T5 Info
Discussion in 'The Hokey Ass Message Board' started by Flat Ernie, Jun 20, 2004.
  1. Flat Ernie
    Flat Ernie
    Tech Editor
    There's a great article in this month's Hemming's Muscle Cars about the T5. If there's enough interest, I might be persuaded to type it in (it's only a couple pages).
  2. LIMEY
    LIMEY
    Thats gonna take a while with one finger or will your better half do it! [​IMG]
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    Kev - you of all people should know I type like a girl with the phone-book type emails I send you... [​IMG]
  4. LIMEY
    LIMEY
    Oh yeah now i come to think of it....you are so talented...next you'll be telling me you can fly a plane!!
  5. Flat Ernie
    Flat Ernie
    Tech Editor
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Well, I needed to throw this magazine out & didn't want to scan it in, so I typed the damn article out. I'll post it here - if anyone can use it, cool. (excessive comma usage courtesy of the original author)
    T-5 TRANSMISSION SWAPS
    By Jim O’Clair
    Hemmings MUSCLE MACHINES July 2004
    One of the most versatile transmission in the last 20 years or so has been the Borg-Warner T-5 manual transmission. This five-speed unit was used as original equipment by several manufacturers and can be easily adapted into older muscle cars as well. Based on the Borg Warner SR-4 and T-4 four-speed, a fifth gear was added to the case, creating the T-5. Actually, American Motors was the first manufacturer to use this transmission in the 1982 Spirit and Concord cars. Ford soon adopted the T-5, using this unit in the 1983 Mustangs and Thunderbirds. GM used the T-5 in the 1982 and up S/T series pickups and small Blazers, and their Astro vans. They began installing them in 1983 in the Camaros and Firebirds. Nissan also liked the idea of an internal shifter linkage five-speed, and they used this transmission in the 280ZX/300Z cars as well. Additionally, Honda and Isuzu used the T-5 in some models in the 1990s.
    One of the advantages of this transmission is that the internal parts will interchange between versions of this unit. This enables you to select from several shift ratios, and the transmission is adaptable to different engine conversions or rear-end ratios. A T-5, while not known as a drag-racing transmission, can improve gas mileage in cars and trucks with taller gears because of the overdrive fifth gear ratio. Another advantage is that the shifting linkages are internal, improving clearance for easier conversion because external shift linkage clearance is not an issue. The T-5 used in the GM models incorporates a hydraulic clutch master on the firewall and slave attached to the bell housing to provide smoother shifting with less effort than with a conventional mechanical clutch linkage. The Ford version of the T-5 uses a shift cable attached tot eh clutch pedal. The cases are all aluminum and are referred to as toploaders because the access cover for the internals is on top of the transmission rather than on the side like some other standard transmissions.
    There were two generations of T-5 transmissions. All units used from beginning of production in 1982 until mid-1985 were referred to as “non-world class” or NWC. Non-world class versions had all-bronze synchro assemblies and used roller bearings to support the countershaft. In mid-1985, Ford began using the next generation T-5, called the “world class” or WC unit. These had numerous design improvements. First and second synchros were bearing and shaft assemblies rather than solid shafts in the non-world class., and the third and fourth synchro was a steel-reinforced unit with fiber-lined rings. Only fifth gear was still an all-bronze synchro. Both generation Ford T-5s used a 1-1/16-inch 10-spline input shaft diameter and a 28-spline output shaft. The 1983-92 GM T-5s that were coupled to V-8 engines have a 26-spline, 1-1/8-inch input shaft. The GM 4-cylinder and V-6 T-5s used the 3.52 through 4.03 ratios and were 1-inch, 14-spline input shafts. Later model F-Body world-class versions of the GM T-5s used the lower, 2.95 to 1 ratio gearbox and are the most sought-after for GM applications.
    The non-world class T-5 transmissions were used in the following cars and trucks:
    · 1982-85 AMC Spirit, Eagle, Concord
    · 1982-96 Jeep CJ and XJ trucks
    · 1982-85 Ford Mustang, Thunderbird
    · 1983-87 Camaro, Firebird
    · 1982-92 Chevy S/T-10 pickups, Blazers, Astro van
    · 1982-83 Nissan 280ZX
    · 1984-86 Nissan 300ZX
    · 1984-86 Chevette and Pontiac T-1000 also used this unit; however, the countershaft bearings were smaller and the T-Body bellhousing was not interchangeable with any other GM models.
    The more popular world-class units were used in these original vehicles:
    Late 1985-96 Mustang/Cougar/Thunderbird
    · 1988-96 Camaro and Firebird
    · 1993-95 Chevy/GMC S/T series trucks
    · 1994-96 Honda Passport
    · 1991-97 Isuzu Rodeo
    NOTE: 4-cylinder Ford 2.3-liter Turbo units as well as 1993-96 Cobra “Z-Spec” T-5s do not interchange directly, due to difference in the input shaft bearings.
    The most important difference between non-world class and the world-class transmissions is the torque rating. Later is better (or the higher the tag number). For example, 1983-89 Mustang units, both world class and non-world class, were rated at 265-lbs.ft. of torque. The 1990-93 versions were rated at 300-lbs.ft., and the 1993-96 Cobra “Z-Spec” T-5 was rated at 330-lbs.ft.
    You should be looking for as complete a unit as possible, when searching the swap meets or salvage yards for these transmissions. On GM’s crossmember, clutch master, clutch hose, and clutch slave cylinder should come with the unit to save time and plumbing. It would be even better if the starter and flywheel were still with the car; usually later model starters are lighter and have higher torque. If converting from an automatic-equipped car to a manual, a clutch pedal from a donor car will also be needed, as well as the bellhousing. On Ford vehicles, hydraulics are not used, and a shift cable is employed in place of the clutch master and slave cylinders. Make sure to take this cable when buying parts off the donor car. Aftermarket clutch cables and crossmembers are available, if these parts cannot be found.
    An identification tag number, which is on one of the mounting bolts on the tail case, can identify all T-5 manual 5-speeds. They all start with prefix 1352, and the next few digits will tell you what the unit came out of originally and what its shift ratio is. You can check any original tag number online at www.5speeds.com. Numbering series starts at 001 and runs as high as about 260. Borg-Warner sold the rights to the T-5 to Tremec in the late 1990s; however, there is no difference between the two manufacturers’ [production units, other than the name used in the castings.
    Ratios depend on tag number, but most are in the 3.35 to 3.97:1 range. There are 2.95:1 units that were used in late-model Mustangs, Camaros and Firebirds. The 2.3 Turbo Fords used a few units that were 4.06:1. Speedometer drive gears were 6, 7, or 8 teeth, but may have to be changed, depending on engine and rear-end size in the transplant vehicle. Changing of the speedometer gear is a definite requirement when installing a transmission and V-8 unit in a 6-cylinder, and vice versa.
    The Ford versions of the T-5 will adapt easily to the earlier Ford three- and four-speed manual bellhousings by an adapter plate which enlarges the metric mounting bosses to ½-inch diameter, and adds ¾-inch in spacing. Installation of a T-5 into an earlier Ford product is fairly easy, because of the bellhousing similarities. You should make sure, however, that the proper flywheel is used, depending on the year of your engine. The 1981 and earlier Ford small-blocks use a 28-ounce imbalance, 157-tooth flywheel. Any of the small-block Fords newer than 1981 used a 50-ounce imbalance, 157-tooth flywheel. These should not be interchanged. Late-model T-5 bellhousings used on earlier Ford V-8 engines will bolt up, but the late-model fulcrum for the fork needs to be replaced with an early-style fulcrum installed on the inside of the housing to align the throw-out bearing fork. You can, of course, also use of an aftermarket scatter shield for this changeover, eliminating these adapters.
    Because of the simliarites in earlier and later Ford small-block bellhousings, it’s possible your acquired T-5, with an early flywheel, will fit in these small-block applications:
    · 1965-68 Ford full-size cars
    · 1965-69 Comet
    · 1967-70 Fairlane
    · 1967-70 Falcon
    · 1968-73 Mustang
    · 1971-74 Torino
    · 1970-74 Montego
    Mounting a T-5 in place of a Super T-10, Muncie or Saginaw into a Chevy is pretty straightforward; the input shaft length is identical, and the whole unit is only two inches longer overall at the transmission mount pad. A shorter driveshaft would be required, and modifications to the crossmember would be necessary to mount the T-5 properly. The bellhousing-to-block bolt patterns are the same on the earlier V-8s, and the bellhousing-to-transmission configuration is common to all other GM manual transmi9ssions; so installation of a 1983-92 GM T-5 out of a V-8 should be relatively painless, if you can acquire all the necessary parts from the donor car. Although the V-6 and 4-cylinder input shafts are 14-spline, and will fit with the proper clutch disc, they are not recommended for V-8 applications. They do not have the higher torque rations required for the V-8 units without upgrading the internals. Installing one of these five-speeds in a Buick, Pontiac or Oldsmobile would require the use of the proper B-O-P bellhousing. There are two that have been found to fit both engine and transmission. One is out of a 1979-81 Firebird or 1979 Skylark (casting number 563441). The other is from a 1982 F-body (casting number 14037657).
    All 1993 and up GM cars with the T-5 used the Ford bellhousing bolt pattern, and not the earlier GM pattern. The 1993 and up GM applications were limited to V-6 Camaros/Firebirds, as the option was not offered in the V-8s. You can identify these transmissions by the 26-spline GM input shaft with a Ford bolt pattern. You should also know that F-Body bellhousings mount the transmission at a 17-degree angle towards the driver, which could cause problems when trying to line up and mount the shifter through the floorboards of other models.
    Aftermarket adapters to mount the Ford T-5 are available for AMC V-8s, Ford flatheads, and early 1950s Chrysler Hemis. Adapters for GM T-5s are also available for these same cars, plus Buick V-6 and Chrysler flathead 6-cylinder. A, B, and E-Body Mopars can also use the T-5 with an aftermarket bellhousing from one of several suppliers. AMC and Jeep can replace their existing SR4 or T-4 unit with the T-5, and adapters are available to install it in 4WD Jeep applications too. There are numerous “How To” installation instructions on Internet web forums from various enthusiast groups that include Imports and early Chevrolet six-cylinder truck applications.
    T-5s are currently selling for between $150 and $500 through swap meets and salvage yards, and complete changeover kits are being sold in the $850 range. Rebuilt T-5s run about $700-$850. The improvements in performance gained by changing to a T-5 will certainly outweigh the effort required to complete this installation, and the fuel savings, as an added bonus, will help make the decision to upgrade to this transmission one to consider.
    4ever18 likes this.
  7. ESnacky6
    ESnacky6
  8. kentucky
    kentucky
    Valuable info, Thanks!
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Lotsa crap I didn't know and a good refresher on stuff I did know! Thanks a ton!
  10. Southfork
    Southfork
    Hey, thanks Flat Ernie, that's much appreciated.
    I wonder how you identify one of these T5 trannies when the ID tag that the article talks about has somehow become detached from the tranny and lost?
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    Quite a few (I'd say most) of the T5s I've run across have a sticker on the top cover somewhere with a bar-code. The number is usually on there as well. That doesn't mean someone couldn't have changed the lid though!
  12. 30roadster
    30roadster
  13. Smokin Joe
    Smokin Joe
    Damn, Gotta love the HAMB!
  14. Flat Ernie
    Flat Ernie
    Tech Editor
    bttt - been getting a lot of T5 questions lately
  15. kentucky
    kentucky
    Scored a T5 today - so BTTT:)
  16. Bill.S
    Bill.S
    from NW OH
    Thanks,good info, saved it to print out later.
  17. Wow, thanks for taking the time to do that. Been meaning to do a little research on some trannies, including the T5. You just saved my ass from looking. I printed it out for future reference.
  18. Flat Ernie
    Flat Ernie
    Tech Editor
    I had started on my own T5 article/memory jogger, but it's been bogged down by other stuff & is currently on the back burner until I find some more time.
    There is a pretty good article over on BillB's Flathead Techno site, but it has some minor errors, it's tag # list is incomplete & doesn't cover everything I would. I'd give it a B+ because someone basically compiled a bunch of other people's work (check the links at the bottom), but it's a great compilation of relevant & useful stuff & it can be found here:
    http://www.flatheadv8.org/t5-swap.htm
    Techno Site for those that don't know about it:
    http://www.btc-bci.com/~billben/flathead.htm
    :cool:
  19. kentucky
    kentucky
    Hey Flat Ernie,
    I've got to get the #'s today to be sure, but I think my T5 is a 93 S-10 2.8, which will be a WC with the Ford bolt pattern. Do you know the hot setup for adapting this to a early style (1946) flathead? Thanks!
  20. Flat Ernie
    Flat Ernie
    Tech Editor
    Well, if it's a '93, you've got an electronic speedo, so you'll have to figure a way around that one.
    As far as bolting the trans to the engine, off the top of my head, here's what I can think of -
    The standard Offy adapter won't work, so you'll have to come up with something else. What I'd use is the early Ford 4-speed truck removeable bellhousing the one in the picture. Then you can fabricate a flat aluminum adapter/spacer plate that adapts the bolt pattern of the bellhousing to the trans. From memory, this plate should be 3/4" thick, but some of the T5 have a longer input shaft (like 94-95 Mustang) & it may need to go to 1". I think the '93 S10 should have the standard input shaft length though.
    You'll also need to have a spacer sleeve machined that adapts the outside diameter of the T5 input shaft to the inside diameter of the early Ford throwout bearing.
    Finally, you'll need to have a pilot bushing machined to mate the T5 input to the flatty crank - I think it will have to stick up about 1/2" instead of flush.
    For the clutch - just take the S10 plate down to a clutch rebuilder & tell them what diameter you need to mate it to your flatty pressure plate. Bring the flatty clutch disc too if the guy's not familiar.
    That's about all I can think of off the top of my head - should point you in the right direction.
  21. jonizzle
    jonizzle
    Thanks for posting that article Flat Ernie. Good information to know. I can't wait to get my t5 in my car this summer. Thanks man!
  22. bigron
    bigron
    way cool. good info.
  23. al bone
    al bone
    from mid-mich
    thanks,Im running a super t-10 with a 350 rear end ratio,Ive been thinking of this swap for a while now, but I still worry about the low torque ratings, Im guessing I have about 400ft pounds does any body think I will have any problems? I dont race but I do grab an occaisional gear.If I did make the swap does this mean I could run that 4:10 unit Ive got or would this just cause more trouble?..thanks AL BONE
  24. reefer
    reefer
    Ernie, great info, thanks.I`m putting a 283 in my `36 coupe and I`ll be fitting a T5.The question is, the T5 I`ll be getting (hopefully)is the Ford version as fitted to the TVR that is made locally.Now what will I need to match the two?I`ll be using a hydraulic thrust bearings and slave cylinder.Will the box fit right up to the Chev bell housing?Or is this swap a non starter?
  25. Flat Ernie
    Flat Ernie
    Tech Editor
    I'm not really an expert - just opened a couple of these trannys up before & done a bit of my own research.
    I'm not that familiar with the TVR version, but if it's a copy of the Ford (which sounds right, but...), it probably won't bolt up to a Chevy bell.
    Well, if you use a later one rated at 300lb/ft or find a Cobra spec one at 330lb/ft, you'll probably be OK. The 5.0 Mustangers ran T5s for years before the Tremec (who owns the T5 now, BTW) TKO & 3550 came along - I would suggest a racing-type shifter with positive stops (worst thing is factory shifter - allows over-center banging of the forks) & a rebuild to tight tolerances for end play - if it's a fresh box, you can adjust the endplay yourself - the shims go under the end of the input bearing retainer.
    The weak link is 3rd gear & 5th gear - 3rd gear synchros are gone more often than anything.
    These are tough trannys though - I ran an early (83 Mustang 165lb/ft NWC) one behind my stroker 351 for years - I munched the synchros, but the tranny went well - just had to double-clutch & couldn't put much power through it while shifting.:D Ran it like that for years - finally put a later model one in with a good shifter & have no problems behind the stroker (375-ish HP).
    :cool:
  26. CruZer
    CruZer
    Thanks Ernie. This is really timely. I stopped at a friend's house last night to look at his new '52 Chevy fleetline that he just bought.It's a stocker that will be a mild custom and he wants to put a T-5 up against the 6 cyl. This will help him out a lot.
  27. Flat Ernie
    Flat Ernie
    Tech Editor
  28. Scott
    Scott
    This one is going on file! Thanks Ernie. This will definitely help since I am considering a t5 for my present or future project.
  29. Dirty2
    Dirty2
  30. jake//NC\\Mi
    jake//NC\\Mi
    from michigan
    I put a chevy t-5 behind a flathead in my 34 truck works great. Runs down the highway 80mph no problem.I will use one again.
