ford engines
Discussion in 'The Hokey Ass Message Board' started by verde742, Mar 15, 2014.
  1. verde742
    verde742
    Bought a Ford pickup with big Ford V-8 auto, how can I tell what engine and trans does it have? It has Edelbrock aluminum intake and carb, with no numbers I can find. anywhere.:confused:
    thanks fer any help..
  2. thunderplex
    thunderplex
    Posting pictures would help to ID which series Ford engine.
  3. V8 Bob
    V8 Bob
    My crystal ball is broken at the moment, so unless you can describe it much better, a picture or two would really help ID the engine.
    :confused:
  4. slowmotion
    slowmotion
    Need more clues. Snap a few pics & one of these Ford guys will nail it right quick I reckon.
  5. verde742
    verde742
    i wish I knew how,
    will try to get help later.
    .just thought maybe there were things to look for..
    thanks.
  6. pbr40
    pbr40
    from NW Indiana
    Check the numbers out. Pop a valve cover off. Check around the starter bell housing area for number then just punch them in
  7. Heo2
    Heo2
    If the intake and head is parted inside the valvecover
    its an FE Engine 332-428
  8. Heo2
    Heo2
    If the thermostat is in the block and not the intake
    Its a 400M
    Any script on the valvecovers?
  9. Engine man
    Engine man
    from Wisconsin
    Or a 351 Cleveland.
  10. 58custom
    58custom
    Or a 351M. BTW, 400, not 400M.
  11. 58custom
    58custom
    Quick Ford OHV V8 family identification:
    2 valve cover bolts: Y block
    5 valve cover bolts: FE
    6 valve cover bolts: small block (260, 289, 302, 351W etc)
    7 valve cover bolts: 429/460
    8 valve cover bolts: Cleveland series
    Within these families are various displacements and deck heights. Need pix or more info.
    Missing: Lincoln MEL series and Y blocks cuz I don't remember.
  12. FrozenMerc
    FrozenMerc
    An MEL engine has 6 valve cover bolts and a Lincoln Y will have 2 just like its smaller Ford brother. But with a truck it is highly unlikely it has either of those motors unless it is a large Medium or Heavy Duty series truck, or someone did a swap at some point in its life.
  13. verde742
    verde742
    yes it is 1/2 ton short-wide,, lots of changes,,
  14. s55mercury66
    s55mercury66
    from SW Wyoming
    What year Ford pickup is it?
  15. verde742
    verde742
    Just Chrome Edelbrock valve covers, intake, & carb..
  16. verde742
    verde742
    1958 but so much is different from stock,,
  17. 57Custom300
    57Custom300
    from Arizona
    From what 58Custom & Frozenmerc posted you should be able to get a basic idea of what you have.
  18. boutlaw
    boutlaw
    Call the previous owner and ask him/her what engine you have since you can't post a pic. 58 Custom has provided the best info to make an educated guess.
  19. mechanic58
    mechanic58
    Ford only made 2 engines. They made a 302 and a Y-block. So it's one of the two.
  20. tommyd
    tommyd
    from South Indy
  21. kracker36
    kracker36
    Probably a 350 Chevy with a Turbo 350 transmission.
  22. verde742
    verde742
    read the first post...
  23. Chiefrider
    Chiefrider
    from Lower 48
    534 with a Lincoln auto
