Reply
Thread Tools Display Modes
Old 10-01-2007, 11:32 AM   #1
Frank
Senior Member
Frank's Avatar
Default Thinning Rustoleum? Mineral spirits ok?
I had read about the $50 paint jobs and thought I'd use the same method for my chassis. I bought the Rustoleum semi-gloss black. The can says to thin with "Acetone and not gasoline, paint thinner, laquer thinner and etc". Most of what I have read people have been using mineral spirits. Just wanted to question once more before I paint the exposed portion of my frame since I want it to look nicer. Hate to mix something that will never dry.
offline   Reply With Quote
Old 10-01-2007, 11:40 AM   #2
hoof
hoof's Avatar
Default Re: Thinning Rustoleum? Mineral spirits ok?
The can I am using says acetone or mineral spirits.
CHAZ
__________________
Oh, That's right, your brother has the car!
Old 10-01-2007, 11:43 AM   #3
Petejoe
Old School HAMBer
Petejoe's Avatar
Used mineral spirits to thin the rustoleum and paint the roof and fenders on my pickup.
Dried fine. Holding up well..
__________________
In my old age...
Grant me the senility to forget the people I never liked.....
the good fortune to run into the ones I do.....
and the eyesight to tell the difference.
Old 10-01-2007, 12:15 PM   #4
daddylama
daddylama's Avatar
i've only sprayed rustoleum, never the roll-on method...
for spray i used "fast drying" lacquer thinner multiple times with great results on cool days.... mineral spirits on warm days...
acetone once, didn't get good results (but hear it's the way to go with roll-on)
Old 10-01-2007, 12:19 PM   #5
RF
Senior Member
Rustoleum makes their own thinning agent, but if I'm not mistaken, it's just a dolled up can of X-brand thinner (mineral spirits) that costs twice as much. I've been trying to finish spraying a 60-ft gate/fence out back, and w/o thinning the paint (Hammertone) at least 4:1, it comes out too thick. I guess the difference between using acetone vs. mineral spirits depends on the "type" of Rustoleum you're using.
Old 10-01-2007, 12:30 PM   #6
leadsled01
Senior Member
I used mineral spirits to thin my rustoleum. Also used some "japan drier" just to make sure it hardened up alittle sooner. Rolled on fine.
__________________
sheep aren't really people?
Old 10-01-2007, 01:45 PM   #7
53sled
Old School HAMBer
53sled's Avatar
I did it, it takes a while to dry if it is cold out, otherwise went on real nice. I think it was thinned 15%.
__________________
If only the good die young. I'll be here when you're gone.
Old 10-01-2007, 02:04 PM   #8
Rusty
Old School HAMBer
Rusty's Avatar
Lets see some pics, ihave not seen it sense it left Steves
__________________
Dirtys Speed Shop
214 537-7423
Texas Nostalgia Nationals
Yello Belly Dragstrip - Grand Prairie, TX
www.texasnostalgianationals.com
Old 10-01-2007, 02:16 PM   #9
Big Pauly
Big Pauly's Avatar
I sprayed it thinned with acetone with great results. did a two tone 59 f100 with it.
__________________
I hate thieves
Old 10-01-2007, 04:37 PM   #10
noboD
Old School HAMBer
Frank it's been a while since I sprayed Rustolem, but I've sprayed it unthinned. I thingk like was suggested they recommend slight thinning, like 15%. The only trouble I've had sprying unthinned is it takes a long time to dry, keep the flys awayor you'll have to break off their legs.
__________________
Hot snot, NOW we're back in business!! Doc Hudson
Old 10-01-2007, 06:55 PM   #11
choprods
Alliance Vendor
choprods's Avatar
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
Ive used it with fast dry Laquer thinner....I realize its an oil base finish,But after a little stirring- it will thin it fine.
Then once sprayed ,it levels nicely and speeds the dry time by evaporating quicker than the mineral spirits...
It also does something for the hardness of the finish......I especially like the results with satin black for a parts coating.
__________________
Running in place, will never get you the results that running from a Lion will.....
Old 10-01-2007, 10:26 PM   #12
swade41
Old School HAMBer
swade41's Avatar
I used mineral spirits, I hope you checked out my thread about it to try and stay ahead of the bubbles...lol
Old 10-02-2007, 06:10 AM   #13
47 Tudor Guy
Grenade Inspector
47 Tudor Guy's Avatar
I did my chassis and floor pans - I thinnned with acetone. It sprayed just fine.
__________________
Mike
47 Ford Tudor
68 Dart GTS Pro Street GTS Registry #293
74 Dart Swinger
Old 10-02-2007, 06:40 AM   #14
Unclee
Senior Member
Unclee's Avatar
Anyone tried Zylene? Works really good with the Duplicolor Alkyde enamels, and I've spayed some flat black Rustoleum that came out a real nice semi-gloss. This stuff isn't as hot as lacquer thinner, but a lot hotter than Mineral spirits, good combination, and available at the home improvement store nearest you.
__________________
UNCLEE!!!!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
