Reply
Thread Tools Display Modes
Old 05-23-2007, 11:53 AM   #1
Old School HAMBer
squirrel's Avatar
Default TECH: Chevy Engine Numbers
I seem to answer a lot of questions about Chevy engine numbers, so I thought I'd share some of my "secrets" here in a tech post. Chevy was pretty good about putting a lot of information on their engines, and the numbering systems have stayed mostly the same for a long time. The mid 50s and earlier engines are stamped differently than the newer ones, but the casting date numbers work the same back into the early 1930s. Each engine will have 3 or 4 number sequences that when combined, will identify what the engine is from.
We will start with the block casting number, which is from 6 to 9 digits long. On the straight 6 engines, it is on the back on the passenger side of the block, hidden or almost hidden by the starter motor, or along the middle bottom of the block, possibly hidden by an engine mount. On the V8 engines, it is on the top of the block, at the back, above the bellhousing area. Casting numbers for Chevy V8 engines can be found at:
http://www.mortec.com/
Casting numbers for Chevy 1937-1962 (stovebolt) inline six blocks can be found at:
http://clubs.hemmings.com/clubsites/...tory/cast.html
and for those and newer straight 6s try:
http://www.inliners.org/casting/numbers.html
At the same area where you find the block casting number, you will also find the casting date code. The date codes are sometimes ambiguious, because they don't have the whole year, only the last digit (with a few exceptions). The casting date code is a letter followed by 2, 3 or 4 numbers. The letter is the month, A = Jan, B = Feb, C = March, etc up to L = December. The second or second and third number is the day of the month. The last number (sometimes last two) is the year. Some examples:
C 1 2
or
C 1 62
if it's march 1st, 1962
or B 16 2 (for Feb 16, 1962)
The casting date is usually a day or two or three before the engine assembly date, but sometimes it's weeks or even a month or more earlier.
The third set of numbers is the engine number stamped into the block. It will be on a machined pad at the base of the distributor on straight sixes, or on the deck surface just in front of the passenger side head on V8s. Some newer V8s have it on a little machined pad just above the timing cover. The stamped code on 30s-mid 50s engines includes some variation of the car model code, and a sequential engine number, but no date information. An example is:
JAD123456
J = 1951
Mid 50s engine have a sequential engine number, engine plant, the last two ditits of the year, and the letter suffix code. An example is:
123456 F56B
F = Flint engine plant
56 = 1956
B = truck 265 with hydramatic
The stamped code on 1957 and newer engines tells you the engine assembly plant, the month and day of assembly, and the type of engine and what it was used in. The code looks like this:
F0306AF
The first letter tells you what plant the engine is from, either V or F (Flint, MI), it could be T (Tonawonda, NY).
0306 is march 6th, the assembly date. Notice that the year is not given here. Before about 1960, the date does not have the leading zero, so in this example you would see F306AF.
AF is the suffix code. It can be one or two letters on 1969 and older engines, and three letters on 1970 and newer. The first letter of the 3 letter code on early to mid 70s engines will often be C for Chevrolet car engines, and T for chevrolet truck engines. There are literally hundreds of suffix codes, and I will not attempt to list them all here. I do have some books that list many of the codes from the 50s to the 70s, in addition to the ones pictured here, if you need help finding one please send me a PM. There are also some wierd codes for replacement engines and crate engines, sometimes they include an R at the end of the suffix, or the suffix is CE for "counter engine" (or whatever else it might mean?). Trivia: the LS-7 crate 454 that Chevy sold in the 70s and 80s has the suffix code XCH.
The last number sequence is the partial VIN, which was used beginning sometime in the 1960s. This will usually be found stamped next to the engine code. It will have 9 characters, the first three are the interesting ones, the last 6 will match the last 6 digits of the VIN that the engine was originally installed in. If you are looking at a car that claims to be "number matching", what that means is that the 6 numbers on the block match the 6 numbers on the car's VIN plate. If they don't, then it's not a number matching car! (and even if it has the correct number, it's possible it was restamped). We HAMBers usually don't give a shit about matching numbers, but at least now you know. Here's how the partial VIN breaks down:
12K123456
first number is the carline, which is 1 for Chevrolet, 2 for Pontiac, C for Chevy truck, T for GMC truck.
Second number or letter is the year, it will be the last digit of the year on 1960s and 70s cars, and a letter starting in 1980. A = 1980, B = 1981, C = 1982, etc.
Third letter or number is the vehicle assembly plant, in this case K for Kansas City.
Click image for larger version
ID:	313229   Click image for larger version
ID:	313244   Click image for larger version
ID:	313246   Click image for larger version
ID:	313247   Click image for larger version
ID:	313249   Click image for larger version
ID:	313250   Click image for larger version
ID:	313252   Click image for larger version
ID:	313253   Click image for larger version
__________________
Jim Forbes
my shtuff
offline   Reply With Quote
Old 05-23-2007, 12:02 PM   #2
Jalopy Joker
Old School HAMBer
Default Re: TECH: Chevy Engine Numbers
Thanks-hard info to find.
online   Reply With Quote
Old 05-23-2007, 12:24 PM   #3
Deuce Roadster
Deuce Roadster's Avatar
Good information for sure ... maybe this photo will help newbies find the locations that Squirrel listed ...
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 05-23-2007, 12:31 PM   #4
houtex63
houtex63's Avatar
nice, thanks for the info
Old 05-23-2007, 12:46 PM   #5
Flathead Youngin'
Old School HAMBer
Flathead Youngin''s Avatar
man, good stuff! thanks
__________________
Yeah, it's mustang 2'd, 350, 350, 9 inch, pro-streeted, mini-tubbed.......pretty cool, huh?
Old 05-23-2007, 03:09 PM   #6
AHotRod
Alliance Member
AHotRod's Avatar
Your a RULER !
__________________
Glenn
Old 05-23-2007, 04:11 PM   #7
fiat128
Senior Member
fiat128's Avatar
Cool tech, that's good info to have since there are so many Chevy blocks that are sitting around out of whatever they originally came in.
Old 05-24-2007, 02:36 PM   #8
Lucky Strike
Senior Member
Lucky Strike's Avatar
Very good info. Thank you.
I just want to add that if the number stampped on your block begins with "CE" then it is a counter exchange engine. The 327 I'm working on now has that and it is my understanding that a counter exchange motor is one that was replaced under warranty.
Essentially this limits the amout of information you can learn about the motor. All I know is that it is a replacment 327, and I found it in a 1967 3/4 ton chevy truck, but it has flat top pistons. I believe some trucks had dished pistons.
__________________
I'll round off that bolt head...just as soon as I'm done strippin' this screw!
Lucky Strike = Andrew Jackson W.
Old 06-01-2007, 10:48 AM   #9
dan34
Newbie
dan34's Avatar
Very helpful! I've been meaning to check what my engine came out of
Old 04-04-2008, 09:47 AM   #10
babyboomer
FNG
hey squirrel-thanks for the great info on deciphering engine numbers.I'm see where my inline 6 engine number F0803TPR breaks down to flint Aug. 03 truck but I can't find what pr stand for.Also casting number is 3994257 can't find that anywhere on the web either?Any help would be really appreciated.
Old 04-04-2008, 07:13 PM   #11
35Chevy.com
35Chevy.com's Avatar
Good info
I have two 1990 chevy 350's that dont have serial numbers.
They were built by Mercury Marine.
Im curious do the GM crate engines have serial numbers?
Gary
__________________
I think the monkeys at the zoo should have to wear sunglasses so they can't
hypnotize you.....Jack Handy
Old 04-04-2008, 09:20 PM   #12
Ratmotor
Alliance Member
Ratmotor's Avatar
My 454 has an oddball number that doesn,t show up anywhere...I guess that,s because it was originally a 330 horse Crusader marine engine out of a boat! The casting number does show up as a truck block.
Old 04-05-2008, 01:16 AM   #13
j-jock
Grenade Inspector
j-jock's Avatar
I also have a 1968 427 block with a serial number that I have never been able to place.
The number starts with CCxxxxxx.. , which doesn't match any car that I am aware of. I was wondering if it was a replacement block ( I have never seen any with serial numbers stamped on them ), or a Mercury Marine motor. All the moving parts, manifold, and heads are 435 horse. The crank is also a puzzle, it is a cross drilled, grooved crank, and I thought Chevy had stopped grooving the cranks.
Any help would be appreciated. I was going to put some flat top pistons in it, but have built up a 454 for my truck instead.
Bob
__________________
The only time when you can have too much gas, is when you're on fire..
Old 04-06-2008, 12:01 PM   #14
52 csb
52 csb's Avatar
Talking Re: TECH: Chevy Engine Numbers
ALL THAT INFO AND MORE IS FOUND ON THIS GREAT SITE http:www.mortec.com/location.htm if anybody is interested. LATER 52 csb
Old 05-13-2009, 05:06 PM   #15
ROADSTERJEFF
ROADSTERJEFF's Avatar
I just got 1955 chevy with the engine serial number KO613TJZ. What is it!
Jeff
Old 05-13-2009, 05:41 PM   #16
Old School HAMBer
squirrel's Avatar
1973 chevy pickup 4bbl 350.
__________________
Jim Forbes
my shtuff
Old 05-13-2009, 06:06 PM   #17
oilslinger53
Senior Member
oilslinger53's Avatar
Thanks for posting this squirrel, very helpful, as always.
__________________
I think I breathed too much rust...
Old 05-13-2009, 07:31 PM   #18
ROADSTERJEFF
Thanks for the input.
Old 05-13-2009, 07:50 PM   #19
Engine Pro 5X
Old School HAMBer
Engine Pro 5X's Avatar
Quote:
Originally Posted by AHotRod View Post
Your a RULER !
####----A Yardstick !!
__________________
GET IN THE TRUCK JETHRO!!! WE'RE GOING TO CALIFORNIA!!! SWIMMING POOLS!!! MOVIE STARS!!!***CAN I SHOW YOU MY BEST KIELBASA ???
Old 05-13-2009, 08:36 PM   #20
Ranunculous
Senior Member
Ranunculous's Avatar
Damn! My motor isn't a super deluxe hi-po 350;it's a 305 smogger?!
Thanks for the great info!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
