Reply
Thread Tools Display Modes
Old 04-14-2007, 04:55 PM   #1
LEECOUNTYRODS
Grenade Inspector
LEECOUNTYRODS's Avatar
Default HELP: How to change a 6 Volt 51 Flathead to a 12 Volt
First off, if there is a post on this exact subject please shoot it to me. I looked, but didn't find what I was looking for.
I would like to know a guess on what it cost to change a 1951 Ford Flathead 8 from a 6 volt to a 12 volt. Also, how is it done? I appreciate your help all!!!!
__________________
All over it like a starving man on a Christmas HAMB
offline   Reply With Quote
Old 04-14-2007, 05:06 PM   #2
petebert
Grenade Inspector
petebert's Avatar
Default Re: HELP: How to change a 6 Volt 51 Flathead to a 12 Volt
I'm at work right now but when I get home I'll post a link to a page that has good info on the conversion.
Old 04-14-2007, 05:19 PM   #3
LEECOUNTYRODS
Grenade Inspector
I appreciate it!!!
__________________
Old 04-14-2007, 05:32 PM   #4
sinner13
sinner13's Avatar
Try here:
http://www.oldengine.org/unfaq/six12.htm
__________________
Messin shit up since "66"
http://www.myspace.com/nevercouldbenormal
Old 04-14-2007, 05:53 PM   #5
LEECOUNTYRODS
Grenade Inspector
Sinner, since my ride is all ready 12 volt system, all I need to purchase is a alternator and Ignition, does that sound right?
__________________
Old 04-14-2007, 07:40 PM   #6
sinner13
sinner13's Avatar
I thought it was a 6volt and you wanted to go to a 12volt ????
On my chev, I stuck a one wire alt in there and changed over the bulbs and put a battery in it. Im still using the stock 6 volt starter and stock ignition switch...with no problems at all...Not so sure about your flatty....
__________________
Old 04-14-2007, 08:09 PM   #7
Cadien
Newbie
Cadien's Avatar
Very easy especially if you already have a 12 volt system on the car. You'll only need a new coil and a 1 wire alternator. I use a Mallory unilite distributor on my 51 Merc and have no problems. Most of the supply houses like Hot Rod and Custom supply sell a little book on changing systems over to 12 volt. Cost a few bucks and has alot of information.
Here is a link to Speedway motors and the book:
http://www.speedwaymotors.com/p/2867...ion-Guide.html
__________________
"When the going gets Weird, the Weird turn Pro"
Old 04-14-2007, 08:18 PM   #8
Cadien
Newbie
Cadien's Avatar
OH, And your 6 volt starter on the Flathead will work fine on a 12 volt system. No need to change or convert anything there.
If you are running an original tranny with an overdrive then the solenoid will have to be converted to 12.
__________________
Old 04-14-2007, 08:22 PM   #9
I go pogo
I go pogo's Avatar
I use a stock 6 volt starter and distributor with a ballast resister in the wire to the coil.
__________________
Who lives in a pineapple under the sea?
Old 04-14-2007, 09:16 PM   #10
LEECOUNTYRODS
Grenade Inspector
This is great information and really appreciate it. Sinner here is alittle more in detail of what I meant. I built a 31 Ford making sure all components ran on a 12 Volt system. I just purchased a Flat head off a guy who was still running the 6 volt system. Anyway, it sounds like I do not need much at all so I should be on my way in a few weeks. Thanks guys!!!!!!!
__________________
Old 04-15-2007, 08:18 AM   #11
petebert
Grenade Inspector
petebert's Avatar
dosn't look like you need it any more but here's a 12v conversion link if anyone needs it.
http://home.earthlink.net/~philedmonds/id3.html
Old 04-15-2007, 08:21 AM   #12
sinner13
sinner13's Avatar
Cool beans....it's a fairly easy to do conversion...good luck
__________________
Old 05-26-2007, 07:08 PM   #13
LEECOUNTYRODS
Grenade Inspector
Thanks again
__________________
Old 09-20-2007, 01:10 PM   #14
1bdsinner
1bdsinner's Avatar
1 question on this post. What should I do with a stock voltage regulator on a 6 volt system? DO I jumper or splice any wires and shitcan it? Or just put a 12 volt in it and use the gm internal reg and external regulator? I am converting my 6 volt 53 ford to 12 volt. thanks for search option!
__________________
You sure would look funny piciking up your teeth off the floor with broken fingers!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
