Maybe this will make it easier than it just being a comment in another thread... TECH: Zoomie baffles, a monkey can do it TECH ... cooling a SBC with a mechanical fan. Tech: Filling radiator hole in '32 truck grill TECH - AD truck gauge resto / reface TECH:Upholstery 101 - Seat Covers (Dial-up warning lots o' pix) Tech- A simple way to adjust valves TECH......Adding body line w/big grinder. TECH: Roadster seat upholstery simple and easy TECH: Chopping my 50 chevy coupe TECH---New way to use Buick drums. More Lo-Buc Tech: Eliminating Hot Start prolems on GM TECH: 5 hole wheels on 38 chevy I-beam TECH---oil filter/coolant tank Tech: Fabricating rocker panels, floor, trans tunnell TECH - Keeping the Boss Happy during a Build TECH: From left over parts to a Model A truck! Tech Week/Drop Light Bulbs TECH: Inexpensive but rigid exhaust hanger TECH: Air filter from scrap. Tech: Woodgraining videos. TECH: Affordable taller legs for your Advanced Series Truck TECH: Roadster type Windshield from scratch Tech Week/Shop Safety Low Tech. How to get more leverage w/ a combination wrench TECH: Gene Winfield chops a 51 Ford PU @ WCC in MI TECH: Cheap steering column speedo mount Tech: Shortening an I beam axle TECH...Floor and f/wall fab in Anglia. Tech- Holesaws and sheetmetal. Tech : Low Buck Engine Turning TECH---Wiring harness made easy. TECH: Banger trans swap..... tech cutting circles with a plasma with found parts Tech - JB Weld Patch Panel Tech-Pretty Blind Rivits TECH=History=Terms, Racing TECH: Basic FLATHEAD intake and carb identification TECH : low-buck ideas that I've used TECH...Save that old heater Tech Tachometer re-scaling HA/GR Car 1st time TECH: Cad-LaSalle Shifter Bracket Legislative TECH..How to stay in the loop. TECH Old timey trick to remove axle TECH Chopping a 49-50 Merc the Barry Mazza way TECH- Be good to your WOOD! Bandsaw/Chopsaw tech...accessories! TECH- Build an air compressor TECH....Ten homemade hot rod shop tools. TECH: Vinegar vs Rust Take a Picture Buddy! It'll Last Longer TECH TECH - Firewall clearance issues...save those valve covers! tech garage door lights TECH: start to finish custom / gasser budget build. TECH: Mock Ups Made Easy TECH: 40 Ford Coupe jump seats and we're off... I'll ad more as they come along..
