Reply
Thread Tools Display Modes
Old 05-30-2007, 11:42 PM   #1
31aBoy
Default Converting Banjo Rear to Modern Axles
I have a bone stock model a I purchased a little over a year ago. I'm gathering parts, and now have come to the rear end.
I could use the S-10 rear end like a lot of guys do, but I like the stock look of the Banjo. I plan on 300-350 horse SBC and 700r4. I've heard about converting to 9 inch rear axles. So I did a little research, didn't come up with much, only this website: http://www.hotrodworks.com/index.asp
They have a kit ($850) to do this conversion. Is it the only available kit? Has anyone done it? Lets hear the positives and negatives.
Its awfully expensive for me as it wont be seen unless someone crawls under the car, but I'd like to use my "A" Banjo. Also, what gear ratio?
Any and all thoughts, experience, suggestions appreciated.
__________________
1931 Tudor
online   Reply With Quote
Old 05-31-2007, 12:53 AM   #2
Human Fly
Default Re: Converting Banjo Rear to Modern Axles
There was a tech post on this many many moons ago.
Goodluck, anything would be better than the key and tapered axle format, although i plan on running it
offline   Reply With Quote
Old 05-31-2007, 08:51 AM   #3
Flathead Youngin'
Old School HAMBer
Flathead Youngin''s Avatar
this has come up a couple of times....
pm me your email and i'll send you some you some pages from street rodder 1985 by david stone......
__________________
Yeah, it's mustang 2'd, 350, 350, 9 inch, pro-streeted, mini-tubbed.......pretty cool, huh?
Old 05-31-2007, 09:01 AM   #4
Petejoe
Old School HAMBer
Petejoe's Avatar
Found in the tech achive.
http://jalopyjournal.com/forum/showt...ighlight=banjo
__________________
In my old age...
Grant me the senility to forget the people I never liked.....
the good fortune to run into the ones I do.....
and the eyesight to tell the difference.
Old 05-31-2007, 09:11 AM   #5
Goztrider
Old School HAMBer
Goztrider's Avatar
I recently installed a complete 9" setup out of a '70s Ford half ton truck under the back of my '29 Dubble A truck. Using the same principles, you could probably do the same with your A frame.
I used everything off of the '70 Ford - 9" rear, springs, shackles, and brackets, and everything fit wonderfully, and pretty much looks like it belongs there.
My frame is 39.5" wide where the rear bracket mounts, and 34.75" wide where the front bracket mounts. Where the spring eyes mount to the brackets the length of the spring is 55".
I'll post the link to the thread where I did the install in a few minutes. Hopefully it'll help you decide.
Here it is:
http://www.jalopyjournal.com/forum/s...light=Dubble+A
__________________
Subtlety is saying what you mean, and getting out of the way before it is understood.
My '29 Dubble A build progress thread.
Old 05-31-2007, 07:54 PM   #6
31aBoy
Lots of great info, am I the only one who wants to do this??
__________________
1931 Tudor
Old 05-31-2007, 08:24 PM   #7
Bib Overalls
Alliance Member
Bib Overalls's Avatar
Your Model A rear will not stand up to 300 HP. With that kind of power you need something a lot stronger.
__________________
Plan ahead.
Sweat the details.
http://www.flickr.com/photos/ratpoison/
Old 05-31-2007, 08:37 PM   #8
Andy
Old School HAMBer
Andy's Avatar
Something designed for 40HP will not hold 300. The 39-48 would be a lot better but very marginal for sure.
Old 05-31-2007, 09:54 PM   #9
31aBoy
Even with upgraded axles?
__________________
1931 Tudor
Old 05-31-2007, 10:58 PM   #10
Bib Overalls
Alliance Member
I don't know of any way to put modern axles in an A banjo. You can upgrade later banjos. But that only fixes the key spline issue and the problem with wheels taking a hike when an axle breaks. It does nothing to improve the strength of the ring and pinon. The later banjos with late axles will handle a mild small block if you are careful. I am converting a 46 banjo to a quick change and running late axles behind an Olds 215. About 200 HP. I'd be uncomfortable running any thing stronger.
__________________
Plan ahead.
Sweat the details.
Old 06-01-2007, 08:04 AM   #11
31aBoy
Good to know, anybody else?
__________________
1931 Tudor
Old 06-01-2007, 08:55 AM   #12
HotRodWorks
Alliance Vendor
HotRodWorks's Avatar
Quote:
We offer a new differential for the 'A' rear end that will allow us to covert them to 9" style axles. It uses the stock 'A' ring and pinion, but uses new axle gears and spiders internally. It requires machining the axle housings for seals and using '40 style juice brakes and our bearing adapters.
Bib is correct, in that the pinion support is not as strong in the 'A' rear as the V8 rear. It does not have the 3rd pinion support bearing that the V8 rears do. If you're planning on running it hard, I would consider using a V8 style rear end.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
