vacuum gauge needle vibrates 1"HG
Discussion in 'The Hokey Ass Message Board' started by Von Rigg Fink, May 29, 2008.
  1. Von Rigg Fink
    Von Rigg Fink
    from Garage
    here is the back ground.
    SBC 327 Rochester quadrajet. (stock spread bore). Edlebrock perfomer intake
    HEi ignition. comp cam 12-242-2 if you need more info let me know
    while at Idle engine has about 14 to 15 inches Hg. vacuum
    the needle vibrates somewhere between 13 and 14 Hg consitantly..like a buzz so fast that the needle is a blurr.
    at acceleration the needle keeps the same blurr. and while holding the RPM at say 2000 or 2200 or any other elevated RPM the needle continues to keep that blurr or vibration.
    also to add to the equation at the elevated RPM there is a uneavenness to the engine, like a stumble.
    Tonight i plan on changing the spark plugs, and the carb base gasket to see if this solves or changes anything.
    anyone out there ever have this type of senario before? what was your diagnosis? what changed things. should i worry about the rapid needle vibration its only 1" and focus more on the engine stumble?
    yes i have gone thru and adjusted and re adjusted the valves , it doesnt remove the 1" needle fluxuation.
  2. Try another gauge. Maybe a vac leak.
  3. tommy
    tommy
    That's a sign of an engine miss that could be caused by many things.
    Read this
  4. plym_46
    plym_46
    from central NY
    Just posted a link to a site with a bunch of vacuum gauge diagnosis illustrations. It's on the driving by vacuum thread.
  5. thunderbirdesq
    thunderbirdesq
    Valve guides a little sloppy? What's the engine rebuild history?
  6. In the bottom of the drawer there is a folded up piece of paper that has a series of little pictures that show what the different readings mean.
    It is under the Playboy magazine.
    TagMan likes this.
  7. TheMonkey
    TheMonkey
    from MN
    considering the size of your cam, it sounds pretty normal to me. the cam is spec'd to have about 15.5" vac at 800 RPM, so perhaps you can tune idle a bit.
    my cam is expected to have slightly less vac than yours (13-14"). the nature of valve overlap gives funky vacuum reading.
    if you are concerned about the condition of your motor, i think a proper leak-down test will tell you quite a bit more information.
    with a normal cam that pulls nearly 20" at idle, the vacuum gauge would be steady. this data is off of a newly built motor with a hyd-roller cam expected to get 13-14" vacuum, idles at 750 RPM:
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Most vac gauges I've had used a 1/8 pipe fitting to screw into the manifold/carb, this had a small hole [less than 1/16] in it. That serves to dampen the pulses,without it I would get he same flutter. Not much to worry about.
  9. Danimal
    Danimal
    1. A-D Truckers
    Heads are supposed to have been newly gone through. He and I both got sets from the same guy. Looks like Tommy's like leans more towards ignition with the 1" bounce. Heads would tend to be higher, 3-4".
    We'd like to get this sorted out so he can drive to Billetproof Detroit in just over a week.
  10. art.resi
    art.resi
    Yes good site.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    im leaning toward the ignition issue..im changing the plugs tonight and the carb base spacer and gaskets tomorrow , each change i am going to test.
    i do feel that some of it could be valve overlap and possibly normal for this cam and head set up the valves are 1.94s..1.60's and the vac gauge is new, and it does have that tiny hole in the inlet im feeding it with a 1/4" hose off of my manifold. really the engine seems to run fine..may need a bit of tweeking (timing& mixture). the only thing that is bothersome is the studdering at RPM.
    and that could be plugs or carb tuneing and timing all playing with each other.
    I will go thru a sytematic elimination of the possibilities so i can pin point what was causing the stumble and or the needle buzz.
    If i dont get the needle buzz to disapear but the engine feels healthy i will atribute it to the valve and cam combination.
    oh and no the engine wasnt completely rebuilt. rod and mains were re done, cam and lifters and heads were redone. piston bores looked good and didnt have much ridge on the top so I elected to stay out of re-ringing or new pistons.
    the vac. readings are not indicating any problems with the lower end..ie piston ring wear etc..new carb, new manifold.
  12. blown49
    blown49
    Pretty good diognastics here:
  13. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah nice chart...but it doesnt have the one that shows what my gauge is showing..i have that chart too..thats why when i ran across the reading im getting i was a bit stumped.
    im going with the valve overlap thinking..because the engine runs good, and the stumble is unrelated, and i will find what is causing the stumble.
  14. Flat Ernie
    Flat Ernie
    Tech Editor
    I think yours falls into the loose valve guides/burnt valves area...
    Is that cam hyd or mech? If mech, check valve lash...
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    its hyd. lifters..could be loose guides..definetly not burnt..yet. they are new. I hope the dude that did the valve job didnt scrimp, on doing it right.
    Flat ernie, what do you think about the possibility of the "valve overlap" issue that was discussed? is it a possibility?
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    im still going after the ignition system first, than the carb, than if none of that cleans it up..than i will suspect the guides
  17. tommy
    tommy
    If I understand it correctly the fluctuation that you are seeing is the difference between one cylinder and the other 7. A hot cam usually results in a lower vacuum reading than a stock cam but it should still be relatively stable at that lower reading. I was taught that the bouncing is a result of one cylinder not producing the same amount of vacuum as the others. Others may disagree.
  18. Von Rigg Fink
    Von Rigg Fink
    from Garage
    ok i got a little more to go on..
    I pulled my plugs last night..i dont know how i fucked this one up, but my plug gap was only at 32 to 35 th...mmm that aint right for an HEI ignition..should be around like 45 right? and yes im talking .045..any way.
    as i see one chart does show having some erratic needle movement if the plug gaps are too tight..That will be rectified this weekend and also a new carb base gasket. The low vac. is normal for this cam per manufacture. so its still possible to even out that needle flutter. i guess we will see.
    yes i verified the plug gap...R44TS should be gapped at 0.045 for use with HEI ignitions
  19. TheMonkey
    TheMonkey
    from MN
    how much does your RPM vary while idling?
    lumpier cams have lumpier idle RPM. remember, without load vac will increase with RPM. watch your vac gauge go up as you lightly rev your motor.
  20. nexxussian
    nexxussian
    Okay, now I gotta watch. I have never heard of that being the problem (except when a plug got bumped and was only gapped to a few thou, and different from the rest).
    Keep us posted.
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    remember nexxussian i have a few other issues that could also be causing it..and one of them cannot be changed. (valve overlap sequencing)
    but i did see on one of my vac reading charts ,where incorrect spark plug gap gap can effect the vac gauge..so. im skeptic too ,but im not going to rule it out until i see it for myself.
  22. Flat Ernie
    Flat Ernie
    Tech Editor
    Yeah, I think you're grasping at straws here...
  23. I'd focus more on the stumble, and less on the gauge.
  24. nexxussian
    nexxussian
    I'm not knockin ya for trying it, it's free after all. I'll just be surprised if that's it, so I'm watchin, might learn sumthin;), ya never know.
  25. mac762
    mac762
    They might say that HEIs are supposed to run a .045 plug gap but I haven't found that to be the case in any of the cars I've had. I've even tried .040. They always run better in mine with .035. This goes for a junkyard HEI, a Mallory, or an Accel. Serveral different cars and motors too.
    I'm gonna install a vacum gauge today or tommorow for mileage reasons. I'll see if mine moves, my car has a slightly lumpy cam 224/234 duration and .46something/ .473 lift in a very fresh motor.
    Later Josh.
    yes i verified the plug gap...R44TS should be gapped at 0.045 for use with HEI ignitions[/QUOTE]
  26. sdluck
    sdluck
    I have hei dist in three of my cars and have always run 055. to.060 gap, plugs last 2 years,idle is smoother and gas milage is better
  27. TheMonkey
    TheMonkey
    from MN
    interesting this turned into a plug gap discussion... but thought it might be worth mentioning that a larger plug gap (even if with an HEI that can fire it okay) is much harder on your secondary ignition circuit because of the increased resistance. so make sure that your plug wires, rotor, and cap are all very fresh if you try this. if it runs better (or smooths out vacuum if that's your goal), that's great, but plan on replacing secondary ignition circuit components more often.
  28. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah my friend was saying to run the gap much larger too like .050 or .060..i have never run one that wide before. and if you look back in this thread the chart that was put up one of the readings that is close to what im seeing does say that in-correct plug gap can effect the gauge reading..im not sold on it..im just saying.
    my feeling ..its the cam. and the stumble is what im after..i will get that figured out..its probably carb related.
  29. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Flat ernie..i got the same chart as posted on post #12 of this thread..second to last row of gauge readings ..very last gauge shows something like what i see..and it reads, plug gap too close or points not sync.
    now valve guides as i have seen usually read more like 2 to 3 or even 4 if there really bad and are usually a smoother needle bounce.
    Like i said im still not convinced myself..and am leaning toward the new cam. but will keep all that care posted..who knows , some one may end up with the same question some day. Right?
  30. Kramer
    Kramer
    Something I'm not clear on, (maybe I missed it) is this a new engine just fired and doing this?, or has this gauge read okay before and know just started doing this fluttering? May make a difference in trying to trouble shoot.
