Speedometer cable lubricant
Discussion in 'The Hokey Ass Message Board' started by oleskool, Apr 24, 2010.
  1. oleskool
    oleskool
    :confused: What is the best lubricant to use on a speedometer cable?
    :)Thanks for your input.
  2. 29nash
    29nash
    from colorado
    Just about any grease.
  3. bobscogin
    bobscogin
    Don't know what's best. but I've always gotten good results from white lithium grease.
    Bob
  4. dmac620
    dmac620
    Graphite in a spray can. Can be found in Lowe's or Home Depot. Just did mine a couple of months ago and had good results.
  5. brad chevy
    brad chevy
    Xs-2 on white-lithium grease
  6. AAFD
    AAFD
    from US of A
    Any Lithium-Based Grease will work best. Always clean the cable with solvent and blow dry (or air dry) it, then add the new Lithium grease.
  7. pauls fords
    pauls fords
    Grease eventually hardens and the speedo will start to jump around, go to a parts store and ask for 30ND motor oil {non detergent} 30 weight, saturate the inner cable when assembling it. I use 30 ND because any multi visc oil 10-40 will dry up because it has detergent in it.
  8. Mr48chev
    +1 that is all I have used for the past 45 years.
  9. AAFD
    AAFD
    from US of A
  10. Deuce Roadster
    Deuce Roadster
    O'Reilly's Auto Parts actually sells a SPEEDOMETER CABLE lubicant. It comes in a small tube ... costs about $2.50 or so and I just bought some a few days ago for the speedometer in my 32 roadster.
    After 15 years on the road ... the cable has a slight twitch and need lube.
    I plan to take care of that item tomorrow :D
  11. claymore
    claymore
    Powdered Graphite comes in a nice little tube like a toothpaste tube with a nice small opening to put into the housing. Never dries out or leaks.
  12. tommy
    tommy
    The graphite lube that I used made for speedo cables came in a tube mixed with alcohol. The alcohol carried the powdered graphite all the way to the other end of the cable. The alcohol evaporates leaving the dry graphite inside to lubricate the cable. Disconnect both ends and pour it in from the top. When it comes out the bottom end, you know that the entire length got lubricated.
    -Brent- likes this.
  13. knotheads
    knotheads
    graphite is what we always used when i worked at service stations. (remember when service stations did lube and oil changes?)
  14. burnout2614
    burnout2614
  15. They have been using Grafite ever since Car's were Built
    so I like Grafite & have been using it on All my cars
    since the 50's
    Just my 3.5 cents
  16. 39cent
    39cent
    from socal
    my Dad told me to use graphite, that was for my first car a Model A, [in 55] ggg
  17. 61bone
    61bone
    Graphite or dry lube. Doesn't dry, gum or cause speedo to run slow when cold.
  18. Model A Speedster
    Model A Speedster
    If you can get the cable and housing off the car, do so. Pull the cable out of the housing and clean it as best you can. Suspend the housing so that it hangs straight up and down with a coffee can underneath. Now pour some STP down the housing and let it drip into the coffee can. This will take a while. Reassemble. Enjoy. From an old Model A guy.
  19. 4dFord/SC
    4dFord/SC
    Think I used Vaseline the last time I did mine, X years ago.
  20. Clik
    Clik
    Many years with motorcycles taught me to NOT use anything but graphite on cables. Oils and greases get very stiff in cold weather. I use graphite spray with the alcohol carrier. The alcohol evaporates leaving only the graphite.
    Murphy32 likes this.
  21. They actually used to sell ( and maybe still do?) a spray in most auto parts called cable lube and that is what it was or is, a graphite lubricant in an aerosol can.
    grease is cool unless you live where it gets colder than a witches tit then it is not so good.
  22. 61Bone and Beaner are right on. Any lubricant will work as long as it hasn't gotten contaminated with dirt or water, but graphite doesn't harden in the cold. That's why its also used on door locks.
  23. Bert Kollar
    Bert Kollar
    In the 50's we used dry Graphite on the cables and door locks
