Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Administrator
I still can't stop thinking about my time at the Tardel Ranch. Every now and then, a light will flip on and I'll remember some little tid bit that Vern or Keith taught me. This one is basic a... To read the rest of this blog entry from The Jalopy Journal, click here. |
#2 |
Alliance Member
THANKS RYAN!! as a new comer to the flathead scene i still have many questions! and that was one of them-thats why i love the HAMB
#3 |
FNG
Sweet! Another thing to put in my flathead notebook! Thank You!
__________________
"Beware of well meaning but uninformed friends." Magneto349 |
#4 |
Grenade Inspector
I never knew that. Thanks for sharing. Now I'm going to always clance at the center studs when I see a flathead engine.
#5 |
Senior Member
i always thought it was the waterneck location that gave them away...?
__________________
Mundus vult decipi, ergo decipiatur |
#6 |
Senior Member
Thanks for clarifying.
#7 |
Alliance Member
They came both ways on 21's...
Probable reason for change: 21 had a stud directly below centers of bores, and boring to 3 3/16 left only a scary amount of iron between stud and bore. I think they changed the tooling in preparation for the intro of the bigger bore engines to keep tooling as common as possible between 221 and 239.
__________________
Bruce |
#8 |
Hey Ryan that is just great info.Just two days ago I was looking at a flat head and counting the studs.It will be easy now Thanks!
__________________
Hot rods are driven!! 32 ford (hemi power),28 roadster (flathead power) |
#9 |
Old School HAMBer
32-36 21s had water pumps in the heads.
37-38 21s had water pumps in front of block like 38-53 24s. That stud line is a great tip to identify the stud count. Thansk for the tip. |
#10 |
Old School HAMBer
21 stud/bolt hard to find speed parts and very expensive (Arm &Leg ) Were the 24 stud/bolt speed goodies are abundant and in a reasonable price range. The 24's also offer a much wider range of speed accessories.
__________________
Wanted 1932 Ford Roadster Parts doors cowl anything Please parts
#11 |
Senior Member
Awesome bit of info, if you remember other tricks let us know! i require tricks and tips.
thanks
__________________
C YA |
#12 |
Grenade Inspector
thats a good way to look to tell the difference. i always before just looked at the bottom of the head. 2 bolts below the bore=24stud, 1 bolt below bore=21 stud. but cool hey either way works!
__________________
If You're Not Dreaming, You're Not Living! |
#13 |
Newbie
Does it hold true a 21 stud head has 5 studs across bottom of head vs 8 on a 24 stud? xYz
#14 |
Old School HAMBer
. . . waterneck location that gave them away...?
No the 59A series (center) and the later 8BA series (front water neck) both have 24 studs (or bolt holes).
__________________
She's wearin' new colors and runnin' pretty good I got four hundred horses tucked under the hood. |
#15 |
#16 |
Alliance Member
Very interesting.
Just wanted to throw in another interesting flattie into the mix. This is an aircooled prototype that is in Speedy Bill's museum (that place is worthy of its own feature sometime). Thanks for the info Ryan.
__________________
—MRAK Keep Moving Forward — W.Disney |
#17 |
Senior Member
just more info for me to absorb. thanks for the write-up!
__________________
flickr I'm unemployed, read about my shenanigans here: http://newfoundfreetime.blogspot.com/ |
#18 |
I like that little trivia stuff!
#19 |
Good Stuff.......
#20 | |
Alliance Vendor
Quote:
If there was a market that could support this type of 21 stud venture, I'd continue with it. Tooling alone is close to $11.5 K up front. Then you still gotta get the casting done,and machine em up. Are HAMBers game to buy if I were to take this chance. They'd be in the same price range as the Flatty Caddy's. If you need em. Let see what we can make?
__________________
All Roads Lead to the Broiler! |
| Thread Tools | |
| Display Modes | |
