Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 02-03-2007, 11:29 PM   #1
Locomotive Breath
Locomotive Breath's Avatar
Default The Original Big Block Ford
Just thought I'd share some before and after pictures of my Ford GAA tank engine. All aluminum 1100 cubic inch V8 used in WWII Sherman Tanks. These were gas burners rated at 500 HP and 1050 Ft. Lbs. of torque for military service, but are capable of much much more using mostly stock parts. They feature a 60 degree vee, 5.4 bore x 6.0 stroke, 180 degree factory billet cranks, pent roof combustion chambers, shaft driven DOHC's, 4 valves per cylinder, and dual mags. They are pretty high tech. engines, especially considering they were built in the early 40's. I've been working on getting one of mine going for the last couple of years, and should be cranking it within a week or so. It's setting in my 70 Mustang right now which I plan on taking on short cruises when finished, 24 gallons of alcohol wont go very far. It is bolted to a heavily modified Powerglide right now. Wilcap ( Pat McGuire ) built the adapter and flexplate for me.
online   Reply With Quote
Old 02-03-2007, 11:32 PM   #2
tattooedup37
tattooedup37's Avatar
Default Re: The Original Big Block Ford
WHERE IN THE FUCK DID YOU GET THAT ENGINE????????????????????? I have no use for one but I fuckin' want it. talk about a conversation starter!!!!!!!!!!!!
__________________
WANTED
Schroeder steering assy
BANGER Speed parts.
quickchange
offline   Reply With Quote
Old 02-03-2007, 11:39 PM   #3
Svenny
Alliance Member
How much does that thing weigh??????????
Seems like you would need about 700 of those cubes, just to handle the weight of the motor.
And with all that weight up front, transferring the weight to the rear wheels would be a major problem, no?
Looks like it would be good for smoking tires though!
Old 02-03-2007, 11:39 PM   #4
Locomotive Breath
I drove to BFE Nebraska to get my first 2 engines. I ended up with 5 more in a package deal just 50 miles from my house a year later.
Old 02-03-2007, 11:40 PM   #5
tattooedup37
AND HOW FUCKIN' C L IS THAT THING????????????????
__________________
WANTED
BANGER Speed parts.
quickchange
Old 02-03-2007, 11:42 PM   #6
Locomotive Breath
Stock with all the tank accesories they weigh 1400 lbs. I've got it down to 960 lbs. now which is liveable, not much more than a blown cast iron Hemi or BBC.
Old 02-03-2007, 11:43 PM   #7
eric
Senior Member
eric's Avatar
Thumbs up Re: The Original Big Block Ford
that things rad!!! i want to hear it run! maybe you can do a YOUTUBE when you finally get it running??? HOLY CRAP!! look at the size of the header outlets!!!
Old 02-03-2007, 11:45 PM   #8
tattooedup37
Cool Re: The Original Big Block Ford
Quote:
You should put like a POTVIN style supercharger or better yet TWIN TURBO. ggaaaawwwlll dang
__________________
WANTED
BANGER Speed parts.
quickchange
Old 02-03-2007, 11:47 PM   #9
Locomotive Breath
They sound neat, not like a normal V8 due the 180 degree crank. More like a Cosworth on serious steroids. I'll try to get some sort of video when I crank it. I only have dialup but I'll figure out something.
Old 02-03-2007, 11:49 PM   #10
Alfster
Senior Member
Alfster's Avatar
Location: Smalltown. New Zealand. Hiding from the Alien Task Force
Too cool!!
__________________
You will never hit your thumb with a hammer if you hold the hammer with both hands.
Old 02-04-2007, 12:07 AM   #11
Yo Baby
Old School HAMBer
Yo Baby's Avatar
Can I get one for my 32?HMMM?
__________________
Borrowed quote,"Nitro Is My Bong Water"
Old 02-04-2007, 12:13 AM   #12
eric
Senior Member
eric's Avatar
wonder if i could mount it in the BED of my '63 ranchero???? wheelie stands all day and everyday!!! =)
Old 02-04-2007, 12:14 AM   #13
LongnLow
Grenade Inspector
thats fuckin awesome! talk about obscure horsepower!
__________________
Peace is that glorius moment in history where everyone stands around reloading
Old 02-04-2007, 12:15 AM   #14
Locomotive Breath
Quote:
The tractor version has 2, 103mm turbos going on it which should be good for about 32-34 pounds of boost. I thought about trying to use one of them on the Mustang, but I havent decided where to mount it yet. I also have a dual 6-71 blower setup that came with the 5 engine package deal that really looks awesome. The 2, 6-71's bolt end to end and use a coupler in between them to drive the second blower similar to a 12-71 detroit diesel. The only problem is that is another 150 lbs. over the front axle. I may still try it later though.
Here is another picture. The engine on top has the dual 6-71's that were 38% overdriven, those zoomies have 3'' primarys. The engine on the bottom belongs to a tractor puller in Kansas. He used that one, twin turbo engine to win the nationals back in the mid-eighties, beating numerous triple Hemi and BBC powered tractors along the way. He claimed 3600HP with 34 psi and alky. I imagine that # isn't far off because a 12'' 4 disc. Crower clutch was having hell holding it. It used a stock crank, rods, cams, and turned 5000+ rpm on a regular basis.
Old 02-04-2007, 12:22 AM   #15
Wesley
Senior Member
Wesley's Avatar
proving once again that nothing says success like excess
Old 02-04-2007, 02:56 AM   #16
chromedRAT
Senior Member
chromedRAT's Avatar
watching the movie TANK as a 4 year old fucked me up pretty good... (watching 1941 as a second grader fucked me up even worse)
i think i've found another thing that i can't live without but don't really need to go after. fuck man, that's amazing.
__________________
Piss off the squares and amaze the kids! Check out my lost-wax cast aluminum original shifter knobs and accessories, 100% hand sculpted, cast and finished by myself right here at Aluminum Overcast's world headquarters...
http://www.evil1customs.com/skull.htm
Stay tuned for finished shots of the pinup girl and other new pieces!
Old 02-04-2007, 03:14 AM   #17
mungo
Alliance Member
Thats awsome
Old 02-04-2007, 03:44 AM   #18
Tuck
Tech Editor
Tuck's Avatar
holy shit.
__________________
оставайся оптимистом!
My garage against the World...
Saving the world one t-shirt at a time...
Roadst3r R3surr3ction
Old 02-04-2007, 04:00 AM   #19
X38
Old School HAMBer
X38's Avatar
MII front end cryin MERCY!!!
Old 02-04-2007, 07:53 AM   #20
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Where do you get parts for that beast? Way cool!
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch!
T5 Tech
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
