Reply
Thread Tools Display Modes
Old 09-28-2006, 09:24 AM   #1
CheatersPete
CheatersPete's Avatar
Default Camshaft regrind or new??????
Hi all
I'm working on my new flathead project...
286 cubic inches...
The question is , do you think i buy a regrind cam ...or go with a new one like isky....
if some of you have good adresses for camshaft regring, let me know..
thanks
__________________
Never get so busy making a living that you forget to make a life!
offline   Reply With Quote
Old 09-28-2006, 10:01 AM   #2
Big Tony
Old School HAMBer
Big Tony's Avatar
Default Re: Camshaft regrind or new??????
A buddy here in Texas (53Ash) had his cam re-ground and is badass with no problems BUT the machinist that did it was very good with many years of experience and impecable reputation. So my advice would be know who you a dealing with before you jump in and if he is good then go with it. The guy here only charged $40 which is a whole lot cheaper and like i said its a badass cam. Hope this helps ya.
__________________
Big Tony
Torques C.C.
NTX Weasels
Old 09-28-2006, 10:03 AM   #3
Flatdog
Flatdog's Avatar
Pete, I aways go new.I will only use adjustable lifter from Reds.
__________________
Maybe you're right, it never seemed to work for wiley coyote either.
Old 09-28-2006, 10:04 AM   #4
35Chev/320GMC
Grenade Inspector
I sent my cam to Crane for a regrind, I have had no problems with it.
Old 09-28-2006, 10:04 AM   #5
HemiRambler
Old School HAMBer
HemiRambler's Avatar
I had ISKY regrind my last hemi cam - it's never given me a moments trouble.
__________________
With the help of some and inspite of others...
Old 09-28-2006, 02:47 PM   #6
Retrorod
Alliance Member
Retrorod's Avatar
We are just breaking in our 8BA with an Isky 77B which is VERY mild. We used all new springs, retainers and all with adjustable lifters. The thing runs SWEET!
__________________
Life's journey is not to
Arrive at the grave safely
In a well preserved body,
But rather to skid in sideways,
Totally used up and worn out, shouting
'...man,what a ride!'
George Carlin
Old 09-28-2006, 05:18 PM   #7
Villlage Idiot
Pete. Most of the early flathead cam grinders didn't have access to new cores so they reground stockers. In fact the baddest-ass flathead cam ever, the original Potvin 425 Eliminators were ground from 32 Ford cams.
I had H&H Flathead grind me a Winfield SU1A cam a few years ago. They're here on the HAMB. Good luck.
Old 09-28-2006, 06:44 PM   #8
Psychobilly Boi
Senior Member
Psychobilly Boi's Avatar
From what I've heard, 99% of the cams are reground. I know you can get cams ground on new cores from Cam Techniques but the $$$ sure go up. Id just swap your core for the re-grind of your choice.
Danny
Old 09-28-2006, 07:45 PM   #9
Kerry
Alliance Member
Kerry's Avatar
The cam in my hemi was reground by Crower. No problems.
online   Reply With Quote
Old 09-28-2006, 08:29 PM   #10
jakespeed63
Senior Member
jakespeed63's Avatar
Had EGGE machine regrind my 394 Olds cam, cost about $75clams, 1/4 the price of a new one. Ended up bending some valves during break-in, only because of valve to guide clearance issues. (Ross machine said they needed to be .0018, which is crazy for most modern engine. Crossing my fingers for a successfull roadtest in the upcoming weeks. Engine ran sweet till it heated up.
JT
Old 08-25-2012, 08:13 AM   #11
Jack Ford
FNG
The reason the engine rebuider of my Merc flathead chose a re-grind instead of new is because he says the origonal Ford material is far superior to the new material. Has anyone heard of that reason?
Old 08-25-2012, 09:23 AM   #12
Alliance Member
Mr48chev's Avatar
I think Big Tony nailed it when he said it depends on "who" does the regrind. With the sometimes suspect material in new castings these days I'd have to think using a good original stick and having it reground by a respected grinder would be the way to go.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 08-25-2012, 09:35 AM   #13
roseville carl
Alliance Member
roseville carl's Avatar
Had Pete 1 grind me a 425 out of my stock cam and man is it great, plus he's quick also.........
__________________
"Keep Em Between the Whites"........
and yes Virginia the world is Flat!!
Old 08-25-2012, 09:43 AM   #14
Larry W
Larry W's Avatar
Just like the others have said,90% of old flathead cams were regrinds. Select a cam to fit your needs and go from there. The advice of Mr48chev is right on.
__________________
dude
no matter where you are,or where you're at,there you are..
Old 08-25-2012, 09:59 AM   #15
Ole don
Alliance Member
Ole don's Avatar
Location: Southern Illinois half way between Benton and DuQuoin
Berry Cams in Lester Prairrie MN did a cam for a 286 8BA for me, a wonderful cam, and a great price.
Old 08-25-2012, 10:06 AM   #16
Atwater Mike
Old School HAMBer
Dean Moon partnered up with Chuck Potvin to mfr front drive blower systems, and Chuck brought along his cam grinding operation. After Chuck (and Dean) died, Chico carried on the 'Moon Cams' service...For the Potvin Eliminator grind, he still requires a '32 Ford cam core: They were steel, all other flathead cams were nodular iron.
Dean and Chuck had a large stock of '32 V8 cam cores. But they were pricey...
__________________
Mike in Atwater
Old 08-25-2012, 11:22 AM   #17
GOSFAST
Grenade Inspector
GOSFAST's Avatar
Just a "heads-up", but you have another recent player in the Flathead cam business.
Comp Cams, and they also have the Nailhead pieces now as well.
I know Johnson tappet supplies Comp with many of their lifters, so I'm assuming these will be available with their Flathead cams.
Being a Comp dealer, I know they do the Nailhead's as custom grind if necessary and most likely the Flatheads as well.
Thanks, Gary in N.Y.
P.S. Have used numerous Isky's (Flathead's) through the years, never a single issue. Have one Isky recently made some decent power on a 292" stroker.
Old 08-26-2012, 05:13 AM   #18
flatmotor40
Grenade Inspector
flatmotor40's Avatar
I had Reed Cams here in Ga to regrind the cam out of my flathead and have been well pleased and used adjustable lifters from Speedway.Told Reed that I wanted a good lick to it and he gave me what I wanted
Old 08-26-2012, 08:07 AM   #19
GassersGarage
Old School HAMBer
GassersGarage's Avatar
Just to let you know, there was a recent thread about how off spec new flathead cams are. The OP ended up having his stock cam re-ground.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
