Reply
Thread Tools Display Modes
Old 03-26-2006, 02:58 PM   #1
Johnny Sparkle
Senior Member
Johnny Sparkle's Avatar
Default Why is my air compressor making so much water?
I put in a new dryer yesterday to combat the water, but there is so much it is still coming through. My air tools don't like it very much. The compressor is getting pretty warm, is it supposed to? I have it behind a makeshift wall to cut down on the noise, but there is plenty of space above for air to get through. The pic of the water coming out of the dryer is after about 10 minutes of use. The water doesn't hit the receptacle, before anyone asks.
I'm not sure what to do here, any help would be appreciated.
Click image for larger version
ID:	174108   Click image for larger version
online   Reply With Quote
Old 03-26-2006, 03:05 PM   #2
Upchuck
Senior Member
Upchuck's Avatar
Default Re: Why is my air compressor making so much water?
lots of humidity in the air this time of year with the snow melting and whatnot
offline   Reply With Quote
Old 03-26-2006, 03:17 PM   #3
Bored&Stroked
Alliance Member
Bored&Stroked's Avatar
They will do this -- especially with high humidity and when you're running them hard (like air sanders) and they are hot.
Do you have a drain in the bottom of the tank? You most likely have lots of water in the bottom of the dang thing. Also - you might want to put an air-filter down stream a bit -- as it will remove more water once the air cools (which happens downstream).
__________________
As my old buddy used to say . . . "Gas, Grass or Ass" - nobody rides for free ! Seemed he was always alone . . .
Old 03-26-2006, 03:25 PM   #4
Johnny Sparkle
Senior Member
I've been draining it out every night. I have the dryer at the end of my piping, but I was told I may have my piping a bit too short, it's only about 10 feet long right now. I might end up lengthening it. It just seems to make an unusual amount of water, though I am running an air sander and die grinder, so it is on quite a bit.
Old 03-26-2006, 03:51 PM   #5
rattlecanrods
Grenade Inspector
rattlecanrods's Avatar
Try setting up a box fan to blow over the pump. Cooling the pump will cut down on the production of condensation. This worked amazingly for me while I was sandblasting.
__________________
To every good project, a little blood must be donated.
Old 03-26-2006, 03:54 PM   #6
polisher
Alliance Vendor
Smile Re: Why is my air compressor making so much water?
We put an old twenty gallon tank in our line nearly 20 feet from the compressor, then a watertrap and filter and water still gets by.
Guess a big old expensive commercial dryer is gonna be the only way.
__________________
Polisher
www.englishcustompolishing.com
victim of excess
Old 03-26-2006, 05:43 PM   #7
Digger_Dave
Old School HAMBer
Quote:
The one picture shows the compressor in a fairly tight space. Like rattlecan says, you would help things if you could cool the compressor down with some cooler (outside) air. Or run large diameter hose to the compressor air inlets to the outside. (cooling the heads would be better)
Then as polisher says, a second air receiver (old compressor tank) hooked into the outlet line as far down stream as possible (could even be set outside the shop) would give the moisture in the air, time to condense. The extra tank also acts as a "buffer" (extra capacity) that cuts down on "cycle time" of the compressor as well. (helps if you use your air tools a lot)
Keep in mind that in high humidity conditions the air seperator or dryer is going to "pull off" lots of moisture which is what they are supposed to do. (moisture will collect in the tanks also)
Another accesory I use is an "Automatic Line Oiler"; (automatically puts a shot of oil in the line going to your air tools) lets the tools live longer. I set up a box with a filter, moisture trap, a line oiler and a retractable hose on castors, to use just with air tools.
The couplers are different than the regular air line couplers so oil contaminated hose can't be accidently used for paint or sandblasting
__________________
Digger Dave
Flathead Fanatic
"A cluttered workshop, is the sign of a GENIUS at work!*"
(*unless they were messy to begin with!)
Old 03-26-2006, 05:45 PM   #8
gasheat
gasheat's Avatar
I have always heard to keep the hose off the cold concrete floor. It supposedly speeds condensation.
__________________
God Bless Ed Iskendarian
Old 03-26-2006, 06:22 PM   #9
williebill
Senior Member
I have a fan that blows cool air across the pump anytime the compressor is running...also bought a dehumidifier a few years ago for the garage..The house heat and air are piped into the garage,but the dehumidifier sucks out a ton of water any time I turn it on..Not sure it helps much,my compressor blows a lot of water,too,but I figured anything that cut down on humidity in the garage was a good thing.
__________________
East Coast styling then,now,and always
Sell me your Appleton 552s...they look ugly on your car
Old 03-26-2006, 09:36 PM   #10
atch
Old School HAMBer
atch's Avatar
wish i had a pic of it: my neighbor has a cabinet making shop (kitchen type cab'ts for new homes) and when they use air they REALLY use air. they have two big compressors. he made condensors for them out of old refrigerator heat exchangers. i don't remember exactly how they are positioned, but i think i remember a tank on the bottom of each one where the water collects; and they are in the air stream that the compressor pulley/fan creates. and the compressors are outside the shop under a porch style roof that they built for just the compressors.i'll see if i can take a pic sometime and post it.just a thought in case it helps anyone or gives someone an idea.
__________________
atch (Mike Atchley)
MO hambers - join Missouri H.A.M.B.ers and check out this thread
Old 03-26-2006, 09:36 PM   #11
kenagain
kenagain's Avatar
another thing that helps is to put a down leg off a tee fitting where it comes out of compressor line run the output up in the air and around to where you use it and another drop leg there with tee to supply= use a couple of china freight ball valves to blow legs down when using it
Old 03-26-2006, 09:44 PM   #12
choprods
Alliance Vendor
choprods's Avatar
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
Is your motor a 3450 RPM model? And is that a single stage pump?
If so that is the main source of the excessive moisture......
The pump rpm is fast[about exactly double] on the single stage compressors and makes a lot of water.....
__________________
Running in place, will never get you the results that running from a Lion will.....
Old 03-26-2006, 10:56 PM   #13
slamdpup
Senior Member
slamdpup's Avatar
i have on my compressor 2 water traps. self drainers ..1 off the tank and the other at the end of about 20 feet of pcv (3/4'') ..i dont have a water problem at all..i empty my tank about once aweek...the self drainers are the way to go
Old 03-27-2006, 01:39 AM   #14
eye bone
eye bone's Avatar
Also make sure you change the oil regularly (once a year, or whatever your rig requires). Obviously more friction causes it to run hotter, and when it's wet like this winter the hotter it's running the more condensation it will create. Anything you can do to cool it down should help (some really good ideas in this thread).
Make sure you keep draining that water from the tank. Over the years it can rust a weak spot into it with disastrous results.
Also I run a water trap at the compressor and one I hang on my belt loop, or at my airbrush easel.
That's my two cents. Good luck with that!
__________________
"Ain't got no spare, ain't got no jack, don't give a shit I ain't commin' back!" Tom Waits
http://www.eyebone.com
Old 03-27-2006, 07:58 AM   #15
4t64rd
Old School HAMBer
4t64rd's Avatar
Location: Pinellas County - the skin tag on the underside of America's wang, Florida
I'm gonna get me one (or 2) of these...
http://www.paragoncode.com/shop/compressor/
FL is juicy and my 60 gallon tank always has a little water in it, that thing would finish the problem for good.
I have 1/2" black pipe lines running into the rafters (Home Depot was moving to a new building and everything was 60% off), after the first 10 foot run (angled to let the water in the line run towards the next drop), I made a drop that went all the way down to a spare 20 gallon tank and back up again, then after the second 10 ft run (same angle thing), I have a drop, that goes down to a petcock a few feet off the floor and then up to an oiler/water separator, and I have the quick connects there one for tools (oiler side) and one for the touch up gun/sandblaster.
Old 03-27-2006, 08:14 AM   #16
Old School HAMBer
squirrel's Avatar
the solution I've found (as if anyone from AZ should be contributing to a humidity thread!) is to run a pipe around the top of the shop, with air drops every 20 feet, and a drain below each air outlet. Use the last drop on the system when you're doing high air demand stuff. In my shop the compressor is near the "machine shop" end, then the air piping goes around to the opposite side of the shop and then down to the end where I do the sandblasting. When opening all 5 drains in turn, the one at the end of the line is usually dry.
__________________
Jim Forbes
my shtuff
Old 03-27-2006, 08:19 AM   #17
FiddyFour
Old School HAMBer
the longer your lines are, and the longer your drops are the better. as squirrel said.
one added benifit of longer line runs, is added capacity to the system... more capacity = less compressor running = less heat = less condensation
Old 03-27-2006, 09:56 AM   #18
FNG777
Alliance Member
The Boys at our Truck Shop were having the same problem They somewhat solved the problem by attaching one of those stick- on 110 volt heaters to the airtank. The warmth from the heater helps keep the air dryer.
Old 03-27-2006, 11:33 AM   #19
Slide
Old School HAMBer
Slide's Avatar
During the more hmid times of the year, my dad says he actually lets the drain of the compressor "leak" a little all the time. The hiss can be annoying, and you'd need a compressor that's well more than capable of handling whatever demands you put on it, but it can be an option.
Another thing that I have seen done that works real well is to run a hose from your compressor to the wall, hooking that to a hard line that goes up to where your wall meets the ceiling. Then run your horizontal line down the wall, but letting go kinda down hill... dropping a few inches every 10 feet or so. Then tee off this line to go back down the wall to your connection for the lead hose & tools.
But... here's the important part: point your tee up, then use a couple elbows so the drop to your "outlet" goes up, makes a u-turn then down the wall.
Then at the end of the "almost horizontal" run, turn 90 degrees down toward the floor. At the end of this, put a ball valve or gate valve to drain the condensation in the lines.
What all this does, it gets moisture running down hill... eventually to the drain valve mentioned in the last paragraph. Since the tees to your "outlets" are on the top side of the down hill run, the moisture will not try to defy gravity and go up into your "tool" lines.
__________________
Just because you can doesn't mean you should.
www.mikeshoaf.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
