Where can I find old Trw chevy 327 350 Hp cam specs ? They have to be Trw specs for a chevy cam with a Pt # CK 151 . I looked everywhere for the specs for that cam.
I know the feeling, I've been trying to find old Crower and Speed Pro cam part numbers with specs. No luck there either
sorry ,no TRW catalog according to the Chevy Performance Parts catalog : .447 lift intake and exhaust , 222 degrees duration at .050 lift , 114 degree lobe centerline. their part number 3863151 . there are more spec's on it in the Chevy Power book if you want edit: i have an old Speed Pro catalog and i do see a copy of it , their part # CS-179R
my old TRW and wolverine cam books say 327/350 cam specs are 222/222 @.050 306/306 advertised duration .447/.447 lift 110/118 lobe centers 114 lobe seperation events @.050 1 41 49 7 trw part number for this cam is tp240 in my '89 book
I bought that same cam back in 89, the dealership i bought it from claimed it was the same as the old 350 hp 327 cam thats how it was listed in there book a little while after that they called it a computer smoothed or improved desighn. but was pretty much the same cam.
The CK 151 was a Cam Kit which contained a TP 151 Cam. The Specs are Valve Lift, I&E, .460, Cam Lift, I&E, .307, Duration I&E, 302 deg, Overlap 74 deg. Timing Events Intake Open BTDC 7 deg. Close ABDC 45 deg. Exhaust OpenBBDC 55 deg., Close ATDC 3 deg. with 1,5 Rocker. HemiDeuce.
Hello Get a camshaft T210 TRW Ford Y Block 292-312. I would like to know the specs since I have not the catalog Thanks in advance
out in storage i have the books(trw crower and who knows) hold tight and give me some time ill dig em out
Strictly by memory; the '151' cam was TP240 and the 30-30 cam was TP118. TP147 was either the '140' (first design, off-road) cam that was a Z-28 option, or, it was the mildest of 5 roundy round cams made in the late 1980's by TRW. I think I still might have an old TRW catalog laying around, I'll look for it this weekend if you don't find the answer you need........ Al in TN
