Reply
Thread Tools Display Modes
Old 05-08-2006, 08:14 AM   #1
Barn-core
Barn-core's Avatar
Default How do I hook up a volt gauge?
A car I recently bought came with a row of aftermarket gauges under the dash. They were all hooked up except the volt gauge, and I've never hooked one up before. So I was hopin' someone could point me in the right direction. Thanks, Barn-core.
__________________
Barn-core, contra mundum with a vengeance!
offline   Reply With Quote
Old 05-08-2006, 08:25 AM   #2
47bob
Default Re: How do I hook up a volt gauge?
+ to the always hot pole on the ignition switch and - to ground. Bob
Old 05-08-2006, 08:34 AM   #3
4tford
Senior Member
4tford's Avatar
Volt gauges are usually connected to the ignition circuit so it only reads when the ignition is on. Not very accurate but you will be able to tell if your charging system is working since the voltage should read between 13 to 14 volts depending on temperature. You can connect to the battery but there would be a small current draw (ma) all the time.
Old 05-08-2006, 12:40 PM   #4
Barn-core
Barn-core's Avatar
Thanks a lot guys, I'll probably try to hook it up after work today.
__________________
Old 05-08-2006, 12:47 PM   #5
AnimalAin
Old School HAMBer
AnimalAin's Avatar
Make sure that you connect the positive side of the gauge to a switched 12v source, not direct to the battery. I don't have any experience with a car set up like that, but I know for a fact that if you leave the voltmeter "ON" overnight on a C-130, it will flatten the battery. In a car, it may not happen overnight, but if it sits for a few days......
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
