updated pictures of our latest 32 project
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, Oct 12, 2007.
  1. hot rod pro
    hot rod pro
    from spring tx.
    here at the shop we have been head down and tail up on projects.we have finally gotten the body on the chassis.we like it hope ya'll do too.
    -danny
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    :) ...'at are purdy...who's is it?
    kidcampbell71 likes this.
  3. hot rod pro
    hot rod pro
    from spring tx.
    his name is travis,and he is a good friend of the customer i built these two cars for.glad you like it.
    -danny
  4. hot rod pro
    hot rod pro
    from spring tx.
    here is some more.hope ya'll like.
    -danny
  5. myke
    myke
    from SoCal
    Wow, nice work!...as always
  6. Awesome details. I especially like the fuelpump/lines and the rear swaybar,and the ladder bars, and,and.....
  7. Preacher
    Preacher
    Love the subtle motor mounts and the removable tranny cross member.
    Very clean work, but always expect that with your guys stuff.
  8. 8flat
    8flat
    A rear sway bar? Damn that's cool. Great work...
  9. manicmechanic
    manicmechanic
    Looking good Danny...:) You going to Boerne?
  10. rustymetal
    rustymetal
    hi danny nice work what year is your transmission.
    thanks
  11. hot rod pro
    hot rod pro
    from spring tx.
    no.got to stay and work.if i stay and work it gets dad out of the shop.:D
    bills stink,never grow up.
    -danny
  12. hot rod pro
    hot rod pro
    from spring tx.
    the transmission is a brand new tremac tko-600 5-speed.hope that helps.
    -danny
  13. hot rod pro
    hot rod pro
    from spring tx.
    yes a rear swaybar,i put them on all my chassis.i have found that no matter what body style you use,it will help in the handling,and putting the power to the ground.
    glad you like it.
    -danny
  14. jusjunk
    jusjunk
    from Michigan
    how bout some more pics of the roadster ????????
    Dave
  15. 8flat
    8flat
    Are you adding one to the front also?
  16. MIKE-3137
    MIKE-3137
    Wow, Danny..as usual !
    If I ever hit the big time i'd want you guys building mine.
  17. hot rod pro
    hot rod pro
    from spring tx.
    i have see them before,but i have never used them on the front.it is soo hard to make them look good stuck out in the open.on chassis that have independant front and rear,i use front and rear sway bars.most of the time they have fenders to cover them up.on 35-48 they are a must,front and rear.
    -danny
  18. hot rod pro
    hot rod pro
    from spring tx.
    i didn't know what you wanted to see so i picked random pictures to post.
    here are some of another roadster we built.
    -danny
  19. Deuce Roadster
    Deuce Roadster
    Nice work !!
    A question please ... and I am NOT being critical.
    Why the cutout of the frame ??
    The engine does not look to be all that forward. Is the frame narrowed ??
    The radiator holes look a little close the rails :D
    Excellent job on the cutout ... just wondering what caused it ... :)
    Mine is close ... but has about 3/8ths of a inch clearance .... without a cutout.
  20. Roadsir
    Roadsir
    Really nice work.
    Regarding the fuel pump, it could be the aluminum block moving the fuel pump out?
  21. hot rod pro
    hot rod pro
    from spring tx.
    the frame is pinched 5/8" per side at the front crossmember,to remove the gap between the grill shell and the frame horns.
    the aluminum block has nothing to do with the location of the pump.
    -danny
  22. EarPunch
    EarPunch
    from Conroe, Tx
    Looking great Danny! Your craftsmanship is 2nd to none in my book.
  23. Doc.
    Doc.
    Beautiful work. You can build for me anytime.
    Doc.
  24. hot rod pro
    hot rod pro
    from spring tx.
    thanks guys.your nice words mean alot.
    doc,let me know when you want to start.:D
    -danny
  25. Brad S.
    Brad S.
    Man as always those look good.
    When will you have that one out and about with the other two? Taking it Niftees tonight? :D
  26. stude_trucks
    stude_trucks
    wow!, very nicely detailed and clean looking work. beautiful cars.
  27. hot rod pro
    hot rod pro
    from spring tx.
    i have about 3 weeks of work to do before i realisticly can drive it.as for tonite,i'm going to try to make it.don't know if i'll be in the sedan or roadster.
    glad you like the pictures.
    -danny
  28. hot rod pro
    hot rod pro
    from spring tx.
    thanks for the nice words.
    -danny
