Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
i'm trying to pull the dash panel on my '66 el camino. i apologize if this is the wrong forum for this, but.....
this is the top panel on the dash that all the switches are in. I unscrewed the bezels on the wipers, lights, and ignition, but the ignition bezel still seems to be held on by stainless disc (has one small hole in it) that is on the face where the key goes in. I'm assuming you can push something in hole and then it releases, but the first attempt or two didn't work and I figured I'd ask before I f'd something up. |
#2 |
Old School HAMBer
You have to put the key in and turn it. Use a paperclip in the hole and it will come apart.
#3 |
Senior Member
put your key in it and turn to acc, then insert a big paper clip and push,reaching up behind the dash and turn the switch
oh and did you get the headlight switch out? no need to wreck it if you didnt, little button on top of the switch hidden by the wireing ,pull out the knob and push in the button, it will release in case you didnt know about that have seen a few wrecked because nobody showed them |
#4 |
Grenade Inspector
unscrewed the bezel on the wiper and lights and those came right out, but the ignition.......
???so, put the key in and turn to ignition, then put paper clip in hole and reach behind and reach behind dash and turn the body of the switch??? unless i'm wrong, the whole of the steel dash has to come out, which is attached to the column by a bracket. this i've already unscrewed, but it seems counterintuitive to me. |
#5 |
Senior Member
ok maybe miy brain is too old, you either just put the ky in it compresse the tumblers and then you push in the clip, then you can rotate and remove,
i know on the 55 to 57 chevy's it is just insert the key and use the clip, no turn to accesories to the left, that opens a little hole in the face of the switch through the bezel hole, thne insert the clip or stiff wire, it depresses the insde spring holding a tab , turn the switch alittle to hold that kind off pinching the clip, then pull out the clip and turn the switch kind of monkey fuck but a little fiddling it will come off the bezel and you will justhave the switch, oh pull the key out also tkae a look into the bezel hole and you will see another hole line up when you turn the key to acc, Last edited by oldchevyseller; 10-10-2007 at 10:01 PM. |
#6 |
Old School HAMBer
stick the paper clip in the hole and turn the key counter clockwise it will unscrew
#7 |
Senior Member
insert key into the ignition and turn it to the “lock” position. Use a straightened paper clip or similar small stiff wire and push it into one of small the holes in the chrome bezel on the lock tumbler. Turn the ignition to the left (counterclockwise) until the lock tumbler ejects from the switch. there it is from the chevy shop manual ![]() ONCE YOU GET IT YOU WILL HAVE ATTAINED GENIUS ENGINEERING STATUS ON BEATING GM DESIGN, WELL AT LEAST ON ONE OF THIER MILLION CRAZY DESIGNS Last edited by oldchevyseller; 10-10-2007 at 10:14 PM. |
#8 |
Grenade Inspector
thanks guys, i'll give it a try
#10 |
Senior Member
this takes some trial and error, like was said put the key in turn to assy take the paper clip and push through the hole you should fell a spring loaded plunger play with it felling the resistence, when you have it depressed turn to the left and pull out the tumbler now you can remove the bezel. this is a aquired skill.
#11 |
Senior Member
Use a flattened ice pick or a blunt scribe instead of a paper clip so it doesn't slip off the brass pin.
#12 |
Senior Member
Don't know if your aware of the www.chevytalk.com web site. Any Chevy problem you have has occured before, all you need to do is ask a question and someone will answer it for you.
#13 |
Old School HAMBer
CONGRATLATIONS for asking before you tore anything up. Too many guys think all you need is a pair of vice-grips to remove the ignition. And a good heads up on the headlight switch. I don't know how many good switches were ruined because folks don't know about the little button.
__________________
Every knee will bow H.A.M.B. Chapel 322 Naihead and complete stick set-up for sale |
#14 |
Old School HAMBer
My question is how do you get them out without a key ?
#15 |
Senior Member
up until 1966 after that they went to the column key
have to have a key or you will end up ruining the lock set gm used a key that fit the door lock and ignition, pull out the door lock and there is a code on it,no code? still can cut a key just takes them a little longer to read the tumblers locksmith can cut a new key and then you will be ready to take the ignition out, glove box and trunk are a diferent key Last edited by oldchevyseller; 10-11-2007 at 01:40 PM. |
#16 |
Old School HAMBer
or just try all your old Chevy keys, wiggling gently, until you get the lock to turn....this works about half the time I try it!
| Thread Tools | |
| Display Modes | |
