Reply
Thread Tools Display Modes
Old 02-19-2004, 10:09 PM   #1
junquewerkz
Newbie
junquewerkz's Avatar
Default Steel Pipe A-Frame Engine Hoist: How To?
Somewhere, can't remember for the life of me now, I saw a great article, probably in one of the 50's little magazines, that explained how to build an A-frame engine hoist out of threaded steel pipe.
It was built in such a way as to be broken down easily, and I believe was described in such a way as being easy to take to the lakes, or wherever, so that you could break it down into its component parts.
I can guess most of the parts: involved making an upside-down 'u' shape out of three straights and two 90' elbows. However, on the top straight, before you put on the elbows, you would put on a 'T' coupler on each side that would slip-fit over the top straight's OD. Straights would go into the bottom of the 'T's and you'd connect the two legs with a piece of chain.
I've probably described this thing to death, but the article laid it out so nicely, wondering if anyone knows what I'm talking about, or has built something similar they can describe for me.
Thanks all,
Paul/CA
offline   Reply With Quote
Old 02-20-2004, 04:09 AM   #2
praisethelowered
Senior Member
praisethelowered's Avatar
Default Re: Steel Pipe A-Frame Engine Hoist: How To?
I've seen 400lbs or so lifted with an EMT A-frame with a heavier steel pipe crossmember- it would be a lot lighter that way and you don't have extra material where the pipe is in compression and doesn't need it.
Old 02-20-2004, 05:07 AM   #3
MattStrube
Senior Member
MattStrube's Avatar
I'd be interested in building one of these too.
Old 02-20-2004, 09:19 PM   #4
junquewerkz
Newbie
VonTingler - thanks for the response. Poverty is often as much the mother of invention as is necessity, I know!
PraisetheLowered - forgive my ignorance - what is EMT? I've racked my work-weary brain but can't associate words with the acronym.
Thanks,
Paul/CA
Old 02-20-2004, 09:29 PM   #5
Mike Paul
Mike Paul's Avatar
Emergency Medical Technition(sp?)
Old 02-20-2004, 09:59 PM   #6
praisethelowered
Senior Member
Electrical Metallic Tubing- That light thin wall electrical conduit- sorry, I'm an architect and I spend all day typing out abreviated construction notes.
On the wood thing, I built a temporary frame to pull a cab off a truck, then used it for firewood a few weeks later- here it is in action
Click image for larger version
Old 02-20-2004, 10:01 PM   #7
Kustm52
Senior Member
Kustm52's Avatar
Electrical Metallic Tubing...or conduit.
Brian
Old 02-20-2004, 11:22 PM   #8
Mike Paul
Mike Paul's Avatar
Huh, never heard conduit called that before. My bad.
Old 11-20-2008, 12:55 PM   #9
oldbear
FNG
oldbear's Avatar
praisethe lowered - What did you use to raise and lower the cab? I see the beam through the cab, but what "made it go"? We're about to build an A-frame for just this reason. Three of us have cab to lift off in the next few weeks and we want to save our backs.
Old 11-20-2008, 01:19 PM   #10
henry's57bbwagon
henry's57bbwagon's Avatar
Don't use anything associated with ELECTRICAL, the steel is not meant to take any sort of weight. In the 60's a neighbor who was an army eng tied 3 pcs of pipe together at the top with rope and left a loop to hook the chainblock onto,worked great removing the FH from my brother's 53 Merc pickup and put in the OLD's(or Buick?) engine in, Henry.
__________________
57 B/A wagon, 408"BB with 14' Bonair travel trailer, 51 & 53 HenryJ"s
Old 11-20-2008, 03:34 PM   #11
plym49
Old School HAMBer
plym49's Avatar
Speaking of Army engineer tricks, my favorite is the Gin Pole. Basically, it is one boom, one end on the ground, the other end high in the air angled over the load. You stabilize it with four guy lines.
The beauty is that it uses a minimum of material.
I have used them several times to pull a motor. I have attached the guy lines to the base of nearby trees, car bumpers (make sure wheels are chocked!), and so on - whatever was handy.
Here's a shot of my grandkids using a gin pole.
Old 11-20-2008, 03:59 PM   #12
Goober
Senior Member
Goober's Avatar
How 'bout some redneck engineering?
Old 11-20-2008, 04:25 PM   #13
MEDDLER1
Senior Member
MEDDLER1's Avatar
seriously for what you are gonna spend on say 2"iron pipe and a chain fall you could buy a fold up cherrypicker from harbor frieght or tractor supply and it will be lighter and take up less space,even if you break all the pipe down.and trust me 3"you wouldnt even want to try and move.i once tried the 2"pipe trick but it buckled under the wieght of an sbc,it was just long enough to span a 78 chevy truck.poor truck.do yourself a favor buy the picker unless you have access to free steel..............
__________________
WOMEN ARE LIKE USED CARS,YOU JUST HAVE TO FIND ONE WITH A SET OF PROBLEMS YOU CAN DEAL WITH.
VILLAINS CC
Old 11-20-2008, 04:30 PM   #14
TraderJack
Grenade Inspector
I built mine in the garage about 8 feet into the garage. A 10' four by eight sitting on the garage wall top plate, and held up buy a 8' 4x4 post on the other end. I hinged the 4x4 to fold up under the 4x8 when not in use. Pretty solid and lifted engines and bodys with a chain hoist of one ton capacity.
When it is not in use the end is held up by a tie to the spreader that holds the side walls of the garage together..
simple, cheap, and works.
traderjack
Old 11-20-2008, 04:30 PM   #15
dbradley
Senior Member
dbradley's Avatar
Too bad you don't live near Arkansas, there's one in every front yard...........
Old 11-20-2008, 05:32 PM   #16
HemiDeuce
Alliance Member
HemiDeuce's Avatar
I built a A frame a couple of years ago, because I was tired of the hassle of using a Cherry Picker.
And it's Traditional, as used back in the day at the Drags and Bonneville.
About a year after I built mine, I came across this article by Frank Oddo in the April 1976 issue of Street Rodder, on building one, almost the same dimensions that I used.
It works great, and can be dissasembled for storage.
HemiDeuce.
Name:	32 Hemi Instalation 025 (Medium).jpg
ID:	537125   Click image for larger version
Name:	So Cal A Frame (Medium).jpg
ID:	537128   Click image for larger version
Name:	A Frame at the Drags (Medium).jpg
Name:	A Frame Engine Hoist (Medium).jpg
ID:	537130   Click image for larger version
Name:	lastscan (Medium).jpg
Old 11-20-2008, 05:57 PM   #17
GuyW
Grenade Inspector
GuyW's Avatar
Check out this 'un...
Old 11-20-2008, 07:01 PM   #18
boldventure
Senior Member
boldventure's Avatar
Quote:
As long as the pipe is strong enough...
That one looks like a neat design, not too portable but the swing out of the way idea...I like it! What was old is new again.
Old 11-20-2008, 09:04 PM   #19
spiffy1937
Alliance Member
spiffy1937's Avatar
Look on page 74-75 of the new Rodder's Journal # 42. Referring to that picture,I'd just make sure that the elbows joining the legs to the crossbar couldn't turn on the threads and let the base of the legs slide apart collapsing the frame. Also, look on page 81, same issue. I'd scan it but don't want to piss off Steve Coonan!
__________________
It's never too late to have a happy childhood!
http://www.dogsindanger.com/
http://www.petfinder.com/shelters.html
Old 11-20-2008, 09:09 PM   #20
spiffy1937
Alliance Member
spiffy1937's Avatar
Now, that's really trick!!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
