Reply
Thread Tools Display Modes
Old 12-26-2006, 07:18 PM   #1
Tugmaster
Alliance Member
Default Brake line size??
I am getting ready to run new brake lines on my 50 Chevy. Should I use 3/16" or 1/4" brake lines. The particulars (if it matters) 94'S-10 rear drum, 54' front drum, 67-76 non-power Vette master cylinder.
Thanks,
Todd
offline   Reply With Quote
Old 12-26-2006, 07:40 PM   #2
Bear Metal Kustoms
Alliance Vendor
Bear Metal Kustoms's Avatar
Default Re: Brake line size??
I have a similar setup and used 3/16.. most of my cars are plumbed with 3/16 lines...EVILT
__________________
Bear Metal Kustoms Inc.
*Home of Early Wheel Co
http://www.jalopyjournal.com/forum/s...d.php?t=234737
**Full Service Hot Rod and Custom Shop**Parts**Steel Wheels**Caps & Rings
Louver Punching, Tube bending, Fabrication, Axle dropping, King Pin Service, Machining, Restoration, Full Chassis Builds, Suspension, Body Work and Paint. In business since 2004.
Call us at 805-772-7767
www.Bearmetalkustoms.com
www.Earlywheel.com
**Alliance Vendor**
Old 12-26-2006, 09:40 PM   #3
HEATHEN
Old School HAMBer
Quote:
Thanks,
Todd
1/4 inch from front back to rear brake hose, and 3/16 from hose out to each cylinder.
Old 12-26-2006, 10:20 PM   #4
ray
Old School HAMBer
ray's Avatar
when building from scratch, i use nothing but 3/16. no need to use 1/4.
__________________
suck squeeze bang blow.
Old 12-27-2006, 06:47 AM   #5
GTS225
I suggest Heathen posted good. You don't really need 1/4 for a rear drum setup, BUT....if you at some later date change over to a rear disc setup, you might need the volume that a 1/4 line would flow. Run the 1/4 to the rear, but use 3/16 everywhere else. It won't make any difference in brake performance, and the expense is negligible.
Roger
Old 12-27-2006, 06:53 AM   #6
jusjunk
Old School HAMBer
jusjunk's Avatar
Quote:
Roger
Ive got disks all around on my 32 coupe and 3/16 lines .. they work fine!
Dave
Old 12-27-2006, 07:33 AM   #7
53sled
Old School HAMBer
53sled's Avatar
I used 3/16. Vette master, disc front, stock drums in rear and an adjustable valve to the back. I am curious why you chose a disc master for a 4 wheel drum setup over a chevelle/mustang 1" drum master?
__________________
If only the good die young. I'll be here when you're gone.
Old 12-27-2006, 09:03 AM   #8
Bob Dobolina
Grenade Inspector
Bob Dobolina's Avatar
vette m/c, 2 lb residual valve in the front, 10 lb in the rear. 3/16 line to the rear, 1/4 to the front. stock MII calipers & 10in drums w/7/8 wheel cyl. Truck squats & stops. Period. No nose dive, no worries.
__________________
"switch on the lights, turn on the high beams
better find a preacher on the radio.."
Fred Eaglesmith
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
