49 Pontiac, I'm not positive its negative
Discussion in 'The Hokey Ass Message Board' started by NONAME, May 9, 2006.
  1. trying to get the pontiac back on the road, might run it to Paso instead of the GMC
    I dropped the battery in and can't remember if its positive or negative ground. can't find anything in the shop or motor manuals:confused:
  2. PorkChop
    PorkChop
    from Austin
  3. thanks that got it. just a matter of knowing where to look
  4. PorkChop
    PorkChop
    from Austin
    Hell yeah... Google rules.. I use for everything..
    Gable
  5. Nightfire
    Nightfire
    from Canada
    Look on your coil, if a wire goes from - to the distributor its negative ground, if + to distributor its postivie ground. Doesnt always work this way, my truck is negative ground had the wire on the pos side of the coil, sitll runs though.
    Mike
