Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 12-05-2007, 10:38 AM   #21
Hellfish
Old School HAMBer
Hellfish's Avatar
Default Re: 63 Econoline lowering...Help!
Was it a white, chopped van? There was a guy from KY or TN at the Cinematic with one. He said it rode like utter crap and was scary on the highway. In fact, the first thing he did when he got to the show was change the wheels to smaller ones so he could steer. I forget how he lowered the front (i took pics underneath), but he c-notched the frame and added a huge hump in the bed to lower the rear
__________________
http://www.chromeczars.com
http://www.hunnertcarpileup.com
Metalflake: The new flat black
offline   Reply With Quote
Old 12-05-2007, 10:52 AM   #22
meatball
Old School HAMBer
meatball's Avatar
Quote:
Originally Posted by Hellfish View Post
Why would you buy and old straight axle van and put in IFS? That's like buying a Model A and putting in a LT1, A/C, air bags, IFS, etc. Anyway, these things have FRONT steering and not much room in the wheel wells up front, so I'm not sure it would work without serious fabrication... and then you still wouldn't be able to turn.
Keep in mind that, while there is more room in the rear wheel wells, the frame goes STRAIGHT across, so any lowering in the rear will require c-notching the frame (and bed) or your rear end will be smacking the frame on every bump
yeah I agree.he was asking about low not style...I'll never take the axle out from under my A-100
Click image for larger version
Name:	kents 65 dodge A100.jpg
__________________
Be nice to strangers.......They may sit on your jury!
Old 12-05-2007, 10:58 AM   #23
Hellfish
Old School HAMBer
Hellfish's Avatar
I love those Dodge's, too.
Here's the chopped/lowered van from the Cinematic that I mentioned
__________________
Old 12-05-2007, 11:06 AM   #24
meatball
Old School HAMBer
meatball's Avatar
my favorite A 100
Name:	1964 dodge van.jpg
__________________
Old 12-05-2007, 11:15 AM   #25
novatattoo
Alliance Member
novatattoo's Avatar
Yeah that was an early ford. I got no pics or info on it but it was different. I had an early chevy a couple years ago. Decided to go w the 70s surf theme instead. Lowering looked like a hassle.
But there a blast to drive! The looks you get are priceless.
later,Bill
__________________
FOR SALE 37 Ford pickup http://www.jalopyjournal.com/forum/s...d.php?t=505507
Buick switch pitch trans $250
Old 12-05-2007, 11:40 AM   #26
ray
Old School HAMBer
ray's Avatar
nice lookin van, nice chop too.
but damn, it ain't even low!
while working on mine, i had it sitting on the brake drums to reach the roof for paintwork, that's about how high it sat off the ground. i did a little measuring while it was like that, up front you could get tires to fit pretty easy, even tucked up high in the wheelwells, provided you ran as much backspacing as possible, or got in there and cut out those humps that are towards the outside of the wheelwells.
Old 12-05-2007, 09:50 PM   #27
55 dude
Old School HAMBer
55 dude's Avatar
my 65' runs great and stopping sucks! in the past i helped a guy try and lower his and after messing with it for way longer than we should have ended up getting another front end to replace the one we fucked up! tire rub is a major issue and if you attempt to raise the wheelwells you will not be happy with the results.
Old 12-06-2007, 10:42 AM   #28
WhoDoYouFink
Alliance Member
WhoDoYouFink's Avatar
Hellfish, I think that was it. The wheels look the same, but it was primed flat black at the pumpkin run.
__________________
I may not be good, but I sure am slow!
Old 12-07-2007, 11:44 AM   #29
rev106
rev106's Avatar
http://autos.groups.yahoo.com/group/...t=windows-1252
Try these yahoo group threads on lowering....
__________________
We are men of action, lies do not become us.
Old 12-07-2007, 12:32 PM   #30
Hellfish
Old School HAMBer
Hellfish's Avatar
that's where a lot of the info posted here came from
__________________
Old 12-08-2007, 06:36 AM   #31
nmbuellist
Grenade Inspector
nmbuellist's Avatar
When I last built my econoline(1992) I was more concerned about driveability. I was living in the mountains and using it for a work truck. lots of fast mountain roads. I lowered the whole drivetrain ( 302 and c-6) 3 inches. This really helped the center of gravity, made the old truck go around corners good. The headers are so low that I have overloaded the truck and it was dragging the headers.
When overloaded it would lower the whole truck evenly on all 4 corners, and the front tires would touch in a tight turn.
Old 12-17-2007, 09:25 PM   #32
erock805
Alliance Member
erock805's Avatar
I have just lowered my 61. First I static dropped with with a MAS axle and flipped the rear springs. I went with a 5 inch dropped axle, narrowed an inch on each side. This is super important as it helps your tire rub issue on the small inner fender. Which btw would be best to be popped in or cutt out. I can say that I would recommend a MAS axle. Its very beefy and fit as it should.
The truck looked great but was not very drivable unless your a hard ass, or you lift it up a bit. Also, before I started I measured with re arched springs that had settled for 6 months. If I were to keep the static drop I would have to have raised the front up at least an inch and stiffened it up quit a bit.
Heres the issues you will run into.
Steering, we had to cutt and reshape the steering arm. Some tire clearance, I used a 26 inch tall tire and rim but its a skinny drag wheel.
We had only four inches of travel before the axle would bounce of the shift arms. (3 spd). Maybe 5 inches to the oil pan and the bottom radiator hose.
By flipping the axle over the spring in the back, ud have to beef up the spring. It bottomed out to easily...I only had 3 to 4 inches of travel before it bounce off the pumpkin.
My friend at LOWBOY in Mesa put two four links in it and bagged it with full heim joint steering. We are working all the buggs out of it as we speak. I will say that sway bars are a must.
I will put out a bunch a pix and a tech article about the whole thing once I get it cleaned up. You can see pics of it static dropped in one of the web sites in my signature.
__________________
Get ur bitchass in the kitchen and cook me some pie!
http://www.myspace.com/erock805
http://www.myrideisme.com/Garage/erock805
Always looking for Econoline parts, spindles, steering boxes other....
Old 12-17-2007, 09:26 PM   #33
erock805
Alliance Member
erock805's Avatar
BTW....Its lower than that now.
__________________
Old 12-07-2008, 09:03 AM   #34
Gas Huffer
Grenade Inspector
Gas Huffer's Avatar
Here's a thought, but since I've never been underneath one of these, I might be talking completely out of my ass...
What's preventing a person from doing a body drop on one of these? It seems like it would be the easiest way to drop one and PLUS, you would still maintain the original steering geometery, wheelwell clearance, etc.
It just seems like going through the trouble of completely redoing the suspension/undercarrage would be a lot more work than is neccessary just to lower one of these. But if it were truly that simple, I'm sure this would be the most obvious way to lower one. Someone who knows better than me, please feel free to school me.
__________________
God bless America...
Except Idaho
Fuck Idaho
Old 12-07-2008, 09:23 AM   #35
thunderbirdesq
Old School HAMBer
thunderbirdesq's Avatar
They're unibody construction, the frame is the floor...
__________________
Full Throttle Rock and Roll!
www.kohlerkustom.com ~TWICE PIPES C.C.~
online   Reply With Quote
Old 12-07-2008, 09:37 AM   #36
mr57
Senior Member
mr57's Avatar
What about a frame donor?? Lots of work, but something like a Safari van frame might work?? Steering should be in the right place, and setting back the engine shouldn't be a big deal. Not sure about the track width either but this might be an option.
Old 12-07-2008, 10:01 AM   #37
AcadianKid
Grenade Inspector
AcadianKid's Avatar
I found this. Dont know if it helps. I do know there was lots if work involved.
http://www.shadoworksart.com/doorway.htm
Click on "The Artist" and then click "here" on his biggest project yet, it's toward the top, before the ink pics.
__________________
Need: 53 & 54 Chev Taillights
Old 12-07-2008, 12:00 PM   #38
novatattoo
Alliance Member
novatattoo's Avatar
Cory, Yes this van will be bad ass. Later,Bill
__________________
Old 12-07-2008, 12:21 PM   #39
LiveWire64
Newbie
LiveWire64's Avatar
http://www.showtrux.com/showvans/ear...adowbefore.htmShadows Econo is sweet. I do believe it's finished. Painted anyways.
Old 12-07-2008, 12:40 PM   #40
ray
Old School HAMBer
ray's Avatar
naturally, i ended up lowering mine.
__________________
suck squeeze bang blow.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
