Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 03-25-2007, 11:57 PM   #1
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Default TECH: Ultimate T-5 Article
The Ultimate T-5 Swap Article
There’s a lot of confusion regarding the Borg & Warner T-5 and which one to use in an early Ford car. Terms like world-class & non-world class are intermingled with gear ratios and torque ratings, shifter positions and speedometer drive type. This article should help clear up many of these issues.
The confusion surrounding which T-5 is best is understandable. An extremely versatile transmission, B&W modified this tranny to suit different applications several times over its 13-year production run (1982-1995) before being acquired by Tremec and discontinued for OEM use. In truth, the confusion stems from its versatility, and that’s a good thing.
Replacing an early floor-shift 3-speed requires a forward shifter location. This location is found in T-5 transmissions used in S-10, T-10, Astrovan, & Jeep transmissions.
While the T-5 was used by AMC, Ford, GM, Isuzu, Nissan, Ssang, & TVR (among others – even an agricultural sprayer!) This article will focus on three main OEM applications – Mustang, Camaro/Firebird, & S-10.
IDENTIFYING A T-5
There is only one positive way to identify which T-5 you have and that is by using the metal tag attached to one of the tail housing bolts. The number will look like this: 13-52-XXX, where XXX is a three-digit number unique to the specific make/model application. There are several online T-5 number decoders, but one of the easiest to use is found at http://www.5speeds.com/t5/index.html - at the bottom you can use the drop-down menu to select your three-digit suffix and find the original application.
Contrary to popular belief, you cannot tell gear ratios by application – only by tag number and then only if you have a comprehensive chart. So if your buddy tells you to get the T5 out of an S10 with a V6 because it has better gear ratios and/or it’s stronger, that’s simply not always true and you must reference the tag number.
World Class vs Non World Class
In the beginning, there was no WC/NWC discussion as all transmissions were NWC. The WC designation began in ’85 with Ford using it in the 5.0 Mustang first. F-Body (Camaro/Firebird) began using WC units in ’88. The S10 didn’t use WC until ’93. The differences between WC & NWC are principally in the bearings & synchros. Externally, there is one readily identifiable difference between WC & NWC (without having to know input sizes & spline counts) and that’s the front countershaft bearing retainer. The NWC has a one-piece design that looks like a large welch/freeze plug while the WC has a two-piece design that looks like two concentric circles. Here’s a pic of each (lifted from the HAMB):
World Class Bearing Retainer
Non World Class Bearing Retainer
’93 and newer GM WC T-5 use the Ford case and bolt pattern, so these will not bolt up to standard Chevy bellhousings.
In general, WC is stronger than NWC, newer transmissions are stronger than older ones, and higher first gear ratios are stronger than lower. The torque ratings are guides and typically represent shock ratings. It is generally accepted that WC units can be made to live behind about 400hp as proven by the 5.0 Mustang crowd. There is no hard and fast rule – if you hammer it, it will break.
Input Shafts
Ford NWC & WC (except 4-cyl) units used a 1-1/16” 10-spline input shaft. The ’94-95 Mustang T5 had a 0.67" longer input shaft & uses a unique bellhousing for the SN-95 platform. However, this input shaft can be swapped with an ’89-93 Mustang input shaft.
GM used a two different input shafts. The input shaft used behind V8 engines (both WC & NWC) was 1-1/8” 26-spline while the input shaft destined for 4/6 cylinder engines was 1” 14-spline. The exception to that is the ’93-’96 V6 F-body applications which used the 26-spline input shaft & the Ford case.
Speedometer Drives
Early T-5 used a typical gear-driven, cable speedometer drive while many late T-5 used an electronic speedometer drive. In GM applications, the changeover is about ’89. Ford used cable speedos through T-5 usage.
WHICH T-5 TO USE
S10
The S10 T-5 has garnered most of the attention due to its favorable shifter location. The S10, however, was a NWC unit through ’92. There are two basic gearsets available in the S10 T-5:
1st – 4.03 2nd – 2.37 3rd – 1.49 4th – 1.00 5th – 0.86
1st – 3.76 2nd – 2.18 3rd – 1.41 4th – 1.00 5th – 0.72
As a general rule of thumb, regardless of engine, ALL S10 T-5 prior to ’85 received the 4.03 gear set, while ALL S10 T-5 after ’86 got the 3.76 gearset. The “S10” T-5 was also available in the equivalent GMC T-truck.
The speedometer changed to electronic with the ’90 model year, however, some ’89 model T5 came with electronic speedos if they were equipped with the optional digital dash. These can prove problematic for swaps, but output shafts & tail housings can be swapped with cable-driven speedo models.
The Astrovan T-5 is worth mentioning. With an offset shifter which can be replaced with an S10 shifter, it makes a good candidate for swaps too. The 4-cyl vans used the 3.76 gearset, but the ratios found behind the V6 are better than the S10:
1st – 3.50 2nd – 2.14 3rd – 1.39 4th – 1.00 5th – 0.78
Tag Numbers:
S/T Truck – 4.03 Gearset – 010, 012, 013, 014, 033, 042, 043, 055, 056, 057, 058, 146
S/T Truck – 3.76 Gearset – 107, 108, 110, 136, 145, 186, 191, 192, 193, 201
Astrovan – 3.76 Gearset – 170, 180, 190
Astrovan – 3.50 Gearset – 101, 148, 149, 164, 179, 189
Mustang
Introduced in ’83, the T-5 arguably gained its fame in the Mustang 5.0. The first to take the step up to WC in ’85, Ford used the T-5 through the Fox-body & SN-95 chassis ending in ’95. The strongest T-5 available was found in later Mustangs and available through Ford’s Motorsport & SVO operations.
Available with a few different gearsets, the most common gearing was from ’85 through ’95:
1st – 3.35 2nd – 1.99 3rd – 1.33 4th –1.00 5th – 0.68
The other V8 gearset used was the NWC ’83-84:
1st – 2.95 2nd – 1.94 3rd – 1.34 4th – 1.00 5th – 0.62
Ford rated their T-5 anywhere from 260lb/ft to 335lb/ft depending on the application. In ’89, stronger alloys were used upping the torque rating from 260lb/ft to 300lb/ft. The 310lb/ft rating belonged to the ’93-94 Cobra spec T-5 and an aftermarket-only Z-spec T-5 was available with 335lb/ft.
The late-model (94-95) 3.8 V6 T-5 was rated at 265lb/ft, had the slightly longer input shaft, and had the following ratios:
1st – 3.35 2nd – 1.93 3rd – 1.29 4th – 1.00 5th – 0.73
Tag Numbers
NWC V8 – 034, 065
3.8 V6 – 220, 236
V8 260lb/ft – 126, 165, 169, 141
V8 300lb/ft – 199, 204, 208, 246, 218, 219
Z-spec 335 – 249, 251
SVO – 200, 202
Cobra – 239, 242, 253
GM F-Body
GM used the T-5 in F-body cars behind all engines. In general, the I4/V6 got the following ratios:
1st – 3.50 2nd – 2.14 3rd – 1.36 4th – 1.00 5th – 0.78
Although some 4-cyl cars got the 3.76 gearset as used in the S10 & a few V6 cars actually got the 4.03 gearset.
The V8 F-bodies typically got the following Gearset:
1st – 2.95 2nd – 1.94 3rd – 1.34 4th – 1.00 5th – 0.73
It’s worth noting again that the ’93-95 F-body V6 cars got a Ford case with a GM input shaft. There were no V8 T-5 during these years.
Tag Numbers
V8 2.95 NWC – 028, 062, 070, 072, 157, 185
V8 2.95 WC – 159, 160, 175, 176, 195, 196
3.50 NWC – 015, 027, 061, 156
3.76 NWC – 054, 083, 158
4.03 NWC – 181
4.03 WC – 177
NWC Other (unk app/gears) – 071, 084, 150, 166, 178, 182, 183
WC Other (unk app/gears) – 197, 212, 213, 214
WC Ford Pattern – 210, 245, 247
ADAPTING THE T-5
Shifter Placement
The Mustang and F-body T-5 both have rear mounted shifters at the end of the tailshaft. These often make difficult swaps and shifter placement, particularly in early Fords, is untenable.
L-R Early Ford Toploader, S10 T-5 w/Adapter, Mustang T-5
The S10 T-5 is often selected due to the shifter placement (approx 7” further rearward than early Ford), but typically lacks desirable gear ratios or the increased strength of a WC unit. Because of the T-5 excellent interchangeability, the tail housing and top cover from an S10 can be swapped onto other T-5. There are a few issues when doing this.
The first is a small plastic oiling funnel found on the countershaft and retained by the tail housing. These are different from WC to NWC, but it is primarily due to changes in the tail housing casting, not an internal oiling issue. Consequently, this plastic funnel should stay with the tail housing. So, use the S10 plastic funnel when swapping an S10 tail housing onto a WC T-5.
T-5 Countershaft Oiling Funnels
The second issue is that of speedometer gear. Typically, when installing an S10 tail housing and top cover onto a WC T5 from a Mustang or F-body, the speedo gear will no longer align with the driven gear mounting hole in the housing. The output shaft has a built up area where the speedo drive gear mounts with a clip. Moving the gear requires building up the output shaft with shim stock. An excellent example of how to do this is found on the inliners websit at: http://www.inliners.org/Jack/T5tech.html
Finally, if putting an S10 tail housing onto a Ford T-5, you will probably have to change the tailshaft bushing for the Ford one. This is due to different diameters of the output shaft.
Adapters
Adapting a GM (pre-’93) T-5 to any other GM product is pretty straightforward. Just find a bellhousing that will accept any standard Chevy-style transmission and bolt it all up. You’ll have clutch linkage to sort out, but putting the trans behind the engine is easy.
Adapting a Mustang T5 to a post-64 Ford bellhousing is pretty straightforward too. A thin, flat-plate adapter used by the early Mustang crowd is all you need. However, the easiest solution is to use the bellhousing from a late-model 5.0 Mustang – no adapters required.
65-Up Ford Adapter
Adapting a Mustang T5 to a ’49-64 Ford bellhousing is also relatively easy. The bottom two bolts line up well, one top bolt will need to be re-drilled, and the other top bolt will likely need an ear welded onto the bellhousing to finish it all off.
When adapting a GM T5 to a Flathead Ford, there are several options. Offenhauser makes two adapters – one for the early, internal clutch linkage and one for a more modern clutch fork. Speedway sells their own version of these adapters for a little bit lower price. Cornhusker also sells a complete kit with the adapter and other items (like pilot bushing, input shaft sleeve, etc).
Speedway Clutch Fork GM Adapter
Another option is to use a machined flat plate and the “hogshead” or mini-bellhousing from a ’46 and up Ford truck 4-speed. Dwight Bond (eBay ID 007Dwight) in Gibbon, NE sells these for very reasonable and you’d be hard pressed to buy the material and pay for the machining for what he asks. He also has the special pilot bushing and input shave sleeve. There are also plans for the flat plate available from George Greenbaugh (eBay ID community-chest) for the hard-core do-it-yourselfers.
Dwight Bond Flat Plate Adapter on Hogshead
To use the Ford pattern T-5 behind a flathead is a bit more work, but a company in New Zealand, Mac’s Speed Equipment, builds this adapter. Their webpage is: http://www.macsspeed.com/adapters_2.html I believe Vern Tardel also makes an adapter to use the Ford T-5 behind a flathead.
Input Shafts
As mentioned, input shafts vary by application and there are three general sizes, Ford, Chevy V8, and small Chevy. When adapting the T-5 to a flathead, or many other early engines, the input bearing retainer where the throwout bearing rides may be too small if using the original throwout bearing. A simple sleeve-type adapter can be used and are easily made by any competent machine shop, or readily available either in kits from Speedway or Cornhusker, or separately from Dwight Bond and others.
Clutch Disks
As a rule of thumb, any clutch disk that has the correct input shaft size/spline count and correct diameter for the pressure plate will work. The Astrovan clutch disk seems to be popular when doing the flathead conversion, but check the clearance on the flywheel retaining bolts. Some clutch disks will not clear the bolt heads and cause problems later on. The very best option is to have the correct center hub installed on the flathead disk by a good clutch rebuilder.
Shifters
One of the T-5 weak points is the stock shifter. There are no positive stops on the shifter itself, so it is easy to “over shift” the transmission. This can cause bending and cracking of the shift forks and is most notable when really banging the gears hard. This flexing of the shift forks will result in damage to the synchros. One of the best things you can do, especially if you like to shift hard or fast, is to use an aftermarket shifter with positive stops that are correctly adjusted in accordance with the manufacturer’s recommendations.
Shifter handles can be modified simply by cutting off the original shifter and welding on the handle of your choice to the stub. Some shifters are two-piece with a rubber isolator that can be torn off and a new handle welded on. If you use a Mustang transmission, the shifter handles merely bolt on to the stub.
Throwout Bearings
Which throwout bearing to use will depend on specifics of your swap. If you’re running a flathead in an original Ford frame, it may be best to use one of the adapters that allows you to retain the stock clutch linkage and throwout bearing. This will provide the neatest solution.
Hydraulic slave cylinders are easily adapted in both push and pull configurations and may be the best way if building from scratch or using a less common setup/swap. In this case, use a throwout bearing that will readily adapt to your linkage. In some cases, you may have to sleeve the input bearing retainer, while in others, you may use a T-5 OEM throwout bearing.
Hydraulic throwout bearings are also available, but reviews and results are decidedly mixed and they tend to be quite pricey.
MISCELLANEOUS
Rebuilding
The T-5 is as straight-forward as most other modern manual transmissions and require a minimum of specialized tools. Two excellent resources are available online, the Borg-Warner Technical Service Manual here: http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf and a good how-to rebuild manual here: http://pomoforacing.com/tech/T5Rebuild2002.pdf
Endplay is the key to any manual tranny and the T-5 is no exception. Shim packs are still available from Ford and small parts kits are available from several sources online.
Oil
All NWC T-5 use 70WT Gear Oil or Redline MTL.
ALL WC T-5 use ATF.
Do not use gear oil in a WC T-5. Use a quality synthetic oil (regardless of which type you need to use) & change it frequently (every 15-20K). Fill to the fill plug – about 5-1/2 pints or 2-1/2 quarts.
Open Drive
For a flathead conversion, you’ll probably need to convert to an open drive setup. Hot Rod Works and Speedway, as well as several others, sell a conversion kit for your banjo rear. Alternatively, you can swap to a modern rear like an 8” or 9” rear. You will need to replace the torque tube with some sort of locating device if modifying your banjo – the stock radius rods simply aren’t up to the task.
Closed Drive
While I haven’t done it yet, I am in the process of converting a Jeep T-5 transmission to accept the torque-tube and stock early Ford U-joint. This should require crossmember modification, spline adapter, flat-plate adapter to accept the bell mount, and shortening the torque-tube/driveshaft. I will post this on the HAMB when I complete it. Who knows, maybe I’ll produce a kit if I’m successful!
Jeep T-5
RESOURCES
The following is a list of various websites. Most are pretty good, nearly all also have errors (like I’m sure this article does too). Most errors, are errors of omission that can lead to misunderstanding or confusion, however, there are some errors of fact on many of these pages.
http://www.vanpeltsales.com/FH_web/t5_fivespeed.htm
http://www.flatheadv8.org/t5-swap.htm
http://www.moderndriveline.com/Technical_Bits/t5_history.htm
http://www.jalopyjournal.com/forum/showthread.php?t=169265
SOURCES
Jim O’Clair, T-5 Transmission Swaps, Hemmings Muscle Machines, July 04
Hokey Assed Message Board, http://www.jalopyjournal.com
Inliners International Board, http://www.inliners.org
POMOFO Racing, http://pomoforacing.com/
Transmission Technologies Corporation, http://www.ttcautomotive.com/
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch!
T5 Tech
offline   Reply With Quote
Old 03-26-2007, 12:03 AM   #2
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Default Re: TECH: Ultimate T-5 Article
I've got this saved as both a MS Word .doc here:
http://putstuff.putfile.com/61994/7594287 (300KB)
And for those w/o MS Word, a rich text version here:
http://putstuff.putfile.com/61992/9827767 (BIG - 9MB)
I've been threatening to compile this info for a long time & finally got off my arse & did it. It's meant to be a one-stop FAQ for the more common questions. I'm in no way a T-5 expert, but I have been playing with them since '90-91 or so.
Lemme know of any errors & corrections & I'll go in & fix 'em!
Enjoy!
__________________
T5 Tech
Old 03-26-2007, 12:15 AM   #3
Bib Overalls
Alliance Member
Bib Overalls's Avatar
Thanks!
__________________
An Old California Rodder
Hiding Out In The Ozarks
http://www.flickr.com/photos/ratpoison/
Old 03-26-2007, 07:47 AM   #4
krusty40
Alliance Member
Ernie - thanks for doing this! You ARE the T5 ruler. vic
__________________
"The world of traditional hot rodding is a pretty damned wonderful place." Ryan
Old 03-26-2007, 08:02 AM   #5
myke
Senior Member
myke's Avatar
Thanks for the info!
Who makes an aftermarket shifter for them?
__________________
Who cares what other people think!
Old 03-26-2007, 08:34 AM   #6
UPSrodder
Alliance Member
UPSrodder's Avatar
excellent information, been doing a lot of research myself. Most of mine came for here or the stovebolt page. You have gone above and beyond. Got this thread saved for sure. Thanks again
__________________
Keep it simple, basic and cool!
Old 03-26-2007, 10:11 AM   #7
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Quote:
Hurst is probably the best source for anything other than Mustang shifters. For the Mustang, there are probably a dozen good aftermarket shifters - might be a couple for F-body too.
I have an idea that will put positive stops on the stock S10 shifter, but haven't tried it yet. Basically a collar bolted to the round part of the shifter with one small bolt going through the collar as a locking/locating device. Then just weld tabs up in front & back to accept bolts. Hard to describe, really.
Quote:
No, not really. I've just been tinkering with these for a while. There are loads of folks who do this for a living & I pick their brain.
__________________
T5 Tech
Old 03-26-2007, 10:57 AM   #8
Dirty Dug
Senior Member
Great article but I have one question. Can I use the S-10 pressure plate with the stock Ford throwout bearing behind a '50 flatty?
online   Reply With Quote
Old 03-26-2007, 11:15 AM   #9
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Quote:
I don't believe the S10 pressure plate will bolt up to the flathead flywheel. I guess you could have the flywheel redrilled to accept it...try it & find out.
__________________
T5 Tech
Old 03-26-2007, 01:07 PM   #10
Dirty Dug
Senior Member
I did have it drilled to fit but wonder if the stock throwout bearing is compatable with the fingers on the S-10 pressure plate.
Old 03-26-2007, 01:15 PM   #11
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Well, you should have decreased pedal effort - the diaphragm-style clutch is much easier to operate.
I don't know what kind of throw is required to disengage a diaphragm-style clutch, but would imagine it to be less than the borg & beck or long style. I see no reason why it shouldn't work in your application, but you'll have to mock it all up & see.
One thing to watch out for is over-centering the fingers on the pressure plate. You may have to play with pedal ratios a bit to get that sorted if it's a problem.
Bottom Line - you'll have to mock it up & see.
__________________
T5 Tech
Old 03-26-2007, 01:36 PM   #12
Dirty Dug
Senior Member
Since I would have to mock it up and mount the pedals I think I'm better off just using a flathead pressure plate. Thanks for the help.
Old 03-26-2007, 02:30 PM   #13
FoMoCo_MoFo
Senior Member
FoMoCo_MoFo's Avatar
limeworks sells a real nice one as well as a real nice e-brake set up
www.limeworksspeedshop.com
__________________
Jeff G. Holt
www.crowncycleco.com
www.fomocomofos.com
Old 03-26-2007, 11:40 PM   #14
Rocky
Classified Editor
Rocky's Avatar
Great article but I found a possible error. The text says all chevy W/C from 93 up use the ford bolt pattern. I took the world-class T-5 outta my bone-stock 93 S-10 ]with a 2.8 V/6] and the bolt pattern was most definetely chevrolet. I bolted the tranny to a Speedway adapter used to adapt a GM [muncie 4 speed type] tranny to the early 59-AB, ford flathead. Bolted right up after I installed the correct pilot shaft bushings and bearing retainer adapter bushing.....all stuff that came in the Speedway [offenhauser] kit. I also had to lop off about 3/8ths inch from the end of the pilot stub and run a 1/2 inch drill bit through the metric mounting holes in the tranny case so I could use 1/2 inch mounting bolts...
I also noticed the early S-10 4 banger T-5 with it's smaller bolt pattern wasn't addressed. I have one of these old non W/C trannys I'm adapting to a stock chevy pickup V/8 cast iron bellhousing. I'm gonna have to re-drill and tap new mounting holes for the top 2 mount holes and make up some "L" shaped brackets to utilize the bottom 2 mounting holes in the tranny case......right now there's nuthin but air to bolt to on those bottom 2 bolts...
Just some ramblings.
__________________
"The difference between genius and stupidity is that genius has its limits."--Albert Einstein
Old 03-27-2007, 12:20 AM   #15
a/fxcomet
Alliance Member
So the shifters are different between the different makes? I have a S10 T5 out of an 83ish truck. I'm looking for a newer mustang t5 to mate it with. I was kinda hoping I could use a mustang aftermarket shifter, but I hadn't researched that yet.
__________________
-Walt-
There isn't an off position on the genius switch.
Old 03-27-2007, 12:21 AM   #16
a/fxcomet
Alliance Member
Oh, and THANKS for taking the time to type all of this up!!!!!!!!!!!!!!!
__________________
-Walt-
Old 03-27-2007, 12:51 AM   #17
HHRdave
Senior Member
HHRdave's Avatar
EXCELLENT article. Thanks!
Old 03-27-2007, 02:32 AM   #18
Chopped50Ford
Old School HAMBer
Chopped50Ford's Avatar
Great article...thanks
__________________
Check it out!
Vintage Metal
Vintage Metal Girl
Custom Handbags For your Hot Rod Girl
Old 03-27-2007, 06:47 AM   #19
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Quote:
Rocky - all my research said '93 & up. I've only ever dealt with a '94 & it was definitely the Ford bolt pattern - maybe '93 was a transition year? I will have to research this some more - thanks for the heads up!
I also dropped the ball & failed to mention opening up the holes on the trans - it's these little things you take for granted that get left out. Thanks again!
I purposely left out all 4-cyl application from Mustangs. The only "possibly" odd S10 4-cyl I've never put my hands on is the diesel version. You got pics of this early S10 4-cyl one with small bolt pattern?? PM me if you do - never even heard of it...
This is exactly the feedback I'm looking for! Thanks!!
__________________
T5 Tech
Old 03-28-2007, 07:57 AM   #20
bones35
Grenade Inspector
bones35's Avatar
can these tranny's really hold up to torque motors in racing conditions. im wanting a overdrive for a daily driver-drager.
__________________
" If things go well i might be showin her my Ohh Ohh face"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
