Reply
Thread Tools Display Modes
Old 05-17-2007, 03:59 PM   #1
George G
Senior Member
George G's Avatar
Default How do you install a trunk lid on A Model A?
I bought a new trunk lid for my '28 A Roadster. I am intalling it as a trunk rather than a rumble lid. I got a set of hinges from another vendor, but how do the hinge brakets mount on the trunk lid???
Any help or related website will be appreciated.
offline   Reply With Quote
Old 05-18-2007, 11:01 AM   #2
flathead okie
Alliance Member
flathead okie's Avatar
Default Re: How do you install a trunk lid on A Model A?
Try fordbarn.com if no one here can help.
__________________
It's not about cheeseball culture. It's about true gearheads with true passion...
Old 05-18-2007, 11:19 AM   #3
hiboy
Senior Member
hiboy's Avatar
the trunk lid just uses the holes in the flange to pivot on the hinge bolt. Where the bolt comes through the rain gutter is where the adjustment is.
Old 05-18-2007, 06:01 PM   #4
HairyCanary
Newbie
HairyCanary's Avatar
George, the two most outer holes are used to fasten that mount, shown in the picture, to the inside of each quarter panel. The center hole should have a threaded pin that threads into that mount and protrudes into the decklid hole.
Dave
Old 05-18-2007, 06:27 PM   #5
C9
C9's Avatar
Location: Kingman, Arizona - The place on the way to other places....
Here's a couple pics of my 31.
Note that the 2nd pic - shot taken directly from the rear - shows a single stainless flat washer on the pivot.
The right side has 3-4 washers on the pivot.
The washers are required to shim the trunk to the proper transverse location.
Click image for larger version
Name:	31 Trunk hinge.jpg
ID:	311156   Click image for larger version
Name:	31 Trunk hinge 2.jpg
__________________
Sailing the turquoise canyons of the Arizona desert.
C9
Old 05-19-2007, 10:32 AM   #6
George G
Senior Member
George G's Avatar
Thanks Guys! To get the inital location of the hinge bracket in relation to the lid itself, I was thinking I would have to set the lid on the car then screw in the hinge pins with some wet paint or something to get a mark on the lid.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
