1954 chevy wheel bolt pattern dimensions
Discussion in 'The Hokey Ass Message Board' started by originalstack, Sep 17, 2007.
  1. originalstack
    originalstack
    I would like to know what the bolt pattern dimension/measurements are for stock 54 Chevy wheels ? Thanks ! Originalstack
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    5 bolts on a 4 3/4" circle, same for most Chevy passenger cars from 1949 to 90s. Some big cars use 5 on 5" circle, wagons, El Caminos, and such.
  3. 40Standard
    40Standard
    from Indy
    4 3/4 inch for passenger car rims
  4. 52RustRocket
    52RustRocket
    While we're on the topic, I'm looking for 2 steel wheels with that lug pattern that will accept full hub caps. Anyone know where to get some?(cheap)
  5. The problem on 49-54 Chevys isn't the rim accepting the cap, any cap of the proper size fits stock 49-54 rims. But the front spindles poke way out of the narrow rims on the front, so a lot of caps won't clear it.
    53-54 Chevy fit; 58-62 Rambler fit, and anything else with a deep peak to them.
    As for rims, any yard should have them; and you can probably pick between 14" and 15" if you poke around a little.
  6. Chaz61
    Chaz61
    from NY
    Do you know the backspace needed to eliminate the spindle problem for new set of chrome wheels on a 54chevy.
  7. 2racer
    2racer
  8. banditomerc
    banditomerc
    my 1953 chevy 210 has 5 on 5 bolt pattern....anyone here know why? i thought they were all 5 on 4 3/4
  9. old thread , but why not......either the bolt pattern has been changed , or you are not measuring it correctly
  10. gimpyshotrods
    gimpyshotrods
    No, it does not, unless you have conclusive evidence that the hubs/axle flanges have been re-drilled.
  11. banditomerc
    banditomerc
    here is the proof that my 1953 chevy 210 coupe is a 5 on 5 bolt pattern....the car components are stock.5 on 5 is a pontiac ,buick pattern,correct?
  12. squirrel
    that looks like you're holding the measuring tape a quarter inch too far to the left. The measurement in the drawing above is to the outside of the stud, not the nut.
  13. 54 Chevy
    54 Chevy
    My 54 was 5 by 4 3/4 when stock
  14. gimpyshotrods
    gimpyshotrods
    Yup, put the hook on the wheelstud.
