Reply
Thread Tools Display Modes
Old 12-28-2007, 10:56 AM   #1
Dakota
Senior Member
Dakota's Avatar
Default Granada Spindle Conversion, 57-8 Ford disc brakes
What years of these cars donate the spindles? i wanna put disc brakes on the Edsel and i read all about this Granada conversion, but nowhere can i find specific years/models that donate them.
if i read right these make a 1-1.5 in drop too right?
if you have a parts list oor a list of what years and models donate the parts let me know.
Thanks
Aaron
__________________
www.suedescarclub.com
"besides, anything north of blaine is kanukistani territory" <--- FiddyFour
offline   Reply With Quote
Old 12-28-2007, 11:10 AM   #2
blacktopbuddha
Alliance Member
blacktopbuddha's Avatar
Default Re: Granada Spindle Conversion, 57-8 Ford disc brakes
75 to 80 for the Granada and Mercury Monarch I think it was called. You will need to ream out the hole for the lower ball joint too. Not sure of exact specs. If you can find a pair of spindles from a Lincoln Versailles, they should bolt right on. Found a few sites on the web for this. Hope none of the mods mind me posting links to other sites.
http://www.mustangsteve.com/granadadiscs.html
http://users.ipns.com/rlewis/disc.htm
online   Reply With Quote
Old 12-28-2007, 11:30 AM   #3
Malcolm
Alliance Member
Malcolm's Avatar
The pair I used were from a '79 Lincoln Versailles and were the same as the Granada/Monarch. -- needed to be reamed.
The rest of the parts - rotors, calipers, bearings, seals, and master cylinder are all readily available.
Try http://www.rockauto.com/
Malcolm
Old 12-28-2007, 12:28 PM   #4
sko_ford
Old School HAMBer
sko_ford's Avatar
for my 64 i have the parts to do it with 73-79 big t-bird. bigger rotors and calipers than the granada and shou;d still dropit 1.5"
__________________
Little Pages Tech Group
thee suedes
Occupy a Hurst shifter
Quote:
Originally Posted by thunderbirdesq View Post
Grind until bitchin
Old 12-28-2007, 03:03 PM   #5
Dakota
Senior Member
Dakota's Avatar
I read that the tbird stuff screws up the ackerman and other geometry...
__________________
Old 12-28-2007, 04:15 PM   #6
Mark T
Mark T's Avatar
Blacktopbuddha listed the correct years above for the spindles.
If you want your Granada spindles to drop the front of your car you should only ream the lower ball joint hole enough so that the spindle sits high on the lower ball joint stud. If the lower hole is reamed larger the car will sit higher. A local machine shop charged me $40. to do the spindles for my '55 Ford.
A company called Drop-n-stop sells this exact setup for '54-'64 Fords.
PM me if you would like to see some pictures of my spindles before I installed them or if you have any questions.
Mark
Old 12-28-2007, 08:52 PM   #7
TP
Senior Member
TP's Avatar
All ther information is correct. I put the spindles on my old 57 ranchero. Dropped it 1.5"-2". It takes a #7 reamer. Use a 67 mustang master cylinder for a disc/drum. You will be able to use the top two bolts that are on the firewall and drill the bottom two. I did not even have to modify the pushrod. I did not go power brakes and used no porportioning valve. It stopped great. TP
Old 12-28-2007, 09:05 PM   #8
Paul2748
Senior Member
Paul2748's Avatar
You can also use the Granada/Monarch master cylinder. Direct bolt in. They have both a power and non-power version. I went with non-power, stops fine. When you get the parts off the donor car, get the combination valve. Mark what holes go to what before taking off.
__________________
flathead or ovhd- fords only
Old 12-28-2007, 09:16 PM   #9
stepchild
stepchild's Avatar
i believe maverick disc brake spindles are the same as granada
Old 01-02-2010, 03:24 PM   #10
Low58Corsair
FNG
not to bring this out of the dead but I'm looking at this granada swap for my 58 corsair which is based off the larger Mercury frame and I had a couple questions.
my car has power drum brakes & was wondering if anyone has advice as far as making it all work with power assist?
only the lower ball joint hole needs to be reamed? the other 2 are correct?
what about a prop valve? the wheel cylinders are 1/32" difference in size from the granada to the corsair, would that pose a major problem?
Old 01-02-2010, 03:47 PM   #11
exStreamliner
Senior Member
exStreamliner's Avatar
I have the Granada wagon set-up on mine and a full station wagon coil was cut out too... handled great at high speeds and in the curves... stopped straight at over a hundred... and, you can retain the 14" rims... 40K miles in five years and no negatives - but I can stamp stupid on my forhead for dismantling it for paint and donating the motor to to my 27
Old 01-02-2010, 04:06 PM   #12
Low58Corsair
FNG
Quote:
Lol I think kicking yourself for projects past is part of the deal. what kind of wagon was it?
Old 01-02-2010, 05:08 PM   #13
enjoyn
FNG
Arron give me a call in Center. Kenny
a
Old 01-02-2010, 06:07 PM   #14
exStreamliner
Senior Member
Quote:
Oh... I'm only semi stupid... I still have a couple of stock 312's and the 57 County Sedan... just the one I pulled out was 375 HP that moved the 4,300 lb brick pretty good... that's how I can say the breaks worked great... the were properly tested!
Old 01-02-2010, 06:17 PM   #15
Low58Corsair
FNG
what master cylinder did you use with those brakes? stock rear brakes? brake booster or no? prop valve?
Old 01-02-2010, 06:47 PM   #16
Crazy Backyard Builder
Senior Member
Crazy Backyard Builder's Avatar
Quote:
I am told you can use the big body '69 galaxie spindles and larger disc brakes. But they use 15" wheels.
I think you still need to ream these spindles too.
CBB
__________________
Wanted
Early '20's Willys touring parts
Dr. door, cast brace for locating the pass. windshield post
Old 09-02-2010, 10:08 PM   #17
BBF57
FNG
do you have the name and spec on that reamer? whats the taper angle? the one i found says a 1/4 inch afoot. which does not match the 57's balljoint
Old 09-02-2010, 11:25 PM   #18
Verminator
Verminator's Avatar
I used 69 Mark III loaded spindles on my 57 Custom 300 Direct bolt on -needed to use 15'' rims. Same as galaxie 70-72 era
Old 09-02-2010, 11:49 PM   #19
Senior Member
Quote:
Thanks for the info, I still have not tried the Galaxie spindles on my 57. This make me want to go out and tear in to the front end.
CBB
__________________
Wanted
Old 09-03-2010, 10:45 AM   #20
hotrod428
Newbie
hotrod428's Avatar
all of these spindle swaps will screw up your geometry, ackerman unless the doner has the exact track and wheelbase as your car. my conversions use the stock spindles and does not change the geometry.
__________________
http://hotrodsandbrakes.com/
Disc brake conversions for Studebaker Ford Mercury Edsel Thunderbird
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
