Im new to this era of cars.so i could use some help...i have a 1931 model a cowl...rails...stock suspension....have a new 4 banger with original transmission... im removing an putting in a 1950 flathead 8 with the tranny...question is i have a brand new brassworks radiator for the 4 banger..can i use this with the 8 ? Sufficient for cooling? And most of all is it possible to mayb y the double hoses together that the 8 require for the radiator...reason being i would like to use my factory 31 radiator cover with center fill...the 50 radiator wont fit at all under the 31 cover oviously...or do i need to use a different radiator cover to hide the 50 radiator....if so what year would fit in front of that 50 radiator an still look good? Im sorry if this is such a novice question...i would really appreciate help...thanks so much . Derek Foster r.i. 401-749-7491 phone calls always appreciated. Posted using the Full Custom H.A.M.B. App!
You can sell the radiator in the classifieds or find a competent radiator shop to add the extra hose outlets,,but from what I remember about the Model A radiators they are tapered on one side of the bottom tank,it gets very narrow. It can't hurt to check with a radiator shop in your area. HRP
