Reply
Thread Tools Display Modes
Old 07-27-2007, 08:20 AM   #1
rat bastad
Old School HAMBer
rat bastad's Avatar
Default TH 700R4 tech.... and install into 57 Chevy
Any HAMBERS run this trans (non lockup) behind a 283 in a tri five?
I recently scored a real nice 57 Bel Air matching numbers longroof surf wagon and want to keep it looking almost stock apart from the altitude adjustment and a nice sounding hyd cam.
But I'm looking to maximise efficiency, 1st gear acceleration, and OD economy on the highway in the wagon and I know the Glide it comes with has a real tall 1st gear and weighs a shitload.... so I figger maybe a 700 R4 could be a viable swap. I know it has been done successfully and parts are available to make it look like a factory install from the column gear indicator to the trans mount.
1st gear ratio in the 700 R4 is 3.06 with a 4th gear/ OD of .69 - this will help the small cube motor really wake up and maximise its efficiency.
Engine is a 283, 10.00:1 CR, bowl ported/shaved power pack heads, port matched Corvette dual plane intake,, 57 Rochester four barrel (450-500cfm), 450" lift/218@.050 hyd cam, ported rams horn manifolds,and 3.36:1 rear gears.
I know a TH 350 is a leap in the right direction but I'd really be interested in TH 700 R4 for a mild application like this and for max economy. That 3.06 first gear will wake that sucker right up too.
This thing looks totally standard from the outside but I want to improve its efficiency as a daily driver and that stock Glide I feel wont cut it.
I know the earlier 700 R4s had dramas with line pressures and weak 27 spline input shafts that were upgraded to 30 spline and overall were improved from the mid 80s on.
So can someone school me on the the possibilities of this swap and as to which trans to get my hands on?
Thanx
Rat
__________________
"IF IT WAS'NT FOR BAD LUCK I WOULD'NT HAVE ANY LUCK AT ALL"
offline   Reply With Quote
Old 07-27-2007, 08:37 AM   #2
Deuce Roadster
Deuce Roadster's Avatar
Default Re: TH 700R4 tech.... and install into 57 Chevy
I just bought the kit ... from these folks ... to solve the TV cable issues.
http://www.phoenixtrans.com/html/newproducts.html
Their kit uses a lot of Lokar stuff and their own carb arm adapter.
You would need side motor mounts on the SBC ... IMHO to do the 700R4 swap. Also ... you need starter mount bolt holes on the block. I do not believe original 57 blocks have these needed items ...
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 07-27-2007, 08:59 AM   #3
walrus
walrus's Avatar
Rat, Just did the 700r4 swap in my 55 , I kept the original front mounts and added the mid bellhousing mounts along with a trans mount , was an easy swap and works great,70 mph on the highway equals to about 1950 to 2000 rpm, got to be good for gas mileage, I did substitute a 350 v8 for the six cylinder so I am not familar with the starter setup. sent you a pm
__________________
"Lord please keep your arm around my shoulders and your hand over my mouth"
Old 07-27-2007, 09:35 AM   #4
rat bastad
Old School HAMBer
rat bastad's Avatar
Thanx for the heads up. But what exactly is this TV cable? DOH !!
Does it pick up the History Channel lmao ???
Seriously, what is its function and how does it work? Also, what is the deal with the starter motor?
Walrus, check your PMs...
Rat
__________________
Old 07-27-2007, 09:52 AM   #5
nexxussian
Alliance Member
nexxussian's Avatar
TV = Throttle Valve. It is how the 700R tells how far you have your foot in it. It controls a valve inside the trans that varies line pressure and as a result shift firmness and shift points. A maladjusted TV cable can make the trans shift poorly and not at the desired points or if it is even further off you can burn up the trans in short order as the 700R does not have a vacuum modulator to sense engine load through manifold vacuum as some other transmissions do (IE TH350). That is why there are several adjustable cable setups to put the 700R in places it wasn't designed for originally.
__________________
Erik
'Cause it's s'posed to be fun.
Quote:
Originally Posted by Dr Goggles View Post
I mean Ive got an angle grinder and a hot metal pump who says I can't make my own manifolds
Old 07-27-2007, 09:58 AM   #6
Bluesfella
Grenade Inspector
Bluesfella's Avatar
The TV cable is arguably the most important part of the swap when switching to a 700R4 trans.
(I just did this swap in my '55 a few weeks ago, though I have a later-model V8 in mine.)
The TV cable controls the Throttle Valve pressure...you have to have it set correctly or you will burn up the trans. It looks like a kick-down cable for a TH350 trans, but it's more important than that.
I don't know about the starter questions, but I really like the 700R4 trans.
Why would you want non-lockup?
__________________
"It's a high-pitched sound. Hot rubber eternally pressing against the blackened pavement. A wheel is forever. A car is infinity times four."
"I'm silver smooth. Bathed ten times a second in an aerosol fire...five thousand degrees in here. I course with electricity from my feet to my tongue, where I vomit a torque-delivering spark."
- Taurus, Interstate '76
www.vancerutherford.com
Old 07-27-2007, 10:01 AM   #7
Bluesfella
Grenade Inspector
Bluesfella's Avatar
Oh, and I didn't use this system for the TV cable, but I know a lot of folks who have and were satisfied with it:
http://www.tvmadeez.com/
__________________
Old 07-27-2007, 10:06 AM   #8
nexxussian
Alliance Member
nexxussian's Avatar
Quote:
Do you want to run it non lockup for some reason? It will get better economy and run cooler in OD if you let it lock the converter. It can be done as simply as a switch on the dash all the way up to a wiring kit that includes a vacuum switch to unlock the converter at higher throttle settings.
__________________
Erik
Old 07-27-2007, 10:18 AM   #9
Moonglow2
Moonglow2's Avatar
You are correct about the later 30 spline input shafts being the better tranny. Both it and the 200-4R went thru several improvements the longer they were offered.
Check out Bowtie Overdrives for tech info and they have a TV kit that eliminates all the guess work for adjusting the TV. A fellow HAMBer on here offers a lock-up kit for the TC. Opinions differ between tranny builders whether to run a lock-up or not.
http://www.bowtieoverdrives.com/index.shtml
Pay attention to Bowtie's article on checking line pressure before attempting to drive the car. Assuming you can resolve the starter hookup problem find out your rear gear ratio. I think most 57s ran either a 3.36 or a 3.55 . Short stroke sbc's need more rpms at cruise speed (at least 2000) than their longer stroke cousins to get any mpg benefits.
The formula for determining this is as follows:
mph x final drive ratio x 336 / tire dia in inches = rpm
Example: At 70 mph using a 700-R4 which has .70 overdrive ratio, a 3.36 rear gear and a 26 in.tall tire the math would look like this.
70 x 3.36 x .70 x 336 / 26 in. = 2127 rpm
Good luck - let us know how it works out.
Old 07-27-2007, 10:25 AM   #10
1950ChevySuburban
1950ChevySuburban's Avatar
1987 to 1991 trannys are best. Make sure it has 2 valve bodies.
I'd buck up for the better 13 vane pump, the reinforced sun shell and the Corvette servo, among other things.
And yes, TV cable adjustment is critical!
__________________
My '29 Sedan build thread can be viewed here:
/showthread.php?t=635145
Old 07-27-2007, 12:24 PM   #11
rat bastad
Old School HAMBer
rat bastad's Avatar
Great info guys....thanx a bunch. Im gonna look ino this some more. Any more info?
BUMP !!
Rat
__________________
Old 07-27-2007, 12:45 PM   #12
stickylifter
Senior Member
stickylifter's Avatar
You'll definately want to hook it up so the converter locks up. Slip in the converter causes more heat. Also, your mileage will be way better in cruise gear. You can hook it up with a kit from these guys: Bowtie Overdrives. There is a lot of great info on the site as well.
Old 07-27-2007, 04:42 PM   #13
Deuce Roadster
1957 Chevrolet starters ... bolt up like this ...
To a bell housing like this ... Ford to SBC adapter shown ... but the adapter shown uses a starter like the one on your 57 originally came with
Later engines ( like the ones that 700R4's came bolted to had a starter provision on the block. Upper left hand corner of the photo
Check your starter ... if the bolts go into the bell housing ... and not into the V8 block ... you will have to figure out the starter deal
__________________
Old 07-27-2007, 08:16 PM   #14
rat bastad
Old School HAMBer
rat bastad's Avatar
Thanx for the info DR....Ill explore this a bit further an thanx to all who posted !!
Rat
__________________
Old 07-27-2007, 08:27 PM   #15
Enginetuner
Grenade Inspector
Enginetuner's Avatar
You really want to keep your lock up, not only for the economy, but in over drive there is not enough line pressure without lockup and a pontential for burning clutches is present. Some trans guys are enlarging the oil pressure ports to gain more volume and pressure while in o/d and not having lock up. Lock up can be applied with a switch as mentioned earlier or you can have it engage and dissengage with pressure, talk to your tranny guy.
Ever thought about the 200 trans, alot lighter and just as dependable with a mild engine...just a thought.
Tuner
__________________
Hot Rods For God....
The Hot Rod Preacher
Old 07-27-2007, 08:28 PM   #16
CAMHEAD
Alliance Member
I Think Ecklers Classic Chevy Or Danchuk Manufacturing Has Everything You Need For This Swap.
Old 07-27-2007, 09:00 PM   #17
Mai Ki-Ki
Alliance Member
Mai Ki-Ki's Avatar
Hey Frank sounds cool...any pictures....?
Maiki
(PS< last two photoshoots this weekend!!!)
Old 07-27-2007, 10:27 PM   #18
mark 55
Alliance Member
mark 55's Avatar
Did this same swap in my 55 chevy wagon. Just drove from Louisiana to Bloomington Illinois and back. 20 mpg and no problems.
I run a 64 vintage 283. It's the way to go. Pm me if you need any additional info.
Old 07-28-2007, 10:46 AM   #19
rat bastad
Old School HAMBer
rat bastad's Avatar
Mark thanx for the tip, Ill probably be in touch at some stage in the near future.
Maiki, Ill put up some pix soon and some detail on the ride.
PS: Got some pix for me?
Rat
__________________
Old 07-28-2007, 10:50 AM   #20
pasadenahotrod
Old School HAMBer
My 57 PowerPack V8 had been drilled for the "modern" starter and worked quite well hooked up to a built air-cooled PowerGlide from a 62 Nova in my Old T Roadster. Many engines are already drilled for the "new-style" starters even if they have the old iron Powerglides behind them.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
