Reply
Thread Tools Display Modes
Old 02-09-2007, 12:45 AM   #1
Hans
Grenade Inspector
Hans's Avatar
Default How to make a straight axle handle
I am trying to get my thoughts together on the best performing straight axle front suspension.
Any suggestions?
i was thinking some type of spring over would be the strongest.
__________________
I miss those nights at the bar with every girl all loaded like freight...
offline   Reply With Quote
Old 02-09-2007, 02:05 AM   #2
Mr 42
Senior Member
Mr 42's Avatar
Default Re: How to make a straight axle handle
The important thing here is Spring and shock's.
Ford did keep on lenghten the tranverse front and rear springs, until 42-48 that have the longest springs.
So maybe you should try to incorporate those spring.
Old 02-09-2007, 06:38 AM   #3
gahi
4 link and coilovers.
Old 02-09-2007, 07:01 AM   #4
jusjunk
Old School HAMBer
jusjunk's Avatar
whats the big deal?? transverse leaf pete and jakes shocks 4 bar or wishbones or hair pins?? no wishbones or pins on a tube axle. Set the caster at 7 degrees toe it in 1/8.. go for it. If everything is new or at least tight it should handle well. I also use a stabilizer on my 32 and i never drove this one without one so i dunno if it helped or not but the price was right so i put it on. oh ya vega box and pan hard rod also
Dave
Old 02-09-2007, 07:27 AM   #5
JohnnyFast
JohnnyFast's Avatar
Location: Duluth, MN (Hey, Al....where's that global warming ?)
Leave the wishbone intact like Henry designed it. Install a roll stabilizer and a panhard bar. Suspend with adjustable torsion bars. Use adjustable (rate and valving) shocks.
Make sure that everything is fitted properly.
__________________
JohnnyFast (aka SJFast)
Fenders ? We don't need no stinking fenders !!
Old 02-09-2007, 07:54 AM   #6
ELpolacko
Old School HAMBer
ELpolacko's Avatar
From my experience some of the best handling beam axle front ends have split wish bones or hair pins. I would ditch the buggy spring in favor of a pair of coil overs, my preference would be Bilstiens but a high quality adjustable like a Koni would work very well. And I would add an anti-roll bar, something adjustable would be desireable.
You should not ignore your wheel and tire selection, A neutral to positive offset wheel would keep the scrub radius down and give you less kickback under hard cornering. Obviously a performance tire would be desired.
__________________
Visit my Social Group: Industrial Chassis Inc, Facebook , WEBSITE or Instagram
Old 02-09-2007, 08:04 AM   #7
macsratz
Alliance Member
macsratz's Avatar
I agree 7 degrees or more, play with your spring rate, use a quick ratio steering box
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
