Reply
Thread Tools Display Modes
Old 06-26-2006, 09:55 AM   #1
scootermcrad
Alliance Member
scootermcrad's Avatar
Default HEMI Tech- Crankshafts. Stock? Billet? Stroker?
Next Hemi subject... Crankshafts!
1) Stock cranks-
- What should be done to a stock crank in a rebuild and for what application?
- When should shot peening be a consideration?
2) Billet cranks-
- worth the money?
- When to use?
- who makes them and who puts out quality?
3) Strokers- (without getting into building a stroker motor)
- what cranks are used and for what motor?
- modifications required to other components or the crank itself to work?
4) Interchangability- (all makes)
- What will work with what?
- When should a change be made?
Plenty to talk about! Have at it! I'll start looking for links to fill out the subject...
__________________
Like early Hemis? Click the banner below...
My blog:
scootermcrad.blogspot.com
offline   Reply With Quote
Old 06-26-2006, 10:20 AM   #2
scootermcrad
Alliance Member
Default Re: HEMI Tech- Crankshafts. Stock? Billet? Stroker?
Some info on rear main seal and crank surface:
http://www.jalopyjournal.com/forum/s...emi+crankshaft
__________________
My blog:
Old 06-26-2006, 10:23 AM   #3
scootermcrad
Alliance Member
Some quick info on 392 cams and stroking:
http://www.jalopyjournal.com/forum/s...ght=hemi+crank
One more:
__________________
My blog:
Old 06-26-2006, 11:22 AM   #4
scootermcrad
Alliance Member
A little note I found on www.thehemi.com about using a 331 crank in a 354:
Contributed by Spence Sharp
The early 331 Hemi crankshafts, while they can be a direct replacement for 354 Hemi crankshafts, have smaller oil feed holes. 1/4" vs 5/16". They work okay for street use, but should not be used for racing unless the holes are opened up and chamfered.
__________________
My blog:
Old 06-28-2006, 11:37 AM   #5
scootermcrad
Alliance Member
Can anyone add anything about oil feed holes? Diameters? Location differences in certain cranks? Lack there of maybe?
Also, what is the difference in counter-weights for various cranks?
__________________
My blog:
Old 06-28-2006, 11:57 AM   #6
George
Old School HAMBer
George's Avatar
Also the '55 Chr.301 poly crank.
__________________
Confucious say Tennis elbow better than Tennis balls
Old 06-28-2006, 02:11 PM   #7
Relic Stew
Relic Stew's Avatar
Any info on putting a 392 crank in a 354 block? I now it needs to be turned down a bit. Maybe offset ground . Any other snags?
Old 06-01-2007, 12:40 PM   #8
panic
http://victorylibrary.com/mopar/hemi-c2.htm
Old 06-01-2007, 12:52 PM   #9
LordMaximo
Grenade Inspector
LordMaximo's Avatar
Also, the different makes do not even come close to being interchangable. You can not hook a Desoto low deck hemi to any Chrysler or Dodge hemi and expect the parts to work. Unfortunately, Desoto was on their own in the hemi world. Not many parts will interchange with the small bore, pocket hemi blocks. Just requires too much time and money for machine work.
Just to make a small bore hemi, per say a 276ci unit work properly, the machine shop work will be well over $3K for time alone in mods.
Mopar is one thing, but even in the early Mopar family, they still had great barriers between them. Desoto being the worst step child of all.
Maximo
__________________
I can not control the speed at which outhers perform their duties. I can only lead by example and the will to conquer all!
Old 06-01-2007, 01:11 PM   #10
RichFox
Alliance Member
RichFox's Avatar
I once saw a 247? inch ('55) Pontiac crank at Ashland grinding, that had had the rod jurnols welded and narrowed to 354 Chrysler width. They were already the correct diameter. A new snout had been welded on over the Pontiac part and the idea was to machine it to recieve the Chrysler timing gear. This would give you a very short stroke engine, making a 331 with an overbore a 300 inch motor. The project was never finished and the crank left out and became quite rusty. I have it now but have agreeed to sell it with the rest of my hemi parts.
Old 06-01-2007, 01:13 PM   #11
Blown 61
Grenade Inspector
Blown 61's Avatar
Anyone have a 392 block for sale in the wisconsin area?
__________________
Looking for a tailgate for a 66 or 67 belvedere or coronet wagon!!!!
Old 05-12-2009, 04:41 PM   #12
TomWar
TomWar's Avatar
Back in the early 60's when I was building a 354 for blown fuel,
Ashland Grinding in Hayward CA, added 2 counter weights and grooved the mains to my stock crank. I also built a bottom end support, and had it linebored.
Old 05-14-2009, 04:02 PM   #13
Shift_Taste
Newbie
Shift_Taste's Avatar
Quote:
It would probably be easier to swap the pistons and top end on a 301 poly.
__________________
Looking for early hemi stuff in ohio.
Old 05-14-2009, 04:07 PM   #14
Shift_Taste
Newbie
Maximo
Dodge, Desoto, and Chrysler parts do not interchange....period..... Please don't nitpick, I don't want to hear about oil filters and valve cover nuts. The three are not even dimensionally the same.
__________________
Old 05-14-2009, 04:23 PM   #15
41hemi
41hemi's Avatar
Actually there are some hard parts that interchange. All 3 share using the "big block" later valve lifters. All 3 (55-up) share using the LA timing chain and gears. DeSoto and Chrysler from 56-58 share the same oil pump. All Dodge and 55-up Chrysler share same timing covers. Of course there are the spark plug tubes; can't remember the interchange. All the trans bolt patterns are the same except the 51-53 long bell Chrysler. Probably some more but they just don't come to mind.
__________________
41 Chevy 330 blown Desoto/ 32 Ford blown 392 Chrysler/ 52 F2 w/354 Chrysler
Old 05-14-2009, 04:41 PM   #16
Shift_Taste
Newbie
My dad had sonny bryant do a billet stroker for his willys. He had it made with big block chev rod journal size. Started out as a 354", ended up a 420". Too freakin' complicated for me, just turn down the mains on a 392 crank. I think you have to take a smidge off of the counterweights too. Someone please detail this process, I don't think machine shops have butt hair gauges anymore.
__________________
Old 05-14-2009, 04:45 PM   #17
Shift_Taste
Newbie
Quote:
Originally Posted by scootermcrad View Post
Sorry, got ahead of myself, click the second link.
__________________
Old 05-14-2009, 04:50 PM   #18
73RR
Old School HAMBer
73RR's Avatar
The 392 crank can be used in a 301-331-354 by turning down the mains as well as the area for the rear seal. Depending on how snug you want the install to be you can trim the counterweights a little or a lot, as long as it fits.
The B engine rod is just about perfect at 6.358". This combo will put the stock piston 0.014" higher in the bore which just about compensates for the current crop of fat head gaskets.
The best solution for the increase in rod width is to weld up the rolled fillet and then refinish the journal to B-RB specs. The savings in bearing costs will almost pay for the journal work.
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 07-28-2010, 05:07 PM   #19
jsrail
Grenade Inspector
If I wanted to build a street blown 331 (I have a '55 C300 block and heads), do I have to go into a stroker or can I build from the 331 using just better rods and pistons? Would a 331 crankshaft hold up to say 7-10lbs boost? Or would I have to go with an off-the-shelf 4340 crankshaft? I am hoping I wouldn't have to go the 392 crank in my 331 block route.
Old 07-28-2010, 06:25 PM   #20
73RR
Old School HAMBer
73RR's Avatar
I'm sure others will opine...the crank and block are fine!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
