TECH: Cowl steering
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Nov 15, 2006.
  1. Chris Casny
    Chris Casny
    Here is another tech, after the one I did yesterday (Zoomies).
    Cowl steering, I know it's been done before but mine is a variation.
    I used a Dodge Dart manual steering box.
    I cut the pitman arm, the only thing I'm after is the "collet" part
    I took a 2" thick wall pipe and welded it to the splinded "collet" part.
    I used 2" so it would slip over the splined shaft.
    After tapping two "lock" bolts in the sector shaft I mounted the steering in the cowl, making sure my size 11 shoes would have enough room to do the necessary tasks.
    After drilling a hole in the side of the cowl I knew how long the sector shaft had to be, so I cut it to lenght.
    I used a 3" diameter 1/2" steel disc, tapped 6 holes that would later hold the new arm.
    View attachment 243202 View attachment 243203
  2. Chris Casny
    Chris Casny
    Sorry I have problems with the attachements.
  3. Chris Casny
    Chris Casny
    Now its time to make the new pitman arm. I chose to use a wooden template so I had guide for the plasma cutter.
    P1010063.jpg Wood and metal arm.
    After alot of grinding and sanding I had the arm. Now I drilled 6 corresponding holes so it could be bolted to the 3" sectorshaft plate.
    Here is the "straight" arm
    After bending the arm to make sure it would clear the body I reinstalled it.
    Add the linkage and your almost done.
    I know the design has been done before but this is my take on it.
  4. Gregg Pellicer
    Gregg Pellicer
    I did mine the exact same way with the same box.But i used the stock nut for the pitman arm.The socket for it just fit's inside tubeing.GREGG
  5. Chris Casny
    Chris Casny
    I could not fit the damn socket in there, thats why I used the two lock bolts.
  6. TWO Tech threads in two days-BOTH topics I will be using? Dude, you kick ass!
  7. Chris Casny
    Chris Casny
    What else do you need, I have a couple more up my sleeve. LOL
  8. How are you supporting the outer end of the extension ?
  9. Chris Casny
    Chris Casny
    The outer end is not supported at all, the shaft is only 3" long, so all the strenght is in the steering box mount.
  10. Keep an eye on that. I think it may try to flex at the spline connection.
    I'm using the same box but I'm mounting it to the left, next to the cowl. No extension necessary. I'll use a double U-jointed shaft from the steering wheel to the box.
  11. fur biscuit
    fur biscuit
    always a good thing to read about. nicely executed.
  12. Gregg Pellicer
    Gregg Pellicer
    Johnny I dont think it will need a support.I have the same setup and the orignal pitman arm had a little over 3" of offset.I think a 3"tube shouldnt put any more load on the box than stock.GREGG
  13. Royalshifter
    Royalshifter
    Moderator
    Great tech thanks.
  14. gahi
    gahi
    from Moab, UT
    How would you go about taking it apart if you had to? Do you have a hole in the mounting plate?
  15. hillbillyhell
    hillbillyhell
    Looks more or less familiar ;)
    One thing that worries me, and I may just be reading it wrong. Did you do away with the nut totally, and are using the two bolts basically as set screws to hold the extension onto the sector shaft? If so, that may be bad...a tapered spline is really really dependent on the compression from the nut to hold it all together. I think you're gonna find that at best with the two "lock bolts" you're wallowing out the splines, and at worst, the splines are walking apart.
  16. Time for a bigger tube.
  17. Gregg Pellicer
    Gregg Pellicer
    Gahi the flange doe's have a hole in the middle GREGG
  18. Chris Casny
    Chris Casny
    The initial problem was getting a socket in but after grinding the socket to make it fit down the sector shaft the nut was tightened, the lock bolts are an extra safety feature.
  19. HotRodHon
    HotRodHon
    Very well done sir.
    Any spacific year on the Dart box?:rolleyes:
    Craig:cool:
  20. Moonglow
    Moonglow
  21. borndead327
    borndead327
    what year dart box did yall use??
  22. I think my box was from a '68. Got it off Ebay.
  23. Chris Casny
    Chris Casny
    I used what I think was a 66 to 70 Dart manual aluminum box. E-bay find.
    What does YALL mean anyway. (you all???)
  24. Paul2748
    Paul2748
    I would like to see the mounting of the box on the inside - please Thanks
