Reply
Thread Tools Display Modes
Old 02-12-2007, 09:03 AM   #1
Jobe
Senior Member
Jobe's Avatar
Default How to get dead car onto trailer?
hey all,
I'm looking to buy a 62 caddy parts car that doesn't have an engine or tranny. How would I put this onto a flat bed trailer? Could I use a come along puller? Tow straps from my truck and pull it up that way? winch?
I'd like to do this myself and not have to call a hauler/transporter.
thanks for any tips.
bryan
online   Reply With Quote
Old 02-12-2007, 09:07 AM   #2
paintfumesmahgee
Grenade Inspector
paintfumesmahgee's Avatar
Default Re: How to get dead car onto trailer?
Our trailer is a tilt. And has a winch on it. Works really well. We just recently pulled a 58 brookwood wagon up on it with no problem. The winch is an add on item. I don't know the company off hand, but works really well. Just hooks to the battery on your truck. and has a bracket on the trailer so ou can take it on and off.
__________________
...Clowns to the left of me, jokers to the right...
offline   Reply With Quote
Old 02-12-2007, 09:08 AM   #3
CG
Alliance Member
CG's Avatar
I use come alongs and a 10ft cable with eyes on both ends. Bring it up as far as I can, block the tires, move the come along and cable, bring it up further, etc etc. Takes awhile, but if you dont have help or an electric winch. Biggest and heaviest thing I did this way was a 72 3/4 ton truck with a big block. I may have been sweating a tad when I finished.
__________________
Check out the 62 Unibody build with nephews 13 and 15
Mark
Posted using my Progresso Soup Can phone
Old 02-12-2007, 09:15 AM   #4
bcarlson
bcarlson's Avatar
I did the same thing with my '53 F-100... it's not so bad. Get a good come-along, and some chains to secure it when you re-adjust the comealong.
Also, I wish I had done this, but didn't... if it's been sitting in the same spot for a long time on soft ground, try to pull it ahead a full cars length with a truck or skidsteer before trying to get it on the trailer. It might break the wheels free if they are stuck, and it'll get the car out of any tire holes.
Ben
__________________
http://www.drillist.com - Hot Rod Classifieds Done Right.
Old 02-12-2007, 09:19 AM   #5
47bob
Assuming you have aired up tires; winch it on with a come-a-long.
Old 02-12-2007, 09:21 AM   #6
budd
Old School HAMBer
budd's Avatar
when i went to pick up my truck i found out all the wheels were seized up and the tires wouldn`t hold air, so we towed it out of the shead/chicken coup with the farmers tractor, backed the trailer up to the front of the truck, unhooked the trailer and blocked the wheels and used the farmers tractor to tow it onto my trailer. then when i got home i chained the truck to my backhoe and pulled the trailer out from under the truck, all went pretty smoothly.
Old 02-12-2007, 09:23 AM   #7
Mudslinger
Senior Member
Mudslinger's Avatar
Comealong and chain, done this so many times. Tires can be flat as long as the frame doesnt catch it will drag it.
__________________
Looking for 49-50 Oldsmobile Grille and Bumper.
41-48 Ford passenger sheet metal.
Old 02-12-2007, 09:24 AM   #8
HotRodFreak
Senior Member
HotRodFreak's Avatar
Come along will do it.
Come along aerobics will keep you warm.
OR...rent buy or borrow a winch.
Old 02-12-2007, 09:25 AM   #9
heavytlc
Alliance Member
heavytlc's Avatar
I have a winch on the front of my tow rig. I run the cable under the truck, over the front of the trailer and pull cars onto the trailer that way. I have used my tie downs to pull cars on before. A lot of work, but you get the trailer as close as you can, pull the car as far as you can until you have as much stap in the rachet as will fit, hook up a second strap so you can release the first. It takes awhile. A come-along is a better manual method, but not 100% needed.
__________________
Jason Tharp 828-273-2001
Old 02-12-2007, 09:25 AM   #10
BenW455
BenW455's Avatar
If using a come a long take a friend so he can take over when you get tired. Sam's club sells a 8'000 pound winch for a little over 300.00 that you could mount on your trailer. Good luck and post pics when you get it. Ben
Old 02-12-2007, 09:26 AM   #11
boozoo
Alliance Member
boozoo's Avatar
Yep... that's how I did the '47 parts truck.
Takes a little while.... be careful and "think safety" and you'll be fine.
Old 02-12-2007, 09:32 AM   #12
cadillac dave
Quote:
Originally Posted by coopercruisers
hey all,
bryan
blow the tires up as much as you can. less surface area on the gound the easier it rolls. and most important is be safe. don't use under strength cheap ass cumalong or you might end up with broken cable..and worse yet a broken jaw when the cable hits you...buy a good quality cumalong..make sure someone else knows where you are and what you are doing. so you can call them when car is safely loaded. that way you are not hurt in the middle of nowhere and nobody knows where you are....safety first good luck cadillac dave
Old 02-12-2007, 09:40 AM   #13
Jobe
Senior Member
Jobe's Avatar
thanks for all the tips guys, I appreciate it.
I'm mainly concerned with the weight of the vehicle. My 62 with engine and tranny is pushing 5,000 pounds. I'm guessing without engine and tranny it's about 4200-4500.
Old 02-12-2007, 09:42 AM   #14
C9
C9's Avatar
Location: Kingman, Arizona - The place on the way to other places....
1600# boat winch on flatbed trailer.
1800# boat winch in box trailer.
Either winch will pull a complete 50 Plymouth on board easily.
Use chocks under the wheels as you go.
Draggin' a 2200# roadster on is easy.
I've used come-alongs in the past, but the two ton model I had took forever to pull a 39 sedan onto the flatbed.
The boat winches are considerably faster.
Boat winches are fairly reasonable in cost.
The 1800# one I bought about 3 years ago cost $32. or so.
The cable is extra.
An easy way out for mounting a boat winch on a flatbed trailer is to lay it on it's side on the right front corner.
Use a snatch block to make the 90 degree turn for a direct pull up the trailer bed.
My little brother had his flatbed trailer winch mounted on it's side and I think all it took was an additional strap of metal for proper bracing.
Click image for larger version
Name:	Car Show 2003 035 small.jpg
ID:	276559   Click image for larger version
Name:	31 in trailer small.jpg
__________________
Sailing the turquoise canyons of the Arizona desert.
C9
Old 02-12-2007, 09:43 AM   #15
59 brook
59 brook's Avatar
harbor freight or northern tools sells an inexpensive winch that hooks over a trailer ball and works off 12 volts less than a $100 .I have used this kind to load a few wagons chevy and ford some with flat tires cause the old tires wouldnt hold air . this does strain the winch as it shut down on the breaker once and i have had 2 go bad over the years but a good come along isn't much cheaper and it's a lot more work. only downside to the cheap one is only powers in .they used to sell one for around$125 which powered in and out
Old 02-12-2007, 10:13 AM   #16
BAD ROD
Senior Member
BAD ROD's Avatar
A week ago I put my 1959 Ranchero on a car trailer with a come-a-long. Works slick, just 1/2 inch at a time!
Mike
__________________
My first HAMB post.
Old 02-12-2007, 10:16 AM   #17
36-3window
Old School HAMBer
36-3window's Avatar
if you use a come-a-long , be carefull...they can be finger pinchers
and stay out of line with the cable , in case it breaks
Old 02-12-2007, 11:13 AM   #18
Neophyte
Grenade Inspector
Neophyte's Avatar
My issue with a come-a-long is to release the tension everytime all the cable is used up. I do sometimes actually use my chain block to pull a car on a trailer. After you've chocked the wheels it's eeasy to release the tension on the chain. I've even used it to unload as well when you can't let the car just run off the trailer by "lowering" it down.
__________________
My '34 Chev sedan progress: http://www.jalopyjournal.com/forum/showthread.php?t=195096
"So what do we do? Anything - something. So long as we just don't sit there. If we screw it up, start over. Try something else. If we wait until we've satisfied all the uncertainties, it may be too late" - Lee Iacocca, Former Chairman of Chrysler Corporation
Proud member of the Reef Street Rod Club, South Africa and webmaster of their site @ http://www.reefstreetrodclub.za.org
Old 02-12-2007, 11:21 AM   #19
haring
Senior Member
haring's Avatar
Whatever you do, be careful.
I've seen a winch cable break on a two rig, and it's scary.
I've also seen 4 large men lose control of a car as they were manually pushing it up into a box trailer. It started to roll back down the ramp. That's one way to motivate old men to take up running.
__________________
Don Haring, Jr.
Philadelphia-ish, PA
Old 02-12-2007, 03:56 PM   #20
39 Ford
Senior Member
Get a comalong and a long piece of chain, You may have to block the rear wheels several times while you reposition the rig as it comes up the ramps. This works for me, good luck.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
