Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 11-30-2007, 03:05 AM   #1
mikhett
mikhett's Avatar
Default Secret to drilling out spotwelds!
Whats the best way to drill out spotwelds& what are the best drill bits to use? Thanks
offline   Reply With Quote
Old 11-30-2007, 03:21 AM   #2
DocWatson
Alliance Member
DocWatson's Avatar
Default Re: Secret to drilling out spotwelds!
You can get a drill bit from most auto shops that is made for drilling out spot welds. They havd a flat cutting surface with a 'point' in the centre, line this up with the centre of the tack and drill down untill you have gone through the first layer of steel. Then use a steel chisel, place it between the tack welded parts and gently tap them appart with a hammer.
I can take a rad support off a car in about half an hour like this.
__________________
N A I L H E A D
"With great power comes great responsibility"
'Your honor, can we take Wanda the fuck home....'
Old 11-30-2007, 03:22 AM   #3
DocWatson
Alliance Member
DocWatson's Avatar
PS, DONT drill completely through both sheets of steel that are tacked together!
And there called Cobalt bits the ones I am refering to.
__________________
N A I L H E A D
Old 11-30-2007, 03:33 AM   #4
Mercmad
Senior Member
There are several purpose made tools for spot weld drilling.I use a Sykes- Pickavant "Zip cut spot weld remover #04001100."
when you are unpicking panels you need a good tool to keep going and not be held up with breakages etc . This little thing is perfect.
http://www.sptools.co.uk/catalogue
Old 11-30-2007, 06:29 AM   #5
chopolds
Old School HAMBer
chopolds's Avatar
Mike, I've got 2 kinds at the shop, the "mini-holesaw" type, and the solid carbide type. The solid one works better in most applications, though not all. Won't break as easily, either. Got it at Eastwood, but I'm sure you can find it cheaper elsewhere.
__________________
Finished The Kart
Researching the new "secret" project!
www.kopperkart.com
www.customsbyflash.com
Old 11-30-2007, 08:09 AM   #6
Old School HAMBer
squirrel's Avatar
i only have the mini holesaw type, and a very old arbor for it...but I discovered that drilling a 3/32" hole first will keep it centered
__________________
Jim Forbes
my shtuff
Old 11-30-2007, 08:39 AM   #7
hibbyjr53
Alliance Member
hibbyjr53's Avatar
I like to use the Blair spot weld bit. It's a mini "hole saw" style cutter, but has a spring loaded locating pin in the center. Both the saw and pin are replaceable.
I center-punch the spot weld first to locate it.
They are available at any body shop jobber.
__________________
I'm gonna stay young...if I don't die first
Old 11-30-2007, 08:41 AM   #8
Old School HAMBer
squirrel's Avatar
The one I have has that same spring loaded center pin, but it is hard to keep it centered with just a center punch dimple...it'll take off when the blade grabs on one side, and break the blade....drilling a little hole first seems to work a lot better.
__________________
Jim Forbes
my shtuff
Old 11-30-2007, 08:43 AM   #9
hibbyjr53
Alliance Member
hibbyjr53's Avatar
I'll have to try that.
Thanks for the tip
__________________
Old 11-30-2007, 08:53 AM   #10
mikhett
mikhett's Avatar
Thanks guys. Drilling out sws ranks right up there with removing undercoating!
Old 11-30-2007, 08:58 AM   #11
Nick
Grenade Inspector
This type of bit is the best, its kid of a brad point drill bit for metal. They work great for anything I have ever done. I dont think this is the one that I have but looks the same.
http://www.autobarn.net/xxxw-dfxdf1480.html
__________________
www.sacredpiston.com
Old 11-30-2007, 09:09 AM   #12
Katula
Grenade Inspector
Katula's Avatar
spot weld kits, but you don't bore thru the metal, you just drill until the spot weld pops.
Old 11-30-2007, 09:16 AM   #13
codyn
FNG
Northern tool sells em too.
Old 11-30-2007, 09:32 AM   #14
Cadzook
Newbie
If you have trouble finding all of the spot welds lightly run a disc sander over the area (most likely a flange), the spot welds will show up quickly. Have fun.
Alden
Old 11-30-2007, 09:47 AM   #15
19Fordy
Senior Member
19Fordy's Avatar
Grind the point on a HSS drill bit to make it look more like a spade bit and rill only thru the top layer. You'll need a grinding wheel with sharp edges.
Old 11-30-2007, 10:04 AM   #16
19Fordy
Senior Member
19Fordy's Avatar
Using a grinding wheel with sharp edges grind the point of a HSS drill bit to look like a brad point drill. When drilling I found it quicker to first drill out the center of the spot weld with a small center drill. Then I used my home made bit. Hope this photo helps. Click on it to make bigger.
Click image for larger version
Name:	DSC02094 (Medium).JPG
ID:	382951   Click image for larger version
Name:	DSC02093 (Medium).JPG
Old 11-30-2007, 10:07 AM   #17
Old School HAMBer
squirrel's Avatar
That looks like a good way to to it, and cheap too if you have some old drill bits laying around. Nice suggestion!
__________________
Jim Forbes
my shtuff
Old 11-30-2007, 10:08 AM   #18
Terraizer
Alliance Member
I also use the blair spot weld cutters but the larger heavy duty version, and i pre drill with a 1/8" bit to center them, works great and very little breakage.
Old 11-30-2007, 10:40 AM   #19
Wisenheimer
Grenade Inspector
Wisenheimer's Avatar
Spot Welds !! .... I once drilled out close to 100 or so factory spot welds on the front of a 69 factory 440 Cuda which was eventually restored and featured in Muscle Car Digest. I simply used a center punch on the top of the spot weld and then using a regular drill and a new drill bit the same diameter of the spot weld and just drilled out the weld just enough to break through the top panel.... then using a regular old metal putty knife I just placed it under and tapped it up to break away the two panels.. worked like a charm. once the panel itself was removed it was just a matter of using the hand grinder to dress down the bit of spot weld on the under panel... very simple and no special tools. Note that even though a factory spot weld looks to be good 50% of the time the weld under neath had very little penetration... mass produced factory quality.
Old 11-30-2007, 10:44 AM   #20
Old School HAMBer
squirrel's Avatar
Quote:
Originally Posted by Wisenheimer View Post
Note that even though a factory spot weld looks to be a good 50% of the time the weld under neath had very little penetration... mass produced factory quality.
yeah, mopars are like that, but chevys had damn good welds!
(except for my 57 suburban that had half the firewall spot welds break)
__________________
Jim Forbes
my shtuff
Old 11-30-2007, 11:22 AM   #21
Wisenheimer
Grenade Inspector
Ouch! I took that one on the chin.
Old 11-30-2007, 12:03 PM   #22
earl schieb
Senior Member
earl schieb's Avatar
Quote:
No offense to DocWatson, but.....
If you have easy welding access to the back side of the pieces you're separating, it's about as easy to drill thru both pieces---then you have a hole already in the right place to plug weld.
Not always applicable, but it saves panel alignment and drill time when it is.
__________________
I'll paint your car GOOD, FAST and CHEAP!(pick any two)
Old 11-30-2007, 08:20 PM   #23
pimpin paint
Old School HAMBer
Hey,
Another method of locating spot welds to be drilled out is to take
a torch and a wire brush (don't tell me I need to tell you to ware
eye protection) and burn off the paint covering the spot weld.
The hole saw type drill bits are available from auto body supply
outlets, but if you have a shit load of spot welds to drill, center
punch the weld, than take a sharp 1/4 or 3/8, depending on the
size of the weld, bit and drill through the top layer and well into
the bottom layer. Now would be a good time to teach yourself
how to grind drill bits properly. It will save ya a good bit of money
and grief!
Happy Xmas
Happy Whatever
Old 11-30-2007, 08:44 PM   #24
50dodge4x4
Senior Member
Squirrel, must not have had much experence with the 70s and newer Chevy pickups. A bunch of the spot welds on those were not real good. Actually, I've replaced a lot of floor pans and suspension structures on all brands of cars and trucks, foreign and domistic. My guess is probably 25% of the spot welds from the late 60s and newer cars of nearly all brands have little to no penatration. Seems the older stuff was better welded. The 90s and up stuff have really crappy welds and very poor pannel fit, but most of it is covered with that putty/seam sealer they love to load on there. BTW, I use a 5/16 regular drill bit for spot welds. Gene
Old 11-30-2007, 09:28 PM   #25
Wisenheimer
Grenade Inspector
I guess I was being generous when I said 50 % of factory spot welds had good penetration.
Old 11-30-2007, 09:53 PM   #26
DocWatson
Alliance Member
DocWatson's Avatar
No offence taken! You raise a good point that I didnt think off. We had a spot welder so needed the steel to be there, if your just doing it with a mig (Etc..) yes you will need to drill through to plug weld.....
__________________
N A I L H E A D
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
