Reply
Thread Tools Display Modes
Old 09-04-2007, 10:25 AM   #1
RacerRick
Old School HAMBer
RacerRick's Avatar
Default Best way to clean out a radiator while still in the car?
Anyone have any good ways to clean out a partially plugged radiator without removing it from the car?
My 49' is overheating on the highway suddenly. It was fine for a week, and then suddenly on the way to Mokan it started overheating.
Its running a little rich, timing is set to 36 degree total on the 262ci v6, and its using a V8 rad from a 74' Dodge dart, and an electric fan. I thought the thermostat went bad, so I removed the guts from it and its just acting as a restrictor. There are no leaks.
The water looks like rusty mud now, and I think its all from the block. I have flushed out the block with a garden hose now, but I think the crap has partially plugged the raditor.
I am thinking or trying a gallon of white vinegar in the cooling system for 15 minutes then draining. Anyone have any other solutions?
offline   Reply With Quote
Old 09-04-2007, 10:33 AM   #2
usedall9
usedall9's Avatar
Default Re: Best way to clean out a radiator while still in the car?
My local radiator shop hot tanked mine in about an Hour. I know thats not what you asked, but I figured I let you know. I thought they would have it for several days(it had a small leak also). And I did'nt want my car of the road that long since I drive it daily. But I was wrong. They had it back to me in a couple hours. and it was like $40.00. Call around...You might be supprised?
__________________
Looking For:Good or rebuildable Steering column/box for 61' F100, Galaxie, Thunderbird or Mustang bucket seats. 5 on 5 1/2, x 4-5" wide wheels. Other cool shit!!!
[Quote] 6duececaddy-And if that doesnt work, hide in the bushes at his work. Wait till he comes out, then kick him in the balls and run away in a zig-zag motion so he wont recognize you.
Old 09-04-2007, 10:34 AM   #3
Redneck Smooth
Senior Member
I've heard reverse flushing it gets a lot of crud out, but I don't really know jack about it. Someone enlighten us, I'm also gonna flush my rad/block this week when I replace a leaking water pump...
__________________
Looking for Cadillac 390 speed parts and intakes. PM me.
Old 09-04-2007, 11:11 AM   #4
Flatman
Senior Member
Flatman's Avatar
If you can block of the lower spouts, fill it with CLR and let it sit for a few days (probably should leave the cap off) That should take care of any rust, calcium scale, etc... If you can believe the commercials
Flatman
__________________
Some men are Baptists, others Catholics, my father was an Oldsmobile man.
Old 09-04-2007, 11:25 AM   #5
orange crush
Alliance Member
orange crush's Avatar
Prestone makes a heavy duty flush you might give it a try its worked fine for me.
__________________
Growing old, not up!
Old 09-04-2007, 11:28 AM   #6
Ole don
Alliance Member
Ole don's Avatar
Location: Southern Illinois half way between Benton and DuQuoin
Drain all the coolant, and fill with 100 % vinigar. Drive about an hour, drain and flush.
Old 09-04-2007, 02:07 PM   #7
safariknut
Old School HAMBer
I made an,"on the road" radiator repair once but the radiator had already been pulled.You might be able to do this in the car but I would take it out.
Where I was(upstate New York)wouldn't flush out the radiator due to EPA regs so I bought a gallon of Liquid Plum-r at the local hardware store,poured it in after sealing the openings and filled it nearly full with water.Let it set for about 3 hours(rotating it 90 degrees every 20 minutes),reverse flushed it with a garden hose several times and re-installed it in the car.Worked for almost a year before it started overheating again.This time I had it re-cored.
When you're 300 miles from home,you improvise.
__________________
"Adventure BEFORE Dementia!
http://www.pinheadlounge.com/elvago
Old 09-04-2007, 02:21 PM   #8
Speed King
Grenade Inspector
Speed King's Avatar
I've had them flushed at radiator shops with good results. A couple of the suggestions here sound good also.
Old 09-04-2007, 02:42 PM   #9
Von Rigg Fink
Old School HAMBer
Von Rigg Fink's Avatar
citric acid works wonders on copper radiators
__________________
Goldchainers CC S.E. Michigan Chapter
Charter Member
Some guys could fuck up free lunch.
Old 09-04-2007, 03:22 PM   #10
Road Runner
Senior Member
Road Runner's Avatar
Your hardware store has 1 gal. concrete cleaner containing diluted muriatic acid.
You can use it straight from the container and leave it in the radiator over night.
You will not believe the amount of sediment and scale build-up it removes on clogged radiators.
Pure muriatic acid would attack the soft metals, so be careful.
If done right, it leaves the treated metal shiney like new.
Vinegar or citric acids are OK, but they are not very strong acids, taking forever to work. Unless you get highly concentrated pure citric acid.
LCR is just too expensive compared to concrete cleaner.
__________________
On the road every day...
1948 Chevy Coupe - 261
1952 Chevy Truck - 235
online   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
