Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Alliance Member
www.zddplus.com Need a good stiff shot of ZDDP, click on the site listed here. Trying to get these guys to become Alliance Vendors. They are car guys like us.
__________________
seeking the truth note: 'RED FRIDAYS', if you support our troops (men/women in uniform), wear red on Fridays! Spread the word. Last edited by no55mad; 01-15-2008 at 05:25 PM. |
#22 | |
Alliance Member
Quote:
I've been running the 10w-30 Rotella T in the 390 in my Galaxie. Do you think I should go ahead and run 15w-40 (Rotella)? I don't drive it in temps below 40 and the engine is only slightly worn - doesn't use any oil. Malcolm |
#23 |
Old School HAMBer
#24 |
Old School HAMBer
#25 | |
Old School HAMBer
Location: Just past the corner of Hell and The Twilight Zone.
Quote:
How much ????? 10 parts per million doesn't count,if you need 1000. |
#26 |
Just find a dealer for Brad Penn racing oil. It's got all the good stuff and is cheaper then buying 5 quarts and an additive.
__________________
2 things are infinite, the universe and human stupidity, I'm not sure about the universe |
#27 |
Should we believe that new cams and lifters are designed to work without the zinc?
It's funny how many stories I read about new cam and valvetrain components failing too soon.
__________________
Yes, you can heat a 10x20 storage unit with an extension cord and a couple heat bulbs. Jonny o |
#28 |
Old School HAMBer
I'm gonna use a roller cam. That'll show em!
__________________
Oh, did I hurt your feelings? |
#29 |
Alliance Member
They don't make the red bottle STP anymore... that's why its not readily available... it will be gone completely very soon. i use Rotella and a bottle of the blue STP, it has almost as much zinc, and doesn't hurt a thing. The Rotella still has alot of zinc too, just not as much as it used to. Together they'll give you all the zinc you need, and it's the cheapest combination of zinc enriched products you can get IMO... Running this setup in 3 cars with no problems in any of em. Didn't someone post "proof" that all this zinc folklore is a myth anyhow?
__________________
Check out my pics and some other cool stuff at: http://www.myspace.com/joeybsyc |
#30 |
Old School HAMBer
CI-4 diesel oil is high zinc, the new CJ-4 isn't. CJ is same as car oil.
__________________
Confucious say Tennis elbow better than Tennis balls |
#31 |
Tech Editor
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4GGIH_enUS226US227&q=oil+zinc+zddp+site:jalopyjournal%2ecom
More info on oil than you care to read - right here on the HAMB
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch! T5 Tech |
#32 | |
Quote:
#33 | |
Alliance Member
Quote:
__________________
#34 | |
Senior Member
Quote:
__________________
flathead or ovhd- fords only |
#35 |
Dum-dum here,...curious to facination with Zinc in oil ...why , what ,when ...years of motors it's needed,etc. You guys way over my head here.
__________________
#36 |
Old School HAMBer
Zinc is considered the best for lubing non roller cams. It isn't nessesary on cars with roller cams (mid 80s) & it increases emissions so the car companys had the oil companys eliminate it from car oil. There has been a rash of cam failures reported, mainly with high spring pressures. Is it the lack of zinc, bad cams or lifters? Both? People don't seem to be sure.
__________________
#37 |
AH-So...early '08's & earlier need a zinc injection. Does unleaded gas also contribute to these failures? looking at a'64 427 Fairlane. What do I run it on ?
__________________
#38 |
Old School HAMBer
I know this is a bit off topic but this stuff is amazing.
If you want to make sure you engine is being lubed properly this is a must. It expensive but I have seen it work. A guy I know took an old worn out Ford inliner and put it on a stand and ran it for a while with fresh oil and the recomended amout of this stuff in it. Then he drained all the oil and took off the valve cover, side plate and the oil pan. Then with no oil or sheet metal on the engine he fired it up. No noise, no smoke, no grinding no nothing. It ran like a top, never got hot, never ate up any berrings and the rocker arms and pushrods were almost silent. I think the engine has almost 1000 hours running on the stand with no oil. And it still runs great and has no noise whatsoever. I wouldn't have believed it unless I saw it for myself. I haven't put it my engine yet but from the tests I saw this stuff is amazing. Expensive but amazing. I think it is at least worth looking into. http://www.lubricationproducts.com/index.htm |
#39 |
Alliance Member
And then again maybe the sky isn't falling?
![]() http://www.fmrcoa.org/newsletter/200...ter_Screen.pdf It's nice to read a dissenting opinion every once in a while...
__________________
Damnfingers Words of wisdom from that famous philosopher, Willie Nelson: "I have outlived my dick."
#40 |
Alliance Member
I would have to agree with him at least on the point he makes that the performance grinds are more susceptible to failure. Keeping in mind there are flat tappets out today that are wilder than some of the older roller grinds.
But then we have had a few failures at work (with the ground support equipment) and those were all O.E. replacement type cams so. ![]() He mentions phosphating the cams, I personally think the $20 or so it costs to Parkerize a flat tappet cam is worth it (assuming you have it out already). And yes I definitely like to read a dissenting opinion, especially from a credentialed industry rep. |
| Thread Tools | |
| Display Modes | |
