Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Senior Member
This is a copy and paste of an old article. This tells a story of what happens when a person running a major corporation decides to invest what it takes to demonstrate his company's engineering prowess with no holds barred. I'm speaking of Henry II. This excercise happened early in the "Ford Total Performance" era. This project is a good example of "trickle down" technology. Much of this early pushrod Indy V8 technology was put into larger use with the Boss 302 engine of the late `60's.
As you look this article over notice that Ford combined the best from two different era's of engine design thougnt. The basic engine structure was definately all Fairlane "Challenger V8" with it tight compact and lightweight attributes. The valvegear however departs from the ball/ stud rocker system used on the production versions of this engine and probably more famously on the Chev and Pont V8's in the `50's. No the Ford Indy V8 used Y- Block valvegear. Yes that's right Y- Block! Complete with solid mushroom tappets, well supported shaft mounted rockers and even what I believe is the first factory use of a "rev kit". Enjoy this look back at a cool point in Ford's racing histoty. The Ford V-8 Engine Workshop Indy Engines 1963 Indy Pushrod V-8 The 1963 Indy pushrod engine produced 375 BHP at 7200 RPM from 255 cubic inches Ford powered Lotus cars were prepared for Indy in 1963, to be driven by Dan Gurney and Jimmy Clark. The engine for these cars was designed and built by Ford beginning in the fall of 1962. Bill Gay, Executive Engineer of Advanced Engines, assembled a team of engineers including Joe Macura and Richard Chen. Their objective was to build a racing engine of 255 CID, producing at least 325 hp, and weighing no more than 350 lbs. The competition the was Meyer-Drake Offenhauser. Ford purchased an Offy and tested it in one of their dyno cells. It produced 400 hp at 6000 RPM. The team had their work cut out for them! The design project was divided into two phases. First, to baseline the 260 Fairlane engine that was to be the basis of the new engine. Second, to develop a reliable aluminum version of the engine. Work on the 260 began on Sept. 1, 1962. The high performance 260 used in the Cobra was the starting point, dubbed the Stage 0 engine. Stage 1 involved revised and enlarged intake and exhaust ports, and 12.5:1 compression through the used of forged pop-up pistons. The special intake manifold carried four 46mm downdraft Webers carburetors. Larger valves, hollow-stemmed intakes and sodium-filled exhausts were fitted to the heads, along with high silicon content aluminum alloy retainers. 7/16" screw-in rocker studs, with Loctite and further secured by roll pins. The connecting rods were taken from the 289 HiPo engine, fitted with bronze wristpin bushings, shot-peened and polished. The crankshaft used cross-drilled journals for improved connecting rod bearing lubrication at higher engine speeds. After several different camshaft grinds were tried, the 260 produced 325 hp on gasoline, meeting the power objective set for the Lotus racecar. Work on the aluminum Stage 2 engine began on Nov. 1, 1962. The sand cast aluminum cylinder block differed considerably from the production cast iron 260/289 block. The front of the block and timing cover were completely redesigned to support a gear driven camshaft and water pump. Due to the softer aluminum, the deck thickness was increased 50% to 0.64 inches. Bolt holes were lengthened to a thread engagement of 2 X bolt diameters. Main bearing caps were wider and held by 4 bolts. Cylinder heads were attached by studs, using six per cylinder. Four addition studs protrude from the lower edge of the block, and four studs aim down from the heads themselves into bosses at the edge of the lifter valley. The bore size was changed from the 260's 3.80" to 3.76", resulting in 255 cubic inch displacement. The block was fitted with dry cast iron sleeves, pressed in. The tops were grooved to carry a steel O-ring gasket. Oil and water passages were sealed with rubber O-rings and a bead of sealant ran across the lifter valley. This dry deck arrangement was later used on the Boss 429. All torqued down, there was a slight air gap between the deck and cylinder head, concentrating all the clamping loads on the cylinder sleeve O-rings. Special aluminum cylinder heads were made up using the 260/289 production head as a starting point. These heads used aluminum bronze alloy valve guides, alloy steel valve seat inserts, steel valve spring seats, oil passages for the shaft mounted Y-block style rocker arms, and four additional bosses to hold the top row of head studs. The production cast iron crankshaft was not up to the rigors of Indy. The racing engine used a forged steel crank, with revised counterweighting for internal balancing. Bearing size and type was identical to the 289 HiPo, tri-metal Clevite. The rod crank pins were drilled to lighten and and formed an oil reservoir. The ends of the holes were plugged with steel cup plugs, and pinned. This is similar to that found later on the 427. Forged pistons were used, with full-floating pins retained by double-helical spring retainers. Rods were taken from the Stage 1 engine, 289 HiPo, shot-peened and polished. The oiling system was highly modified and is explained below in the article on the 1964 engine. The valve train received extensive redesign. Small diameter tappets weighing only 2/3 that of the production parts ran on the 340 degree duration camshaft. Overlap was 124 degrees. Lift at the valves was .510 inches. The hollow tubular pushrod featured a small cup on the top end to mate with the lash adjustment screw. The tappet end had a compbination spring seat and steel ball. The engine used a revkit, springs fitted under the heads applying pressure against the tappets directly. This reduced loading on the rockers and valve springs and helped improve high speed valve control and longevity. Due to the high coefficient of thermal expansion inherent with the aluminum components, valve lash was set at .032 inches cold. At high speed the stud mounted rockers were found to oscillate, throwing off valve events and often failing outright. The stud mount ball type rockers were replaced by a shaft-mounted system taken from the Y-block. This system was later used on the Tunnel Port 302. Dual springs, with an inner and outer coil were used and fitted snugly together, rubbing, to help dampen harmonics. The Stage 2 got a new intake, this time fitted with 58 mm Webers. Ford tested the engines and did some of the tuning work using a 1963 Galaxie. This chassis with a very low rear axle ratio allowed the engineers to simulate the full throttle acceleration runs typical of the Indy racetrack. From a lower rpm limit of 5000 rpm to the maximum of 7200 rpm at the end of the long straights. With the body removed from the chassis, Ford placed the "car" in its windtunnel to streamline the exhaust headers. The Autolite Division prepared an electronic spark box for the engine. No mechanical advance was used. The static timing was set to 50 degree BTDC! Due to delays in the electronics of about 1 degree per 1000 rpm, the final spark timing was 43 degrees at 7000 rpm. (I wonder how that started the darn thing?) The project was completed in time for the Indy time trials in May, 1963. The engine was producing 365 hp. The test engine had run 2-1/2 hours on the dyno, and over 450 miles on the track at Indy. It was returned to the dyno and found to have broken in a bit, producing 376 hp. -------------------------------------------------------------------------------- |
#2 |
Senior Member
The Y- Block rocker shaft stuff worked because the SBF and the Y- Block share the same bore center dimension of 4.38".
(An interesting sidenote: The FE engines were based on the larger Lincoln Y- block bore center of 4.63") |
#3 |
Senior Member
Notice the direct lineage from the Ford Indy V8 to todays modern redition of the Boss 302. (Canted valves not withstanding)
#4 |
Senior Member
Here's the bottom end of the Indy V8 for comparison.
#5 |
Senior Member
A fellow at Carlisle Ford meet this spring had an "NOS" DOHC Indy motor for sale along with a bunch Gurney Eagle stuff too. He said he had 9 more of them too. Here's a pic.
Thanks for posting the info. I love that whole era of Ford racing and total performance.
__________________
Stu "That's Captain" |
#6 |
Old School HAMBer
Location: Well south of where the Amish live in Michigan.
I have a Hot Rod from 63 (?, I'll have to look) where it also goes in depth into the Indy story... complete with a picture of a 4 door Galaxie with said engine and straight out the hood (think Monster Truck) style headers! And an ironic side note, the day after I read the article in the mag, we were at Henry Ford Museum and I saw the actual Indy car the magazine had pictured... I thought that was pretty cool.
Jay
__________________
My other car is an Amish Drag Buggy. "Hold that nitro- we're gonna cut a rug!" |
#7 |
Alliance Member
Here are some pics of the pushrod Engines in the Lotus Indy Racecars.
__________________
" Its out of gas... I thought I broke it" |
#8 |
Senior Member
Cool pics! Thanks Metalshapes.....Would'nt it be cool to clone the look of the engine below and install in an Indy inspired rod. Love the zoomies!
#9 |
Grenade Inspector
Bringing this old topic back from the archives.
Does anybody know if the current aftermarket and Ford Racing 18 blocks blocks and heads are the same bolt patterns as the Indy engine? Interesting that a lot of the new "5 litre" heavy duty stuff is so similar to 1962. |
#10 | |
Senior Member
Quote:
#11 |
Grenade Inspector
I see that they retained the 90 deg. cranks rather than go to a 180 deg. as sometimes happens in V8 race engines.
| Thread Tools | |
| Display Modes | |
