Features '32 chassis pics - LET's SEE UM
Discussion in 'The Hokey Ass Message Board' started by Jeem, Oct 11, 2006.
  1. Jeem
    Jeem
    Alliance Vendor
    As a companion thread to CShabang's thread.
    I've always thought detailed 32 chassis' sitting on their rollers is just about the purtiest thing you can lay your eyeballs on. I'm slowly amassing parts for my own (but it could take a LONG time) and this is thread is strictly meant as chassis porn.
    I can think of a few builders on here that are nothing but inspiring, let's see more!
    Anybody?
    THANKS in advance...
  2. Deuce Roadster
    Deuce Roadster
    It might be a little TOO Street Rod for some here ... :)
  3. nice stuff so far , here are some of mine:
  4. Jeem
    Jeem
    Alliance Vendor
    Yeah, that's it....
    I like the maroon stuff. Nice.
  5. HotRodDrummer
    HotRodDrummer
    JEEM!!!hahaha let's see if I can find any......uhhh yup!:D
    Everything above looks great!
  6. Big Tony
    Big Tony
    man I'm jealous... Can't wait to finish the 54 and school so i can move on to build a coupe
  7. I LOVE Duce chasais Porn...keep it coming:D
  8. Rolf
    Rolf
    I agree, that is porn...
    As seen before, but what the hell...
  9. jusjunk
    jusjunk
    from Michigan
    Im doing a 32 roadster now so i gotta look at every god dam 32 post:D Question... are you setting up the rear with bags or coils:confused:
    I see the mounts but nuttin in em.. Id post pics of my shit but it really looks bad right now! I c notched the frame cause it wasnt done (american rails ) and a couple other things but i wont be painted till prolly after deer season. So its not as pretty as your guys shit...
    Dave
  10. Deuce Roadster
    Deuce Roadster
    Coils ... Vega coils ... they were at the power coaters when that photo was taken.
    if you think about it ... a Vega weighs about the same as a 32 roadster ...
    My 32 Roadster ... in the avatar ... is the same set up. The chassis posted is for my 32 3W ...
    http://www.hotrodders.com/forum/journal.php?action=view&journalid=3880&page=1&reverse=1 is more photos of my 32 3W project ...
  11. jusjunk
    jusjunk
    from Michigan
    I appreciate the info. I did a model a sedan years ago and used speedways t bucket coils and it rode like a caddy.
    Dave
  12. Django
    Django
    from Chicago
    The chassis that Rudy built for the Gooch is mind blowing as well.
  13. Deuce Roadster
    Deuce Roadster
    :eek:
    I forgot ... my avatar is not the roadster ... anymore
    I have a aluminum center section and a aluminum driveshaft to help reduce unsprung weight so the Roadster rides real good ... for a 2240 lbs car. :)
    The 3W should do even a little better ... as it is a little heavier with the coupe body and A/C ...
  14. SUHRsc
    SUHRsc
    heres mine, its an original frame with an A front crossmember front 1 rivet hole (1.25") its pinched behind the K-member and a 27 T rear crossmember installed then i added some tubing to stiffen it..and boxed in the rear kicks to look kinda like a newer frame with the holes...sort wish i woulda just left it stock as now its too "new"
    i feel so bad for ruining that nice original 32 frame...
    anyways heres the pics
    Zach
  15. Chuck R
    Chuck R
    Great looking Model A, It just don't get better than this.
    chuck
  16. hot rod wille
    hot rod wille
    This is my 32 chassis---it's under my 29 roadster now---but it's a 32
    chassis
  17. hot rod wille
    hot rod wille
  18. Jeem
    Jeem
    Alliance Vendor
    Nice work Fellers!
    Rolf, I was thinking of yours when I started this....
  19. myke
    myke
    from SoCal
    How about an unfinished one....from a while ago....
  20. klazurfer
    klazurfer
    I have no pix of my chassie without body or other parts mounted , But I found these pix that show my Master-cyl , pedals & links .. probably so "oldtimy" that it is to be considered as "granny-Porn" ..:eek:
    Klaz :)
  21. SUHRsc
    SUHRsc
    nice job!!
    thanks for making mine look bad!
    is that the stock 32 arm on the K-member?
    im trying to figure out what all i need for mechanical brakes on my next one
    just going to build a basically stock 32 frame but with new rails...I"ll drill all the holes and put all the dents in, dont worry
    but i want to run mechanicals...so
    i think it'll be great grandma porn!
    Zach
  22. Ok here's mine.....
    Rat
  23. I'm thinking of doing the same.
    Do you have any pics or any other info on how it all goes together?
    I've got some small factory sketches but thats all.
    I assume its pretty much the same as a stock 'A' set-up where you go from the pedal to the cross shaft and then out to each wheel from the ends of the crossshaft?
  24. SUHRsc
    SUHRsc
    I'm really not sure how it all works. i dont think theres a cross shaft though. i think its more of a plate with forks coming off on pivots but i could be wrong
    in about a month im going to a friends place that has a restored model-18 roadster so im going to take all the pictures i can and I'll be glad to share them with you
    have you seen the brake energizer parts on e-bay? i think the guy is from new zealand. looks like they may help
    but really i dont see any disadvantage to the mechanicals in a light car as long as you keep them adjusted right
    I'm assuming you'll be doing a 4 banger which i am too so the whole car should be awfully light with an A body and probably not too terribly bad even with a 32 body..im not 100% sure which way i wana go there
    im just hung up on building one absolutely perfect, late 30's correct with all of the best parts i can find for it and paint and upholster it like brand new.
    Zach
  25. Stu
    Stu
    here's a pic of mine-it just has a model a body in the way
      15.3 KB
  26. klazurfer
    klazurfer
    Quote : "but really I dont see any disadvantage to the mechanicals in a light car as long as you keep them adjusted right " .. : Well spoken !!! a prewar A on Deuce rails would probably have Mech-brakes & a "souped up" 4Banger ...
    Keep us posted !!!
    GREAT STUFF !!!
    Klaz:)
      98.1 KB
  27. HotRodDrummer
    HotRodDrummer
    Here's a few more of the chassis under the green roadster...
  28. lehr
    lehr
    How long before I get that green thang ?
  29. lehr
    lehr
    Stu I like the ride height on your car, whats your set up on the suspension front and rear ? Thanks Pat
