What do you guys think the pros and cons will be I switch to E-85 for the higher octane already set up for alcohol so no need to change anything on that end and run steel fuel lines. input positive or negative appreciated. <!-- / message --><!-- sig -->
a ton of threads on just this subject if you do a search.... the search function is your friend.... http://www.jalopyjournal.com/forum/showthread.php?t=168798&highlight=ethanol http://www.jalopyjournal.com/forum/showthread.php?t=164578&highlight=ethanol http://www.jalopyjournal.com/forum/showthread.php?t=157543&highlight=ethanol and on and on....
