Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Editor
here I have a 1950 Cadillac Lasalle transmission with the long tailshaft that will get a short shaft and housing from a 1950 Oldsmobile.
here are the main ingredients |
#2 |
Editor
remove the bottom cover and tail housing
#3 |
Editor
push the countershaft out the front and lift the cluster gear out
#4 |
Editor
set it gentley on a clean surface trying not to disturb the bearings
#5 |
Editor
remove the snap ring that holds the front bearing on the input shaft, remove the bearing,
and lift the input shaft out through the bottom |
#6 |
Editor
remove the syncronizer unit
#7 |
Editor
remove the snap ring and rear bearing from the mainshaft
#8 |
Editor
move the mainshaft forward to access the snapring at the front of the shaft that keeps the second gear in place
#9 |
Editor
pull the mainshaft out through the back
#10 |
Editor
visually inspect all parts as they come out and the inside of the case
#11 |
Editor
rear shift button and the low reverse gear go back in
#12 |
Editor
slide the Olds tailshaft in
#13 |
Editor
second gear goes back on the shaft being carefull with the roller bearings
followed by the bearing retaining washer |
#14 |
Editor
the snapring goes on
#15 |
Editor
push it the rest of the way with a screw driver making sure it's seated propperly
#16 |
Editor
the syncronizer unit appears ok
but I have a better one so it will go in |
#17 |
Editor
syncro goes on shaft
#18 |
Editor
I'm also swapping the input shaft for one that looks a little better
so it gets cleaned |
#19 |
Editor
grease the bearing surface liberally
#20 |
Editor
clean and inspect the roller bearings
| Thread Tools | |
| Display Modes | |
