Board' started by negativeMatt, Feb 18, 2008.
  1. look, the ipod hook up is EASY. it takes up less space, it's easier to hide, and you don't have to store all your cd's someplace.
    here's what ya do.....
    get an ipod.
    go to your local stereo shop or shop online, but beware that alot of these products do not carry a warranty if purchased online.
    the first thing you need is a PAC a/v output adapter. this will provide an audio signal output and charge your ipod while driving.
    next you'll need a PAC lc-1 volume control. this will allow you to control the volume. most shops use these for subwoofer control, but it's really just a potientometer. should be easy to disguise it with a dashknob. you need this, because when use the ipod output instead of the headphone jack, you will not have volume capability on the ipod itself.
    these 2 parts should run around 50 bucks^^^^^^^^^
    next you'll need an amplifier. any amp with rca inputs will do. for a small, clean, and cool running amp, i suggest the alpine PDX series. they're digital so you can stash them anywhere and not worry about them running hot. and they are pretty small for a powerful amp. not the cheapest, but very good.
    of course you'll need speakers too.
    mount your amplifier wherever you choose. be sure to put an inline fuse at least 12" from the battery. next hook up your speakers to the amplifier. speaker placement will depend on type of car etc.., so i won't go into that.
    mount your LC-1 behind the dash, or inder or wherever. the knob just pulls off a splined shaft, and a small 8mm nut holds it in the mount. i usually remove it from the mounting box for more custom installations.
    run an rca from the output side of the LC-1 to the input side of your amplifier.
    next choose a spot you want your ipod. you'll need to run an rca from the a/v adapter cable to the input side of the LC-1. you'll also need a 12+ and ground wire run to the a/v cable to charge your ipod while driving.
    ok, after all this is done, plug in your ipod to the a/v cable. make sure the gain control on the amplifier is all the way down. turn the LC-1 all the way up. choose a song and play it on the ipod. while the song is playing, adjust the amplifiers gain control up until the music starts to distort. now back off a bit and you've set your volume at max and should help your equipment live a long full life. ( if you amp has a crossover network, i usually set the x-over point at around 120hz highpass. it eliminates alot of distortion and will allow higher volumes. it's not the the most accurate for fine tuning, but in a car with loud exhaust, squeaks, etc...volume is a bit more important!)
    so there ya go, everything you need to use an ipod in your car without the use of a headunit, or cheesy ipod speakers.
    i would do a step by step tech, but i'm sitting at the airport waiting to ship-out, so i don't have access to a camera, or hot rod for that manner!! i'll do a complete one when i get back!
    LOU WELLS and Jim the Sweep like this.
  2. Ryan
    Ryan
    ADMINISTRATOR
    Exactly like I do it...
  3. Stroked
    Stroked
    from DFW, TX
    I like it :cool:
    My ipod goes everywhere with me, but my coupe will never see a modern head unit... this definitley a good compromise.
    - Matt
  4. butch27
    butch27
    Ship Out sounds like Iraq. Take care of yourself and your buddies.
  5. 40Standard
    40Standard
    from Indy
    thanks, I was wondering where to put a radio in my 40
  6. bloodyjack
    bloodyjack
    Why dont ya just use the headphone out right into the amp with a $2.99 cable from anywere (target wallmart rite aid etc)? Thats what I do and retain the volume on the I-pod
  7. bigken
    bigken
    Matt, thanks for the 'tech'. I've been wondering where to stash some tunes/speakers.
    Keep your ass safe over there, and get your tail back here ASAP.
    Later man - BigKen
  8. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Thats how I play the MP3s on my cell phone.
  9. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Pretty neat, how far we've come since a 1940's AM-only tube radio that took up 1/3 of the dash.
  10. flatoz
    flatoz
    good idea to use a modern approach in a old car without having to butcher any of it, or try to hide a big arse headunit.
  11. Abomination
    Abomination
    Think how much a guy could make reselling crap to put iPods into cars? I wonder if http://www.ipodyourrod.com is available? Hell, I could resell, AND drop-ship everything. I wouldn't have to keep ANYTHING in stock. I could put together complete packages...
    ~Jason
  12. Ryan
    Ryan
    ADMINISTRATOR
    Because you lose sound quality that way... And you have multiple cables leaving the ipod if you want to charge it.
  13. scootermcrad
    scootermcrad
    HEY! NEAT! I dig it! I was thinking about this very thing the other day. I would like to do this for road trips. I won't use a stereo for around town driving, but thought if I wanted some tunes for road trips this would be a bitchin' idea!
  14. Jalopy Jim
    Jalopy Jim
    Thank you for the information, I am at doing the repair and design of the interior of my 54 F100 project. Next weekend is the dash so now I know what holes I need to leave. and online I found the size I need for the Amp.
    again thanks
    jim h
  15. bloodyjack
    bloodyjack
    you would have multiple cables because one to charge would be great but the headphone out is just an amplified version of the line out on the connector you will not lose sound quality!
  16. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    Will this process work for an XM Inno too?
    http://reviews.cnet.com/satellite-radio-tuners/pioneer-inno-xm/4505-7873_7-31824917.html
    It is basically an iPod but with XM capabilities. I suppose it has the same ports/jacks as an iPod. I want to figure out a way to wire all of my cars so I can just move the Inno around depending on what I'm driving. And yes, I realize I will need an antenna.
    I'm getting ready to do this in the Chevy. Any advice appreciated.
  17. hotrodladycrusr
    hotrodladycrusr
    Now you tell me after I spent a couple of hundred on a new CD player......:rolleyes:
    Actually Megan has been saying this is the route for me BUT I'm an old dog.....:D
    Will you have you set up at the RoundUp? Perhaps I can take a look at it and you can show me just how easy it is to use.
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Bud Crane never had an Ipod
  19. Thirdyfivepickup
    Thirdyfivepickup
    Its so simple I'm confident you could do it yourself.
  20. ian
    ian
    very efficient. thanks for the information.
  21. Rusty
    Rusty
    Well looks like I wont be cruising around with my ipod earphone anymore
  22. Sean
    Sean
    The SNR of the head phone out compared to the Line out (dock connection) is minimal, within a db or two depending on which gen iPod you own. The Wolfsan DAC's were updated in gen 3 iPods.
    We are talking 98db SNR for the headphone out verses 100db SNR for line out. You will most likely never hear the difference. The real issue at hand would be the quality of your files. Do you encode in a lossless format like ALAC, WAV or AIFF, or a low bit rate MP3?
    Since the headphone out works like a preamp with EQ and volume control you can just run right into a two channel amp and with battery run times of 30-40 hours I rarely need to charge it in the car.
    Good info none the less.
  23. Abomination
    Abomination
    If I did start up a small business venture that sold stuff (and only stuff) to put an iPod into your rod, with or without a radio, would anybody be interested?
  24. Very good info. Thanks very much. Now, how to add my XM Roady unit? Then I'll have everything I want for music in the car.
  25. BZNSRAT
    BZNSRAT
    yepper...but, why hasn't this been dun?...
  26. 8flat
    8flat
    ...or build a custom PC case, super small mother board, big hard drive, and store all of your songs on-board. Call it an iRod.
    oh forget it....
  27. bloodyjack
    bloodyjack
    this is a non starter you can get everything you need in any of the following stores for super cheap
    Wall mart, Target, Fred Myer, Rite aid, K mart, Radio Shack
    An Audio connection cable is under 5 bucks
    http://www.target.com/6-Y-Adaptor-8...v&field-browse=3524091&rank=pmrank&rh=&page=6
    and a car charger is under $15
    http://www.target.com/Belkin-Mobile...field-browse=194069011&rank=pmrank&rh=&page=8
    Most of these stores sell amps and speakers too
  28. Abomination
    Abomination
    Hey, I was in talks with a company to make a pull-out stereo-type docking bay enclosure for the Mac mini that would fit in a standard radio bay, but that's a story for a different time. :) Not for this market at all...
    ~Jason
  29. Abomination
    Abomination
    Of that there is no doubt - it is cheap.
    My intent was to put together an all-in-one package for folks that just want to get it all in one place and have it all just work, never to rip folks off. Granted, there would be some small profit to be made, but it would be less than you'd spend to hunt around for all the parts, do the research, and put the whole package together yourself.
    After all, it was just a passing thought. Nobody sells a complete kit, to my knowledge. Seemed like folks might want that.
    ~Jason
  30. Mercmad
    Mercmad
    from Brisvegas
    Within a week of Apple announcing the Ipod ,I had a mate do exactly this,but to disguise his jack he used a point on the becker mexico radio in his Mercedes and the radio just acts like a front,the switch only turns the amp on and off and a hand held remote works it .1960's looks with 2008 sound.
    it's not new idea by any means but simplicity rules as far as i'm concerned and most modern CD players etc look like they belong in ricers.
    Jim the Sweep likes this.
