??????????? Did he break a rule? '64-'65 Falcons are nearly identical, so accepted here. And likewise the intro isn't required. To the OP, Need to know a bit more info on your Falcon build, as to whether you have plans to buy a straight axle kit, or use a donor axle. Also engine/drivetrain plans. All the info will help determine what direction your straight axle needs to take.
It appears that he was unsure about where to post and this was posted in the to the editors section,questions & answers and was bombarded with the typical BS reply's of... post a intro,,your in the wrong section and no real help. I believe he has left the building. If the OP returns,,try this thread,,just click on it. HRP http://www.jalopyjournal.com/forum/showthread.php?t=80033&highlight=falcon+gasser
