Technical FRAME, basic frame fabrication condensed version
Discussion in 'The Hokey Ass Message Board' started by Paul, Dec 8, 2005.
  1. Paul
    Paul
    Editor
    ok,
    here is the condensed version
    compiled from all previous threads in this series.
    a step by step on how to build a Model A frame out of a bunch of tubing,
    an aftermarket front cross member and stock rear cross member..
    earlier this week I picked up a couple sticks of 2x4x.120 rectangle steel tubing
    with the intent of making a Model A frame
    partly because I will be needing one soon
    partly as an exercise and also to see if I wanted to try to make them for sale
    I have a straight but crusty stock frame to use as reference
    so I got started on it yesterday,
    first I made a pattern of the frame horn..
    because it makes sense to start at that end
    and transfered that to the tubing
    then shifted the pattern to layout the actual cut line
    I will leave the rolled edge and make the weld on the flat
    kidcampbell71 likes this.
  2. Paul
    Paul
    Editor
    then using a snipped off blade in the sawsall
    I first made the long straight cut along the bottom of the tube,
    followed by the long curve
    rolled it over and layed out and cut the opposite side
  3. Paul
    Paul
    Editor
    then I ground all edges clean to the scribe lines
    clamped it to check fit and final shape with the pattern
    took the clamps off
    ground a bevel along the joint
    clamped and tacked it to hold
    reclamped it to the frame table to keep it straight
    an welded the first side up
    Tim and kidcampbell71 like this.
  4. Paul
    Paul
    Editor
    then after it had cooled
    I rolled it over and clamped it with the opposite face up
    tacked it
    and welded it too
  5. Paul
    Paul
    Editor
    ground the welds down,
    with the deep bevel and a good weld this makes a nice clean joint
    with minimal weld material removed
  6. Paul
    Paul
    Editor
    next I trimmed the short curve at the top of the rail
    beveled the edges
    and clamped the soft part of the curve
  7. Paul
    Paul
    Editor
    checked the shape with the pattern again,
    welded that up,
    trimmed the excess strip at the bottom
    rolled the top strip over the tip,
    checked it's shape with the pattern again
    and welded the end up
  8. Paul
    Paul
    Editor
    then I layed out the slice at the inside of the horn to look similar to the stock frame
    trimmed it with the little grinder with a thin disc
    and cleaned it all up
  9. Paul
    Paul
    Editor
    so
    there is one frame rail horn with a shape very similar to the Stock Model A shape
    brEad and kidcampbell71 like this.
  10. Paul
    Paul
    Editor
    need two rails to make an A frame
    so,
    following the same procedure
    a twin was born..
    that was yesterday,
    today I will try to make them look more like a frame
  11. Paul
    Paul
    Editor
    ran out of grinder discs,
    so while the welds cool and before i go get some more,
    here's an update;
    measured the stock frame again, this time for the rear taper,
    I'll make the slice right in the middle of the side,
    tapering both top and bottom trying to minimize warpage
    so to end up with a two and a half inch tube height at the end I leave an inch and a quarter top and bottom, tapering to meet at the center 30" forward
    with a small piecut towards the bottom leaving the bottom strip intact
    again with the sawsall and grinder with the thin disc the cuts are made,
    the edges beveled and the rail clamped to the frame table
    and tacked
  12. Paul
    Paul
    Editor
    and welded,
    then repeat with the other rail...
    and sit down to post pictures on the hamb :)
    more to follow.
  13. Paul
    Paul
    Editor
    last pictures for the night as I close shop
  14. Paul
    Paul
    Editor
    it doesn't get much more basic than this type of frame step or "Z"
    today I stepped my new A frame that I started last week
    I am going with a pretty minor step but the technique could be used for a more severe step
    or for splicing a sub frame
    first I cut two plates to be welded between the frame sections
    cut them as wide as the frame and as deep as the frame plus the depth of step
    I am going with a two inch step, so that plus the four inch of frame means 6 inches- less a shy eighth all the way around for room for weld
    then layout and cut the frame,
    I cut mine right at the firewall
    so the step will not show
  15. Paul
    Paul
    Editor
    then with everything all clamped nice and solid,
    tack,
    and make the first welds
  16. Paul
    Paul
    Editor
    cut some gussets from the same dimension material as the frame,
    mine are 45 degree wedges
    with everything still clamped solid
    weld the first two in,
    let it cool,
    roll it over
    and weld the other two
    before it's done
    plate will be added to the sides to further strengthen the area
  17. Paul
    Paul
    Editor
    and finally another mockup
    I will channel the body over the frame the depth of the frame,
    measured at the bottom of body
    the body should be about a foot lower than stock,
    still have enough suspension travel to not bottom out,
    even with a mild chop there should be plenty of head room
    and with the frame six inches longer than stock between the firewall and front cross member,
    I won't need to tunnel the firewall so leg room will not be compromised
  18. Paul
    Paul
    Editor
    rear suspension 051.jpg another day,
    put a few hours in on the A's rear suspension
    it's all tacked,
    need to make a minor adjustment or two
    and it'll be ready to weld up.
  19. Paul
    Paul
    Editor
    more..
  20. Paul
    Paul
    Editor
    I did go at this one totally backwards,
    I set the frame at ride height
    mocked up the body over it
    put the cross member where it didn't take up the whole trunk
    stuck the spring in the cross member and measured everything up
    then clamped the frame and rear cross member to the frame table
  21. Paul
    Paul
    Editor
    and filled in the gaps
    rear cross member 008.jpg rear cross member 013.jpg rear cross member 016.jpg rear cross member 020.jpg rear cross member 023.jpg
    volvobrynk and kidcampbell71 like this.
  22. Paul
    Paul
    Editor
    I measured the spring when it was mocked up,
    crossed my fingers and whittled out some hangers
    rear suspension 009.jpg rear suspension 010.jpg rear suspension 021.jpg rear suspension 024.jpg
  23. Paul
    Paul
    Editor
    hacked the bushed ends off some extra spring on top type hangers I had laying around
    split the brackets to fit over the rear
    and welded them together,
    bolted the shackle in place
    letting the bracket float on the axle
  24. Paul
    Paul
    Editor
    nothing to the ladders
    just split to fit over the axle
    weld them back together
    position everything the way you like it and tack it all in place
    they save some fab time,
    but are not the cheapest way to go.
    I am sure if I took the time to make up a jig
    to position a tap square to the tube
    -wouldn't even need a lathe-
    I could have saved a hundred bucks easy.. maybe more..
    rear cross member 002.jpg rear suspension 039.jpg rear suspension 048.jpg rear suspension 047.jpg
  25. Paul
    Paul
    Editor
    next I put together a pair of motor mounts for the little Chevy in my Model A
    this is again,
    like most of my so called tech threads
    very basic,
    nothing strange or exciting, just something to get the job done
    actually I'm only half done,
    I still need to put together the brackets that will weld to the frame,
    but I gotta buy a hole saw of the correct size first..
    so I'll show this part now,
    the rest later..
    I am using the Ford biscuit type mounts and the stock Chevy side bolt holes
    first is to position the frame at ride height
    and locate the motor where it will be in the frame
    locate the pad position
    and layout a pattern for the plate that will bolt to the block
    I happened to have a left over stock mount from some forgotten project to use to layout the holes
    but you could do it by careful measuring
    cut the pattern out and transfer to the steel
    I'm using 1/4" plate for overkill, 3/16" would work here too
    motor mounts 002.jpg motor mounts 003.jpg motor mounts 006.jpg motor mounts 007.jpg
  26. Paul
    Paul
    Editor
    drill the bolt holes
    I didn't take pictures here
    but I drilled one hole,
    bolted the plates together
    drilled the next hole and put a bolt in it too
    drilled the last hole and put a bolt in it as well
    that way both plates will be the same.
    then with the big grinder with a course disc I cleaned the rough edges,
    then on the cheapo disc/belt sander I squared the edges up
    bolt the plate to the block
    and fit the bearing plate and gusset pattern
  27. Paul
    Paul
    Editor
    transfer that to steel
    cut, clean, square, drill
    and tack in place
    cut a gusset to help strengthen it
    and repeat on the opposite side
  28. Paul
    Paul
    Editor
    then finally weld them up
    and done,
    two basic mounts to hold my motor up
    ...well not all the way done,
    gotta put together the frame brackets...
    I'll go get that hole saw now
  29. Paul
    Paul
    Editor
    ok,
    more cardboard templates
    more steel cut, cleaned, squared, drilled and tacked
    not bad for a Wednesday afternoon
    tomorrow maybe a transmission mount
    motor mounts 036.jpg motor mounts 038.jpg motor mounts 040.jpg motor mounts 042.jpg motor mounts 043.jpg motor mounts 039.jpg
  30. Paul
    Paul
    Editor
    yesterday I started putting together a transmission mount for the A
    it needs to be removable and strong enough to act as a center cross member as well as hold up the transmission
    I formed a simple plan and gathered up some materials
    first was the tab that the mount itself will bolt to
    so cut, grind, drill and bend
    transmission mount 001.jpg transmission mount 002.jpg transmission mount 005.jpg transmission mount 007.jpg
