Reply
Thread Tools Display Modes
Old 03-30-2007, 02:21 PM   #1
JPMACHADO
Senior Member
Default What size clear tubing to bleed my brakes?
I tried to get a hold of Pete and Jakes to see what size clear tubing I need to bleed the GM Brake Kit they sold me. The one that adapts to the Ford style spingdles. They must be gone because they ALWAYS have great customer service. Can anyone help me out?
offline   Reply With Quote
Old 03-30-2007, 02:25 PM   #2
porknbeaner
Alliance Member
porknbeaner's Avatar
Default Re: What size clear tubing to bleed my brakes?
Quote:
No they're still there.
But what you're going to need is about 1/4 inch. Although I don't know why you need tubeing to bleed your brakes.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 03-30-2007, 02:28 PM   #3
JPMACHADO
Senior Member
The only way I know how to do it is to put the tubing in a jar of fluid and go until there are no bubbles.
Old 03-30-2007, 02:58 PM   #4
Relic Stew
Relic Stew's Avatar
The tubing and jar is the "one man" method. I use 1/4" vinyl tubing from Home Depot or wherever. Aquarium air line from the department store pet section is the same thing, but more expensive. I take it a step further and run the tube through the lid of the jar, seal it with silicone, then run another tube from the lid back to a vacuum port on the engine for the power vacuum bleeding. Need to keep the reservoir full though. A few pumps will suck the MC dry.
Click image for larger version
Old 03-30-2007, 03:12 PM   #5
Darby
Measure the diameter of the bleed screw. Grab a drill of the same size from your drill index. Take it to the pet store. Find a piece of hose that fits on the drill. /rocketscience
Old 03-31-2007, 01:40 AM   #6
Flingdingo
Flingdingo's Avatar
Get some vacuum hose and shove it over the bleeder screw, it's a lot more pliable than the vinyl hose, so the size doesn't have to be an exact match. You'll still see the bubbles in the jar.
Old 03-31-2007, 09:17 AM   #7
Frank
Senior Member
Frank's Avatar
Get a set of speed bleeeders and never worry about the tubing again. You just crack open the screw, get in and pump away. The have a one way check valve so you don't have to worry about it sucking in air. Once you've bled one out, tighten and move on to the next.
Old 03-31-2007, 09:27 AM   #8
brownbagg
Grenade Inspector
use a piece of black vaccum line and a old plastic 20 oz coke bottle. punch a hole in the plastic lid, thread the hose into it and bleed away
Old 03-31-2007, 08:38 PM   #9
55 dude
Old School HAMBer
55 dude's Avatar
other than power bleeding a system " reverse " bleeding them is the way they do airplane's, pushes all the air to the highest point.
Old 03-31-2007, 10:25 PM   #10
publicenemy1925
Old School HAMBer
publicenemy1925's Avatar
Reverse bleeding? Wild idea. Those airplane guys think totally differant than car guys. I use my mity vac gun, it has a bunch of differant tips to use and costs 30 bucks at sears. You can use it on other things to. Easy one man bleeding and fast too.
__________________
"In nomine Patris, Et Filii, Et Spiritus Sancti...Amen."
Old 03-31-2007, 10:28 PM   #11
Longbox55
Newbie
Actually, there is a tool on the market, the Pheonix Injector, that does just that. You hook up at the bleeder and force the fluid back to the m/c. Goes on the principle that air rises in a fluid. I've never used one, but i've heard they work really well. Supposed to be good for hydraulic clutches, too.
Old 04-01-2007, 01:24 AM   #12
36-3window
Old School HAMBer
36-3window's Avatar
i can't believe that this thread is at 10 posts...and that someone had to call the seller of the brake parts to figure out how to bleed them
i know guys come here to learn...........but , come on........
sorry to say this.....if bleeding the brakes with a hose is a real challenge for you , you should take some shop classes at the local votec , or in high school
this is stuff very 14 year old kid should know....and if you don't , there is something wrong with america....oh, shit.... that's right..schools have all dropped shop class
never mind
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
