Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 | ||
Old School HAMBer
I've been posting a lot on the Model T Ford Club of America forum lately. This is my most recent post. In the process, I posted this picture:
![]() This was the second response I got: Quote:
Quote:
-Dave Conwill |
#2 |
Grenade Inspector
wow, thats the second Riley I've heard of in about a month. There is one on the cover of the May 2006 Street Rodder Mag. Intresting to see what comes of this one though.
#3 |
Old School HAMBer
I feel a bit stupid here, but I'm not really sure what a Riley Multi-Lift is. I've heard of Riley heads, but does this mean they made special lifters for Fords as well?
#4 |
Senior Member
Its kinda exciting to think where this could go.
Theres a couple of pics of Multi's car on the American Hot Rod Foundation website in the Julian Doty collection. http://www.ahrf.com/image_detail.php...CategoryID=139 http://www.ahrf.com/image_detail.php...CategoryID=139 Looking in the background of the AHRF pictures makes you wonder if the above picture is not as old as first appears. Julian Doty is currently on the "Ask The Expert" list. Maybe you could put a question forward about the car. |
#5 |
Old School HAMBer
Wow. These are the first images I've seen of anything other than the front of the car.
I desperately want to know more about the car and its owner. I guess I'll head over to the Ask the Expert section. I haven't done that yet because I haven't been able to think up some good questions. ![]() Gorgeous. |
#6 |
Old School HAMBer
As far as the age of the car... the plate says 52, doesn't it? Background looks right for 1952 to me, or am I missing something?
#7 | |
Senior Member
Quote:
Good point! Being British I didn't think to look at the plate for the year. What I meant was the picture looks 30's but is properly later and it is! Its '52! |
#8 | |
Old School HAMBer
Quote:
( and i bet you want to too)
__________________
"You can always find someone who has never been there to explain how easy it is".......Me |
#9 | |
Senior Member
Quote:
So simple and clever. Heres the original adverts for them. There is much more history on them in the 'George Riley Racing Scrapbook' by Dan Iandola. There is currently a copy of this rare book on Ebay. ![]()
#10 | |
Old School HAMBer
Quote:
__________________
#11 |
Old School HAMBer
Could these be fitted to a Model A motor as well? Seems I've heard of A cams being run in T motors, so it seems like it's a possibility.
#12 | |
Old School HAMBer
Quote:
The basics are the following: (i haven't done this in a few years, so it is kinda rusty) Get a nice clean A or B cam, and have it ground. The cam bearings need to be cut down to fit the bore size for the bearing (the A cam basically just runs in the block with no bushings or bearings) i want to say that the bore sizes are 1.25, 1.25 and .997 You need to cut the nose off the end of the a cam and bore the end out, make sure you cut a nice 45 on the face of the cam so you have a way to get good penetration on your future weld... Take a T cam, cut the nose and the 1st bearing surface off of it. Turn this down so you have a very tight fit when you press it into the A cam. Make sure you line up the timing before hand (this can be done by lining the pin on the T head with the center line of the first lobe: SWAG) Press that bad boy together and have it welded. You will now need to notch the T block to accept the A cam (as the lobes are bigger). The basic idea...and where i just plain dont remember...is that you need to cut 2 notches in the cam bearing housing. This allows the cam to slide into the block (if you didnt do this, the cam lobes will hit the cam bore and not go in) Take a dremel and cut out a recess (needs not be bigger than the nose of the cam) in the 1st bearing. Cut it on the top of the bearing, as there is less force applied there. Personally i would cut it at slightly off of TDC (like 15 degrees). Do not notch the second bore!!! After you can slide the cam in up till the 2nd bearing is in the 1st hole (wonderfully technical, eh?), you will be able to see where you need to cut the notch in the second bearing bore. Repeat. I am typing this up at my office, sorry if the description is lacking and that there are no pictures (other than the ones in my head)
__________________
#13 | |
Quote:
A week later, there's ANOTHER copy for sale, same price, IN THE EXACT SAME PLACE AS THE FIRST??? WTF?? I think they may have a few copies. PM me if you want the info.
__________________
Just another broken down old moldmaker, carving away at Bear Metal Kustoms
#14 | |
Old School HAMBer
Quote:
__________________
#15 |
Back in '83 me and a friend was doing the grand american tour, driving from coast to coast and back again. Visiting Bonneville for the Speedweek was one of the must-do things on our journey. However, when we got to SLC we got a bit worried, as the lake was far away from being dry. We got more and more depressed the closer we got to Wendover, realizing there could not be any racing going on with 2 feet of water on the lakebed. We turned off from the freeway, passed the Phillips 66 station, and just by the road was a sixties Ford station wagon with a funky trailer. There was an SCTA sign on the trailer so we stopped for a chat. An older couple greeted us, they presented themselves as Multy and Vera.
We stayed and talked with them for the rest of the day and returned the following morning to buy some shirts and posters, trading addresses. We kept in touch for some years, and Multy kept sending us long letters. He always made sure to include Bonneville memorabilia like stickers, patches, posters, and best of all: small packets of salt sampled from the race course. In his last letter he told me that Vera had passed away, after that I lost contact with him. They were such sweet people, and I can still miss Multys letters. Their card said it all: ![]() I knew Multy had been racing a T, but I never got to see a picture of it. Many thanks for posting it, I hope to see the real deal one day.
__________________
Peel Out! |
#16 | |
Grenade Inspector
Quote:
Thanks for sharing you story, sometimes the word isn’t so big. Here is some picks of a nice T I saw 2003; I don’t know what kind of engine it is. Lars
__________________
“One person's crazyness is another person's reality” |
#17 | |
Old School HAMBer
Quote:
that is one killer rig.
__________________
#18 | |
Senior Member
Quote:
Its a one off by the original owner. The ignition is Stutz, dual dizzys. |
#19 | |
Grenade Inspector
Location: Yucaipa, Calif, USA(not to be confused with Yucca Pie)
Quote:
It was originally built by a Robert Hodge, who was wrongly attributed in the story to being from Orange, Cal. He was actually from Rialto, his father being the City Attorney there. Multy was from Rialto as well. You can imagine Bob and Multy driving from Rialto to Orange on warm summer Sat nites to race other hotrodders in the orange groves in the late '30s. For SoCal folks, if you go to Costco(or the local Barns/Noble) you find those hokey sepia-toned "Images of America" books, where some guy has blown into the local historical society in town and assembled a book made up of old black/white photos, and markets them for the local surrounding areas. I got em for Redlands, San Berdoo, and Rialto. In the Rialto book is a picture of a young Roy Aldrich with his scout troop hiking to Mt Baden-Powell in 1931, and a very young Bob Hodge in the early '30s sitting in his T, already with the trick motor, Buffalo wires and knockoffs, but still in shiney paint with a touring body and fenders.
__________________
You might remember me from such nature films as 'Man VS. Nature; The Road To VICTORY'? |
#20 | |
Old School HAMBer
Quote:
(second time i f'ed that one up)
__________________
| Thread Tools | |
| Display Modes | |
