Camel Back Heads?
Discussion in 'The Hokey Ass Message Board' started by Chester, Jun 17, 2012.
  1. Chester
    Chester
    from At work
    In the classified section of my club magazine I frequently see ads that reference camel back heads.
    What exactly is a camel back head?
  2. Gizzy
    Gizzy
    from N.W,Ohio
    327 dbl humps,need a set?i have an extra pair
  3. tommyd
    tommyd
    from South Indy
    The heads have a couple of little humps in the casting near the deck surface. One chevy's early efforts to be cool like the Ford guys....didn't work.:D.....easy fellas' just yanking your chain!:p
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    202 valves and the rears are Also I think came in 194 and 1.50 It just means bigger valves
  5. F&J
    F&J
    Google image search: They came in 2 sizes of intake valves 2.02 and 1.94". These are the early heads from most of the 60s, without accessory holes in the ends of the heads.
  6. biscaynes
    biscaynes
    casting mark on the ends of the cyl head, bigger valves, 1.94 or 2.02 intakes.
  7. Chester
    Chester
    from At work
    Thanks for the info.
  8. They are generally referred to as Camel Hump Heads, not camel "Back".
  9. nutajunka
    nutajunka
    And double hump, they were also made with the acc. holes.
  10. 49ratfink
    49ratfink
    Camel Hump heads are so cool a frind of mine milled Camel Humps in his aftermarket aluminum heads.
  11. Yes later heads did come with accessory holes and were the same head otherwise.
  12. AG F/C
    AG F/C
    To add to the above mentioned, Many versions of Camel Hump heads were made. they were used on the upper HP SBC's say 327-250 and up. The heads for the most part flow better then the LOPO versions of the day. The small valve versions are very common 1.94-1.50 but can be machined for 2.02-1.60 as GM made them both ways for a given casting number The casting number will make or break the value EG a 461 as opposed to e 461X. If you find a set of 461X heads for a good price I'd grab them. Use the online casting number listings to see what you might be buying.
    For a period Hot Rod the early 327 heads without holed in the front are a good place to start with for a "Belly Button" (SBC).
  13. Sweepspear
    Sweepspear
    And here I always thought it referred to heads shaped like these.
    But, what do I know. I'm a Buick guy. :rolleyes:
    Learn something everyday I guess.
  14. mrconcdid
    mrconcdid
    from Florida
    bottem line, they were the preformance head for there day.
    camaros and corvettes had them.
    I think they also came in 58 and 64 cc sizes with 2.02/1.60 valves
    the later versions did have accessory holes in both ends.
    Godspeed
    MrC.
  15. chaos10meter
    chaos10meter
    from PA.
    The marks are actually what's left of the in gates used to feed the molten metal into the part when pouring at the foundry
  16. Just remember anything without a belly button is an alien. :eek:
    The smaller combustion donot like the 2.02 valves real well, they will have to be unshrouded if you go that route.
    Those are actually W heads, but it is an honest mistake. That is whay we congregate here to help us realize what it is that we know and what it is that we don't. I am forever running onto things that I thought that I knew and then found out that I didn't.
    I have found good information when I can't remember here:
    http://www.fastnuf.com/Headguide.html
  17. how do you mistake a W head for just a camel head? haha
    and camel heads are the ones that hold more water..duh!
  18. Also, Mickey Mouse heads.
  19. davidbistolas
    davidbistolas
    What about Cameltoe heads?
  20. luckyuhaul
    luckyuhaul
    Prone to cracks!
    Comes in lightweight or heavyweight versions, some access holes.
    Early models not permitted, remember, pre - 1964.
  21. Chester, I'm not at all trying to be a wise guy here, but do you drive truck or have friends that do?
    " Camel Back " rear axles are popular on Mack heavy duty rigs especially those used on and off road like dump trucks. Picture a 9" Ford rear and turn the housing 90 degrees so that the center chunk is facing upwards and the back of the housing now faces downward.
    Instead of the drive shaft going into the center of the front chunk and through the axle housing into the front of the rear tandem axle front chunk, it goes longitudinally on top of each axle housing. The pinion being now on top of the rears looks like two humps, hence the Camel Hump rears. Mack engineers believe they are both stronger and they provide much needed ground clearance for off road use. Probably has nothing to do with the price of rice in China, just trying to help, TR
  22. partsdawg
    partsdawg
    from Minnesota
    2.05 Buick valves will work in those heads.
  23. pitman
    pitman
    I've also heard the 1.94"s refered to as 4-bbl heads. They did not crack as often between the two valve seats.
  24. xtralow
    xtralow
    from So Cal
    what are a used set of camel back heads worth?
  25. MATACONCEPTS
    MATACONCEPTS
    They make a SBC cool
  26. MATACONCEPTS
    MATACONCEPTS
    Camel Humps are one of the first things you look for when you check out a SBC
  27. falcongeorge
    falcongeorge
    from BC
    Hmmmm...
  28. Drive Em
    Drive Em
    My dad has a 348 in his truck, and it never fails at a car show or cruise night for someone to look at the engine and tell his girlfriend or wife "Honey, those are Camel Back heads."
  29. theHIGHLANDER
    theHIGHLANDER
    Not much. Ya gotta walk a mile to get em...:cool:
  30. Ester Eddie
    Ester Eddie
    from Alaska
    I was wondering when a camel toe would get tossed in here:D
