Reply
Thread Tools Display Modes
Old 08-21-2007, 09:00 PM   #1
honestjerry
FNG
Default jump starting 6 volt positive ground
ok, school me on jumping a 49 ford, 6 volt positive ground. Can we use a 12 volt neg. car to do it? I know not to leave it hooked up too long and turn all other systems off, etc., but do how do we hook it up?
online   Reply With Quote
Old 08-21-2007, 09:08 PM   #2
junkyardjeff
Old School HAMBer
Default Re: jump starting 6 volt positive ground
I have jumped 6 volt positive ground systems with 12 volts but do not run the vehicle with the 12 volts and have someone ready to yank the cables when it starts,with a 49 ford you should be able to push or pull it to start. Jeff
offline   Reply With Quote
Old 08-21-2007, 09:36 PM   #3
terrarodder
Senior Member
terrarodder's Avatar
Make sure you don't cross polarity, I lost a pair of jeans and a club jacket doing that, blew up the 6 volt battery.
Old 08-21-2007, 10:49 PM   #4
speedtool
It's still positive to positive, negative to negative.
Old 08-21-2007, 10:57 PM   #5
recardo
Buy a second 6 volt battery and weld up a nice roll-around for it, as your first shop project.
Old 08-22-2007, 02:36 AM   #6
Fe26
Fe26's Avatar
Disconnect the battery from the donor car, ensure polarity is correct,
turn your ignition switch on, place the "hot" jumper lead on the starter motor side of the solenoid, the starter will spin without damaging the 6v system, DO NOT press the starter button.
Good luck
__________________
Nothing is more terrible than ignorance in action.
Old 08-22-2007, 07:42 AM   #7
adjustablejohnsons
Old School HAMBer
adjustablejohnsons's Avatar
Location: I bounce around. SouThe Villages, FL..Key West..New Orleans.
Good luck
Winner.
__________________
The HAMB...teaching thousands what high school kids figured out by themselves 70 years ago.
Old 08-22-2007, 07:57 AM   #8
Gorehound
Grenade Inspector
Just rewire the car for 12 volt. You know you love crawling
in and out of damp musty old cars.
Lee
Old 08-22-2007, 09:01 AM   #9
honestjerry
FNG
not gonna rewire. wouldn't be prudent. just want to get it started, bring it home, fix what ails it and send it back to whence it came!
Old 08-22-2007, 09:33 AM   #10
DrDano
Alliance Vendor
Is this a British Ford or something? '49-'51 Fords were all positive ground, at least all the ones I owned and have seen were.
Old 08-22-2007, 09:52 AM   #11
Sawracer
Senior Member
Sawracer's Avatar
my 30 ford is 6V pos ground. It's fine and dandy when the car is running good. Start troubleshooting, cranking and forgetting to turn ignition on and, then you are screwed. It spins just fast enough for a well tuned setup. If you need more than that it's dead battery city. I have been fighting converting it but with the hi comp ovh setup, I know it's inevitable.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
