Reply
Thread Tools Display Modes
Old 01-01-2008, 12:31 PM   #1
Razzmataz
FNG
Default 16" chevy truck 6 lug rims ??
I have a 1965 chevy pick up with 15" 6- lug rims , I want to put some 16" inch 6 lug rims on it, are there any later model chevy truck 16" 6- lug rims that would fit ?? The center hole on the rim needs to be at least three and half inches for the hub to fit thru. I would prefer a stock steel rim.
offline   Reply With Quote
Old 01-01-2008, 12:38 PM   #2
CURIOUS RASH
Classified's Moderator
CURIOUS RASH's Avatar
Default Re: 16" chevy truck 6 lug rims ??
Have you looked at http://www.fullsizechevy.com/forums/ ?
I bet this has been discussed there.
online   Reply With Quote
Old 01-01-2008, 12:40 PM   #3
chaddilac
Old School HAMBer
chaddilac's Avatar
I ran Z71's on my Nissan pu 10 years ago... had to have the machine shop cut the hole in the middle out, no big deal though. I think it cost me $40 and they fit well.
__________________
Specializing in Custom Logos and Design
Old 01-01-2008, 12:40 PM   #4
v8 Bake
Grenade Inspector
v8 Bake's Avatar
A lot of mid 80's suburbans had 6 hole 16's. They are out there if you can find them.
Old 01-01-2008, 12:40 PM   #5
Alliance Member
Mr48chev's Avatar
Most 4 wheel drive half ton wheels should fit but try before you buy.
Old 01-01-2008, 12:42 PM   #6
Ted Kempgens
Grenade Inspector
Ted Kempgens's Avatar
Red Neck trailer supply. Part # WH166-60E 16x6, 6 lug 3.65 center hole, OEM style wheel
Old 01-01-2008, 12:51 PM   #7
Old School HAMBer
squirrel's Avatar
16 inch wheels were available as an option in 55, they're skinny though. I had 4 of them and gave them away years ago....probably not so smart when I think back on it....
__________________
Jim Forbes
my shtuff
Old 01-01-2008, 12:56 PM   #8
fiveofeen
Grenade Inspector
fiveofeen's Avatar
GM is starting to deliver full size trucks with steel wheels that will be simply disposed of upon delivery to the dealer soon. The reason is these trucks will receive upgraded wheel and tire packages at the dealer level. Currently they have no plans to send the steelies back, they will be disposed of... although I'm sure some enterprising souls at the dealerships will make a few bucks off them. Not sure what they look like but they will be arriving soon.
Old 01-01-2008, 03:49 PM   #9
rusty48
rusty48's Avatar
I think any chevy or GMC 4X4 after 88 will work.
Old 01-01-2008, 06:45 PM   #10
Old School HAMBer
squirrel's Avatar
Lotsa negative offset on many of the late model wheels, they're usually 7" wide and use larger studs too.
__________________
Jim Forbes
my shtuff
Old 01-01-2008, 06:57 PM   #11
patrick2965
Senior Member
patrick2965's Avatar
Quote:
Exactly correct. To add to that problem, the countersink in the wheel has a different angle than the standard earlier lugnut. Too much backspacing, no provisions for the two bags to hide the ugliness.
But like the other guy said, our 60's Chevy trucks are off topic here. I've had one for 22 years and 300k miles.
__________________
Custom and performance driveshafts built here. Axiline equipment, quality concious builders.
For most folks, common sense really IS rocket science.
Old 01-01-2008, 07:06 PM   #12
Squablow
Old School HAMBer
Squablow's Avatar
I have one of the ones that Squirrel is talking about. Looks just like the 60's factory 15" 6 lug but it's 16". I think they may have been availible as an option after 55 as well, but I could be wrong. Those would be just the ticket if you could find enough to make a set.
Old 01-01-2008, 07:12 PM   #13
Old School HAMBer
squirrel's Avatar
I think you could get 16" wheels on Chevy half tons for a long time.
also the pre 49 cars used 16" 6 lug wheels
__________________
Jim Forbes
my shtuff
Old 01-01-2008, 07:43 PM   #14
pan-dragger
Old School HAMBer
pan-dragger's Avatar
the late model gm stuff, 88 and newer will not fit the center hub diameter is to small. nothing a machine shop can't help you with. keep in mind the offset difference, the late stuff with a positive offset might hit the tie rod. also some of the later model import truck wheels will fit, but most are styled steel wheels and would probably just look like shit on your truck anyway. there are plenty of companies that can build a steel wheel for you.
__________________
r.i.p. pops
wanted- 671 blower
Old 01-01-2008, 08:10 PM   #15
Squablow
Old School HAMBer
Squablow's Avatar
I've got a bunch of the pre-49 16" 6 lug wheels, but they're really skinny. I bet Wheelkid could take the centers out of some of those early 16" six lugs and weld them into a set of wider hoops to make any width and offset you could want.
Old 01-01-2008, 08:45 PM   #16
1oldtimer
Old School HAMBer
1oldtimer's Avatar
up to the mid 80's (i think) the steel wheels were 15" on the 4x4's, i have a set for my '64 panel they are 3 1/2" offset instead of 4" for the stock 60's p/u wheels.
__________________
#1 Post killer
Old 01-04-2008, 12:53 PM   #17
~X~
FNG
~X~'s Avatar
Heres a pic of a "16 - 6 lug. Ya, its skinny. I think I saved about six of these over the years. All had tubes. Should be a correct fit if you can find some.
__________________
"When I read about the evils of drinking, I had to give up reading."
http://www.caddy500.com/
Old 01-04-2008, 01:27 PM   #18
Big Dirty
Big Dirty's Avatar
My '54 has these hideous 16's on it!!!!! I'm working like mad on trying to get a proper wheel and tire combo on it but I guess there a good example as to what will fit for you. I think there early 80's blazer but I'm not positive....
Dirty
Click image for larger version
__________________
"They took...THE BAR...The whole frickin bar!!!!"
Old 01-04-2008, 01:38 PM   #19
Dan10
Grenade Inspector
My 2002 2500 HD came with aluminum 16" six lug wheels new from the dealer. Offset is not too bad, and the center is at least 3 inches.
Old 01-04-2008, 01:43 PM   #20
elcornus
elcornus's Avatar
Have you tried Early Wheel Co.?
http://www.earlywheel.com/
__________________
Just another broken down old moldmaker,
carving away at Bear Metal Kustoms
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
