Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board > New to the H.A.M.B.? Introduce yourself here!
Reply
Thread Tools Display Modes
Old 04-08-2007, 12:40 AM   #1
51special
Newbie
51special's Avatar
Default Correct Jet Size for a 600 cfm Edelbrock?
Just a quick question...I'm running a 307 Chevy in my '51 Buick, and a while back I threw on a 4 bbl 600 cfm Edelbrock. Since I've had that carb on there, it just hasn't run right. The carb was new out of the box. It's always run really rich,so what I figured is maybe I should change out the jets to lean it out? Does anyone know what size jets come with an Edelbrock 600 out of the box, and what jet size would best suit a 307 SBC? I'm not really concerned about horsepower, I just want to lean it out a bit. Thanks!
-Julian
offline   Reply With Quote
Old 04-08-2007, 01:33 AM   #2
NV rodr
Grenade Inspector
Default Re: Correct Jet Size for a 600 cfm Edelbrock?
If its a 1405 or 1406 (elec choke version) start here : remove the primary jets (should be .098) and set them aside. Take the secondary jets ( should be .095) and move them to the primary spots. Install a .092 in the secondaries. Then use your stock 7547 metering rods with an orange spring under the holder. (buy a spring kit) Turn both idle mixture screw all the way in to seat lightly then open them 1 full turn only. Should be a pretty close start. Pm me if you got questions.
Old 04-08-2007, 04:12 AM   #3
29bowtie
Old School HAMBer
29bowtie's Avatar
You should repost this on the main board,not the "NEW TO THE HAMB" board.You will get far more coverage.
__________________
"Remember Professionals built the Titanic, An Amateur built the Ark."
Old 04-08-2007, 11:00 AM   #4
51special
Newbie
51special's Avatar
Cool. Thanks for the response. I didn't realize I posted in the "New to the HAMB" section. Guess I shouldn't post when I'm about to fall asleep! Haha! thanks.
Old 04-09-2007, 06:54 PM   #5
Stude350guy
Stude350guy's Avatar
First, welcome to the HAMB, glad to have you.
Second try this site for help with your Eddy carb:
http://www.edelbrock.com/automotive_...ers_manual.pdf
Luck!
__________________
"Ain't no replacement for displacement!"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
