Tech: Molding In Fenders On Your Custom Tech - Another way to fit 39-48 brakes to 28-36 Fords TECH: Translucent steering wheel how to Tech: Firewalling my F-1 TECH: Merc headlight frenching. TECH. Radiator crossover pipe TECH - Small Budget Engine "Rebuild" Studebaker tech. Shock Mounts for Older Mopars- Tech Nother Make your own WWW post TECH COMPILATION: Merc 101 (lowering blocks) Tech: How to drop a tie rod. tech. 37-57 BOP suspension/brake upgrade Tech: Homemade Lincolngears TECH: First welding project- a welding cart (!) Tech: How to safety wire TECH: Making A Grill Shell Tech - Removing Stuck Banger Head, Inliner Head or Flathead Head Tech (?) Rusty Slot Head Screws Easy tech, polishing speedo faces. Narrowing aluminum 5 spokes. Making your own garage art $50 rolling toolbox Keeping the inside of your engine clean Discreet turn signal switch Easy Header Baffles Sandblasting Tech TECH: sunken e brake handle Flathead fuel pump tech 9" Guts in Olds Housing Scallops on a budget tech making AC vents Tailgate Latch Idea Restoring Aluminum Valve Covers Tri-Power How-To Camaro Clip in your 58 Chevy in One Day MONSTER TECH GRP Cowl Vent
Can you add this one, if it's worthy? http://www.jalopyjournal.com/forum/showthread.php?t=214063 Feel free to clean it up to only include the tech, and not the chatter and kudos that followed. Eric
Paul sorry I wasn't on top of it this time, I'm working away from the computer during the days this week....
