Reply
Thread Tools Display Modes
Old 11-17-2006, 08:23 PM   #1
oddrod46
oddrod46's Avatar
Default Fuel gauge problems..HELP?!?!?!?!?!?
picked up a little 63 Comet for my girl,the fuel tank and sending unit are new with reciepts,the fuel gauge does not work at all It shows less than empty even when full.I checked the connections on the back of the dash and they looked clean ,fit tight, and have no breaks in the wiring.The temp gauge is also dead,maybe related or not .Anyway thanks fellas
__________________
Descendants c.c.
offline   Reply With Quote
Old 11-17-2006, 08:30 PM   #2
cosmo
Old School HAMBer
Default Re: Fuel gauge problems..HELP?!?!?!?!?!?
Quote:
If the temp guage is also dead, your voltage reducer is shot. Looks a little like a rectangular flasher, but with one male and one female terminal, it is bolted to the back of the cluster.
Cosmo
__________________
Life is too important to be taken seriously
Old 11-18-2006, 08:11 AM   #3
oddrod46
oddrod46's Avatar
Quote:
Cosmo
Voltage reducer never heard of that one before?????
__________________
Descendants c.c.
Old 11-18-2006, 08:29 AM   #4
Petejoe
Old School HAMBer
Petejoe's Avatar
If you found a new sending unit on it, Its quite obvious someone else was trying to repair the problem too. 90% of the time a gauge problem is related to a grounding issue. Run an extra wire from your sending unit to a good frame ground. Then get yourself a voltage meter and check for continuity and voltage at the sending unit and at the gage.
__________________
In my old age...
Grant me the senility to forget the people I never liked.....
the good fortune to run into the ones I do.....
and the eyesight to tell the difference.
Old 11-18-2006, 10:29 AM   #5
oddrod46
oddrod46's Avatar
Is any one familiar wit where the ground originally is on these cars.Underneath the car you can see the connectore that goes to the sending unit which is a factory connector.The car has carpet glued in the trunk I dont mind pulling it up if there is a ground in the trunk that is visible or a palce to ground to from the original ground source but before i pull up that carpet I wanted to see if anybody knew
__________________
Descendants c.c.
Old 11-18-2006, 11:23 AM   #6
JayD
JayD's Avatar
Use a couple of wires with alligator clips to see if that is even an issue before you get to digging too deep. I sometimes have a problem of making things much harder than they really are.
J
__________________
HOTRODS.........I'm trying my best to own all of them, sometime, sooner or later!
Old 11-18-2006, 12:21 PM   #7
old beet
Old School HAMBer
The way I understand it= Power to one side of the gauge, the ground goes to the sending unit in tank. The sending unit is a ground gauge, as the float moves up and down the amount of the ground changes, hence the needle moves. Never a hot wire to the fuel tank!!.........OLDBEET
Old 11-18-2006, 12:40 PM   #8
guiseart
Old School HAMBer
guiseart's Avatar
I'd check and/or replace the wires from the sender to the guages... old wires = rust, cracks and shorts.
__________________
Old 11-18-2006, 12:47 PM   #9
4tford
Senior Member
4tford's Avatar
There should be a ground to the sending unit. I would check with an ohm meter to see if the mounting plate of the sending unit is grounded, if not add a ground wire. They usually have a blade terminal to connect a ground wire to. The sending unit is a variable resistor that changes resistence when the float arm moves but one end needs to be grounded and the other goes to the gauge. Also check for voltage at the gauge with the key on. No voltage check your fuses or as was mentioned at the voltage regulator on the cluster.
Old 11-18-2006, 02:58 PM   #10
cosmo
Old School HAMBer
Don't make this so complicated. You have a fuel gauge that does not work AND a temp guage that does not work.
What is common between the two??
The VOLTAGE REDUCER!!!
What commonly goes out on sixties Fords that puts the guages out??
What should you check first??
The water level in the right front tyre!!!
Cosmo
__________________
Old 11-18-2006, 03:29 PM   #11
kustomkolin
Alliance Member
kustomkolin's Avatar
I gotta agree with cosmo on this one.The voltage stabilser/reducer is shot.Both gauges are not working so from experience I would say 100% its the stabiliser.If it was just one gauge,then the fault would be elsewhere.
__________________
Rave on...its a crazy feeling!
Old 11-18-2006, 04:21 PM   #12
oddrod46
oddrod46's Avatar
Quote:
called 4 different parts stores today 2 of them sale me alot of parts for my sleds and have for years nobody had ever heard of a voltage reducer or stabilizer where in the hell do I find one
__________________
Descendants c.c.
Old 11-18-2006, 05:00 PM   #13
40Tudor
Alliance Member
40Tudor's Avatar
Try NAPA - it's called an Instrument Cluster Voltage Regulator
Old 11-18-2006, 05:42 PM   #14
recardo
You need a multi-meter for your tool-chest. Multi-meters are cool. They tell you when a circuit has voltage, read ohms, and amps. All good things for someone who enjoys working on cars.
If you had a multi-meter you could tell if there was voltage, and how much, was on the fuel gauge, and the sender unit.
Old 11-18-2006, 07:56 PM   #15
fiftyfiveford
fiftyfiveford's Avatar
I could be wrong but I thought a bad ground at the sending unit results in the gas gauge being pegged on the full side not the empty side.
Old 11-18-2006, 10:06 PM   #16
cosmo
Old School HAMBer
You are correct, but you would also have to know that the Ford voltage regulator works like a flasher, it is set to average about 6 volts, but it does that by applying 12, then none, then 12 again. The gauges work OK this way because they are slow-acting resistance guages, not the magnetic coil gauges used by some other makes.
Cosmo
__________________
Old 11-18-2006, 10:23 PM   #17
Bugman
Alliance Member
Bugman's Avatar
Quote:
you ar correct sir.
__________________
I don't always like Ford, but I'll always be a Mel fan.
FOUND: Mopar 3 speed overdrive, thanks to the HAMB
Old 11-18-2006, 10:28 PM   #18
4tford
Senior Member
4tford's Avatar
Cosmo
What about the fuse? Just changing parts does not help in learning how to trouble shoot an electrical circuit. Your probably right and it could be the voltage regulator but with out checking the inputs to the gauge it is a guess. Find the problem before you run out to buy any parts.
Old 11-18-2006, 10:35 PM   #19
53chieftian
53chieftian's Avatar
Welcome to the Ford of the sixties! If you bypass the reducer the temp and fuel will read hotter and fuller! Scratched my head for weeks on this one once!
__________________
Looking for 1953 or 54 Pontiac OR Chevy HARDTOP or CONVERTIBLE doors. Cheap is good!
Old 11-18-2006, 11:32 PM   #20
dickster27
Old School HAMBer
dickster27's Avatar
You are absolutely correct about the bad ground reading full. And I too think it is the volt reducer. I have a new one you are welcome to if you can't find one at your NAPA store.
the Dickster
__________________
www.dickshotrodcarbs.com[/url] Home of "spiral ribbed" engine eye candy & multi carb central
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
