Reply
Thread Tools Display Modes
Old 01-06-2008, 01:15 PM   #1
Spoon
Grenade Inspector
Spoon's Avatar
Default Alternator rotation
Will an alternator produce voltage reguardless of it's rotational direction?
If so, how will it's cooling be effected?
__________________
Some say she's retarded, but those titties ain't retarded!!
offline   Reply With Quote
Old 01-06-2008, 01:31 PM   #2
Von Rigg Fink
Old School HAMBer
Von Rigg Fink's Avatar
Default Re: Alternator rotation
how do you plan on rotating it any other way than it already does?
No matter where you place it on the front of your engine it will always rotate the same way, unless you plan on twisting your V belt into an 8 shape, or mount it facing your engine..am i right?
__________________
Goldchainers CC S.E. Michigan Chapter
Charter Member
Some guys could fuck up free lunch.
Old 01-06-2008, 01:40 PM   #3
dave lewis
Alliance Member
dave lewis's Avatar
Alternators will charge turning either direction. The fan will normally pull warm air out of the case (clockwize, facing the engine) If you need to mount it backwards on the engine ( clearance issues??) it will work fine. The fan will blow cool air into the case. ( slightly less efficient, but ok.)
Dave :-)
online   Reply With Quote
Old 01-06-2008, 01:40 PM   #4
Dirty2
Old School HAMBer
Dirty2's Avatar
It dosent care which way it spins. There is oppasite direction fans like for the serpentine belts which turn the alternator and water pump ccw. But I have never had a problem with the std fan.
__________________
If it dont have 3 pedals it aint no HOT ROD !
If you didnt build it " Shut Up "
" I'm to old to get what I want and to young to give up trying "
me "
www.texasnostalgianationals.com
Old 01-06-2008, 01:45 PM   #5
Von Rigg Fink
Old School HAMBer
Ok, cool I didnt know that either!. good thing to remember.
__________________
Charter Member
Old 01-06-2008, 01:51 PM   #6
DrJ
Old School HAMBer
DrJ's Avatar
Are there marine application reverse rotation alt's for reverse rotation engine$ available with reverse bent fan$?
__________________
Not my fault, I was at camp.
Old 01-06-2008, 02:00 PM   #7
Von Rigg Fink
Old School HAMBer
The marine application issue would be a good source..(Expensive ) but good source..The marine Alt's are approved for that application so they are to provide a low risk of ignition in the case of fumes in the engine compartment, so they get a few bucks more for them..kinda like the Marine Carb. issue.
__________________
Charter Member
Old 01-06-2008, 02:14 PM   #8
Spoon
Grenade Inspector
Spoon's Avatar
The alts I have came off of different V8s and I'm mounting one on my Flat 6. I noticed the fins were opposite from the ones on the generator that came off of the Flathead 6 cyl. Then, I got myself all confused as to which direction my V8s turned. I think they both turn counterclock wise from the drivers seat, but I'm not positive. That's how this question popped up.
Thanks for all of your help.
Ya'll rock!
__________________
Old 01-06-2008, 02:32 PM   #9
langy
Old School HAMBer
langy's Avatar
If the alternator has been used for any length of time the brushes will have bedded thereselves in and may not like being spun in the other direction at first. Got the shirt :-(
__________________
Steve
Checkout my Willys project here http://jalopyjournal.com/forum/showthread.php?t=572303
Old 01-06-2008, 04:10 PM   #10
stuart in mn
Senior Member
stuart in mn's Avatar
If I recall correctly, Corvairs had a reverse rotation alternator so if you're talking about a GM alternator you could try to find an alternator fan off one of them.
Old 01-06-2008, 04:21 PM   #11
Gusaroo
Grenade Inspector
Gusaroo's Avatar
If your running a serpentine set up, you could potentially be in a situation where the alt may run in reverse... but why would you want a serp set up anyway?
__________________
-Joe
'60 Bel Air - 454 w/4 speed
http://www.jalopyjournal.com/forum/a...p?albumid=2743
Old 01-07-2008, 11:05 AM   #12
Model A Vette
Yes, Corvair alternators turn counterclockwise veiwed from the front. They were used '65-'69. The fans are different and the nuts to hold the pulley and fan on are lock nuts. Clarks Corvair sells billet fans if you feel the need! (www.corvair.com)
__________________
Ed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
